Toyota frame rust letter
Discussion in '1st Gen. Tacomas (1995-2004)' started by fukthacubs, Mar 1, 2010.
  1. Mar 1, 2010 at 11:37 PM
    fukthacubs
    fukthacubs [OP] Well-Known Member
    wisconsin
    v6 sr5 4x4 5 speed
    i just got a letter about frame rust on my 02 taco. they say if there is a fixable problem they will spray some crap on it, and that wil fix it. wont that just seal in the rust making it worse later? if the rust is "un fixable" they will buy the truck back for bluebook value. has any one else got this letter or delt with this yet. I guess this letter was only sent to heavily road salted areas
    :mad::mad::mad:
  2. Mar 2, 2010 at 3:00 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
  3. Mar 2, 2010 at 3:55 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Please read your letter carefully. I know that the 01-04 tacomas are supposed to have frame replacements if the rust can't be mitigated. My 00 was bought back by Toyota for 150% of excellent KBB retail value. For what KBB value will Toyota buy it back if the rust can't be halted/repaired? Since buying my 2010, I have not been following the 01-04 frame rust mitigation, but there are many on here who've been directly affected by this, and will most likely chime in.
  4. Mar 2, 2010 at 4:54 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2 Mark.
    To add, this has been going on for almost 2 years now. If the OP's letter is correct, maybe they ran out of frames? :notsure:
  5. Mar 2, 2010 at 9:18 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    As far as spray on halting the process, the theory is that rust needs oxygen in order to grow, so by cutting that off, it shouldn't ever get worse. Good in theory, but I'm highly doubtful of this fix since there are just many places they cant easily get the spray and the spray they do use doesn't seem to last all that long.
  6. Mar 2, 2010 at 9:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    The coatings usually incorporate a rust inhibitor and converter. Some State's EPAs have yet to approve the coating for use.
  7. Mar 2, 2010 at 9:26 AM
    shaunbuddy
    shaunbuddy New Member
    seattle wa
    03 tacoma trd double cab
    17" chrome American Racing rims, Gibson stainless exhaust system, K&N filter charger system.
    I got the same letter, I have some rust but have not had it checked out yet, you?
  8. Mar 2, 2010 at 9:53 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Oh, cool. I was about to give Toyota a call soon, because I was actually thinking of sanding down some rust and spraying it with some rattle can paint myself to stop it from rusting more. If they'd do it for free that would be awesome.
    Go for it.
  9. Mar 2, 2010 at 12:58 PM
    fukthacubs
    wisconsin
    v6 sr5 4x4 5 speed
    i have not taken it in. i plan on calling later today to get it in. ill let you know when i get more info it would be cool if you did the same
  10. Mar 2, 2010 at 1:23 PM
    fukthacubs
    wisconsin
    v6 sr5 4x4 5 speed
    i just looked under mine and theres rust but it dosent look 2 bad i think mine will pass SHIT i had my hopes high for a reason to get a new taco
  11. Mar 2, 2010 at 7:03 PM
    ywen
    ywen Well-Known Member
    Wait.. so they've changed now from frame replacement being an option to now either spray or buy back? So no more frame replacement?
    And regarding blue book value, did they say whether they'll buy back at Excellent Cond price?
  12. Mar 2, 2010 at 8:32 PM
    fukthacubs
    wisconsin
    v6 sr5 4x4 5 speed
    buy back is 1.5 times exelent kbb
  13. Mar 2, 2010 at 8:34 PM
    fukthacubs
    wisconsin
    v6 sr5 4x4 5 speed
    my appointment is Wednesday
  14. Mar 3, 2010 at 4:40 AM
    ywen
    so absolutely no mention of frame replacement huh? damn..
  15. Mar 3, 2010 at 5:58 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    2001-2004 is still frame replacement. They have the frames.
    1995.5-2000 is 150% KBB. No frames.
    Take your truck in to get it inspected as that gets you entered into their 15 year extended warranty (from the time the truck was 1st put into service.) plan.
    You have until Oct. 2010.
    Doesn't cost anything but if you get a rust-through in that time, your truck will be bought back or frame replaced, just depends on the year of the truck.
  16. Mar 3, 2010 at 6:21 AM
    ywen
    they still got frames? well not according to the letter the OP received they don't...
  17. Mar 3, 2010 at 6:34 AM
    mortuusangelus
    mortuusangelus Well-Known Member
    Michael
    Slate Hill, NY
    no truck now :(
    Could be that dealer doesn't want to replace the frame (or doesn't have anyone qualified enough working for them to do the work.)
    Easiest way for the OP to find out... talk to the dealer and ask. I've gotta schedule mine, just in case.
  18. Mar 3, 2010 at 6:53 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    If they are extending the frame replacement out 15 years, I'm sure they have frames.
    I had my frame replaced in January and the semi that brought my frame had frames stacked 10 deep on his truck, on their way to other dealers.
  19. Mar 3, 2010 at 10:51 AM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    I'm waiting for my call from Toyota to get their buyback offer. I think the issue is not whether they have replacemnt frames, but a matter of cost. It probably costs Toyota less to replace the frames on the 01-04s than to buy them back at 1.5X KBB, whereas they are paying less than $12K for the 97-00s' buyback. Just a matter of a break-point.
    The worst of the rust is actually on the insides of the frame (as in on the inside of the frame, where you can't see). Stick your finger in a hole and feel around. You'll feel the flaking. It will first rust through just ahead of the front perch for the rear springs, particularly on the driver's side. I doubt there is any way they can spray rust preventative in there to kill the cancer. Take a hammer and hit that part of your frame, on the inside (as in between the frame rails) by the gas tank. If it makes a hole, take it in. You qualify. If not, take it in for inspection and get the rust-proofing. The rust-proofing will not invalidate the extended warranty. Eventually it will rust out anyway.
  20. Mar 3, 2010 at 10:54 AM
    ywen
    You're missing the point.. the confusion here is a 2002 owner received a letter stating ONLY rust prevention treatment OR buyback. 01-04 is suppose to have frame replacement as an option instead of buyback. So unless the OP can clarify what the letter states, this would indicate a change of direction for the rust issue on the 01-04 models
