Toyota brand tacoma Seat cover install SR5
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doublejdog, Jul 22, 2008.
  1. Jul 22, 2008 at 4:07 AM
    doublejdog
    doublejdog [OP] New Member
    I bought my 08 and had the dealership install the seat covers. They look awesome but the driver side cover has a problem and I'm not sure if they installed it properly. At the base of the seat between the seat back and seat cushion there is a foam tube that tucks in the the crack to keep the cover tight. The tube keeps popping out when I get in/out and I have to tuck it back in every time. The delereship just "tucked" it in during the install. Is that the proper way and I just have to deal with it, or should it pull through the back of the seat for a permanent grip? Thanks for any help.
    drewskie likes this.
  2. Jul 22, 2008 at 4:39 AM
    andrew
    andrew Well-Known Member
    05 TRD Sport, 4x4- totaled
    OEM bug deflector
    Pictures?
  3. Jul 22, 2008 at 2:27 PM
    viq
    viq Member
    So.Cali
    07 4x4 SR5 Sport Edition
    I have the Toyota brand seat covers on an 07 double cab and experienced the same problem with the tube not fitting in the crack of the seat. The tube is a bit longer than the width of that crack, so you may have to trim a little off the tube and it should fit perfectly with no problems. I've had my covers on for about a year with no problems. Hope this helps!
  4. Jul 22, 2008 at 2:32 PM
    gavonder
    gavonder She's Kickass!
    Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    It definitely should be pushed all the way into the seat. It's not easy to do, but you will know it when it is right. Just start on one side and work your way over.
    GA
  5. Mar 3, 2016 at 12:31 PM
    stanrs48
    stanrs48 Member
    Should have strap and clamp under seat
  6. Mar 3, 2016 at 12:34 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I'd hope he'd have figured that out some time in the past 8 years since he asked. ;)
    @stanrs48
  7. Mar 3, 2016 at 1:01 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  8. Mar 5, 2016 at 5:29 AM
    stanrs48
    stanrs48 Member
    Guess I need to look @ the date before I post huh lol
  9. Aug 5, 2019 at 3:21 AM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Bump because some asshole pulled out the piece of my seat covers and now it won't go back in.
