Toyota Key Fob Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iGrom32, May 12, 2014.
  1. May 12, 2014 at 1:00 AM
    iGrom32
    iGrom32 [OP] Well-Known Member
    SoCal
    I would first like to start off by saying how much I love TW for helping me out when I don't know a thing. Now on to the question :)
    I recently purchased a used 2006 TRD Sport from a dealership and they only gave me one set of keys. I took a look at the keys and first of all the ignition key wasnt the OEM Toyota one but a knockoff it seems like. Second the unlock button on the key fob does not work what so ever.
    So how can I fix the key fob? Or do i need to fix the antenna like below?
    Here is a link to the Extending keyless entry range. Do we have an antenna like this?
    Sorry I am all over the place.. Would just like to get this fixed
  2. May 12, 2014 at 2:53 AM
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    I like the link for extending the range,
    Has anyone ever tried or thought about trying to use , let's say maybe a corolla key which is a fob & key combination. Try to get it cut and programmed for a Tacoma? Hope I make sense.
  3. May 12, 2014 at 3:04 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I 'll be glad when they start reducing the size of those key fobs. They are handy but are way too bulky.
  4. May 12, 2014 at 3:11 AM
    TacoTy
    TacoTy Active Member
    Ty
    Colorado Springs, CO.
    2012 Tacoma
    WAY WAY WAY off subject and I apologize, but VOZ I swatted your signature bug. Got a good laugh from it.
  5. May 12, 2014 at 3:32 AM
    voz
    VOZ
    VOZLAND
    The Clean One
    Hahaha. It happened to me on a motorcycle forum. I stole it.
    Sorry, back to topic at hand.
    I have an alarm fob with separate key for my Tacoma & YJ, then another fob/key combo for wifey's car, house key, key to hitch lock.. Would love to reduce at least a key or two
  6. May 12, 2014 at 3:57 AM
    Kala
    Kala Well-Known Member
    BigIsland
    05 PreRunner SR5
    I feel ya on that one…but I would like to know if you can get the combination key to program with a taco. Then I wouldn't feel as raped for just a single key to be made(unless its gonna cost $300+).
  7. May 12, 2014 at 4:24 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    The key you have is likely a transponder key which is programmed specifically to start that vehicle. If you lose this key, or it becomes defective, you'll get a big bill to make a new key, as the vehicle transponder system will have to be replaced. It takes a master key to program another key (antitheft system design)
    You should immediately have another MASTER key made. Maybe a locksmith specializing is autos. I had another dealer key made for my prerunner a couple years ago and it was $125.00 ($60 key, 65 labor)
    For the key fob, search around on line; there should be a toyota fob available that can be field-programmed with instructions.
    Good luck.
  8. May 12, 2014 at 4:35 AM
    voz
    VOZ
    VOZLAND
    The Clean One
    OC,
    eBay has plenty of Toyota key fob combo blanks, I would assume they are all transponder keys that would have to be cut & programmed.
    You guys are way smarter than I. I quests I wanted to know if it is even possible to do. Would any Toyota transponder type key work or is it something specific to a Tacoma?
  9. May 12, 2014 at 9:24 AM
    iGrom32
    SoCal
    Ya my key fob just completely broke now so is there anyway I can open it up and try to fix it?
  10. May 12, 2014 at 9:27 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I think you might have to go to a dealership to get new fobs made or possibly a locksmith might be able to help you out. Either way its not going to be cheap.
  11. May 12, 2014 at 9:45 AM
    iGrom32
    SoCal
    Does anyone know if we have an antenna that can be fixed just like 1st gens?
  12. May 12, 2014 at 2:36 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Working on that as we speak...but keep it hush hush ;)
    Dude just buy a new one from eBay, or go back and tell them that it doesn't work and make them give you a new one...
    eBay oem ones go from $10-70 depends where you look
  13. May 12, 2014 at 4:53 PM
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    I've seen toyota remotes on ebay.
    What was wrong with just a key and a door lock/opener remote?
    Seems to me that the new keys and remotes are expensive and un-needed, at least by me.
    I'm a curmudgeon though.
  14. May 13, 2014 at 12:26 PM
    iGrom32
    SoCal
    Can anyone link me to a reputable seller of the key fob?
  15. May 13, 2014 at 1:45 PM
    devkurf
    devkurf Member at Large
    midwest
    Here is the one I got after I bought my 05. The key FOB that came with the truck didnt work, the dealer replaced the battery in the old FOB and it didnt work, so they gave up on it. i found this one on Amazon. Its a little tricky to get it into programming mode, and you will look like a moron doing it, but with a little patience you can save some big time $ over going through a dealer. Mine has worked flawlessly for 5 months. Cant beat $ 29 shipped.
    LINK TO KEY FOB ON AMAZON:
    http://www.amazon.com/gp/product/B0068OZ25K/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
    THESE ARE THE INSTRUCTIONS I USED:
    http://www.programyourremote.com/classified/2005-toyota-tacoma-listing-6162.aspx
  16. May 13, 2014 at 2:18 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I had problems with my keyfobs on my 2006, one had a bad range, the other went swimming with me in a lake and was never the same. I sure wish my Tacoma keys were like my Camry key with the remote built in.
  17. May 13, 2014 at 5:41 PM
    iGrom32
    SoCal
    Thanks devkurf! I just ordered that!
  18. May 13, 2014 at 6:57 PM
    zmw
    zmw Well-Known Member
    SATX
    2014 TXproBAJA
    none
    does anyone know if you can use the camry keys? I know on a lot of toyota vehicles they were interchangable - what about an L100 landcruiser key?
  19. May 13, 2014 at 7:01 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    The key might be programmable, the key fob part is not. Different frequency
  20. May 14, 2014 at 2:02 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    At this point, you've got nothing to lose. Open it up and see if you can clean the contacts, maybe with a Q-tip dampened with alcohol. Sometimes the contacts get damaged from people pressing too hard on the button, or dirt getting inside. I've got the same key fob in the photo with my '09. It's not a transponder chipped key.
