Toyota 90915-YZZD3 oil filter, is there a longer version?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glk21c, Jan 30, 2012.
  1. Jan 30, 2012 at 5:26 AM
    glk21c
    glk21c [OP] Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    I've searched around, not having any luck, hopefully someone can help me out. My 07 Taco 4.0LV6 calls for the Toyota OEM 90915-YZZD3 oil filter. What I'm looking for is an equivalent Toyota OEM oil filter that will fit (threads, diameter), but is longer. For example, the Fram PH3600 is a longer version of the 3614. I'm looking for the Toyota part# for a longer Toyota filter.
    Thanks much in advance
  2. Jan 30, 2012 at 5:30 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    This maybe a dumb question, but why? And as far as I know I don't think toyota makes anything "longer" that fits the Tacoma.
  3. Jan 30, 2012 at 5:37 AM
    glk21c
    MD
    Just more filtering area
  4. Jan 30, 2012 at 5:39 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    As long as you change the oil when recomended, than there is no reason to switch up filter size.
  5. Jan 30, 2012 at 5:45 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    I'm pretty sure the d3 is the longest one. There is one shorter that is the replacement for the 3.4 but a lot of people including myself use the D3 because of the extra volume. But im pretty sure that's it.
    And honestly the effects of that extra half inch are probably minimal. But I understand your interest.
  6. Jan 30, 2012 at 5:48 AM
    glk21c
    MD
    could have sworn is was a filter used on a "Tundra", but hopefully someone will know. I'm pretty sure, if the Toyota filter exists, it provides more than just a 1/2"
  7. Jan 30, 2012 at 9:53 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
  8. Jan 30, 2012 at 10:00 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
  9. Jan 30, 2012 at 11:31 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Toyota designed your engine oil system with that filter. If they felt like the filter should be longer/shorter, there is plenty of room to do so. Stick with the D3.
  10. Jan 30, 2012 at 1:17 PM
    Oysterhead
    Oysterhead Well-Known Member
    Nashville
    '10 TRD OR
    Kings are king
    Napa 1516 should be what you're looking for.
    Maybe people who have used it can chime in.
    On previous vehicles I've been a big fan of longer/larger capacity filters....and don't buy in to the hypothesis of "stick with OE because if you needed longer they'd use it".
  11. Jan 30, 2012 at 1:19 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    The D3 is the longer filter. The D1 is the short one.
