Toyota Oil Filter (Made in Thailand) vs. the competition........
Discussion in 'Technical Chat' started by chris4x4, Nov 15, 2010.
  1. Jan 4, 2011 at 8:05 AM
    #261
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Well from all that I think Toyota filter has the best design hands down. :D
  2. Jan 4, 2011 at 8:23 AM
    #262
    Dilley
    Dilley Well-Known Member
    WA
    06 2.7L
    KN Cold air intake, Dynomax exaust, Husky liners
    The one flaw with the factory filter is the bypass valve is on the top. Than means when the filtere gets clogged up or you really get on the gas the clean oil will pass over the outside of the dirty oil filter and pick up the filtered particles from the outside of the dirty filter and re-contaminate the clean oil. Also I am not sure if the antidrain back filter on OEM is made from silicone wich handles the heat better. WIX K&N out perform the OEM in every aspect except surface area. Fram SUCKS.. OEM VS WIX or K&N.. I think I would need more info to deside wich is better... but for the price I am leaning toward OEM... The bypass valve really makes me want WIX or K&N..
  3. Jan 4, 2011 at 8:31 AM
    #263
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Most bypass valves are on the tops of the filters, and Im not so sure it makes that much difference, as the contaminants are caught in the media, and not easilly washed away. Also, How hard you get on the throttle has no impact on weather or not the oil bypasses the filter. THe bypass valve function, is to provide a flow of oil to the engine if the filter is clogged.
  4. Jan 4, 2011 at 8:48 AM
    #264
    kbp68
    kbp68 hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    I have dealt with this issue in the past as a partsman for a large fleet. The logic was that with regular maintenance, the less expensive filters are more than adequate. As long as the filter met the manufacturers spec.
    The one and only issue we ever had was when a new powerstroke diesel was destroyed and the cause was determined by the local Ford dealer to be the substandard air filters that we were buying. When the equipment manager brought this "substandard filter" back to confront the parts manager we cleaned off the dirty filter to show him the manufacturer...MOTORCRAFT. (They were the cheapest!) Ford replaced the engine.
  5. Jan 4, 2011 at 8:51 AM
    #265
    Dilley
    WA
    06 2.7L
    I agree that I would not make that much of a differance on the contaminants in caught in the media being washed back into the oil but I believe that over time if you didnt change your oil for a while it could be a problem. That being said if you change it every 3 thousand even the crappy oil filter would probably work good. I may be wrong but i was under the impression that under really high RPM's that the bypass valve opens because the oil pressure is increased just like under low rpms if it is clogged.
  6. Jan 4, 2011 at 8:58 AM
    #266
    Dilley
    WA
    06 2.7L
    Agreed... but since the OEM filter is one of the better and cheaper ones I think it would be the best one if you are trying to save money..
  7. Jan 4, 2011 at 9:05 AM
    #267
    BlueT
    NorthEast
    As Chris points out pretty much all are with valves on top.
    If filter clogs and bypass valve opens there is enough oil pressure to pick up the biggest debris into the engine. I would bet filter gets its walls wiped clean when that happens.
    There is only one bypass valve between pump and oil filter and its set to pretty good pressure. oil pump is "hardwired" to engine which means more RPMS = More oil flow/pressure. With cheap filter there is possibility bypass valve opening prematurely and staying open.
    Filters do get clog. Its hard to pinpoint when they do because it depends on so many factors and its not something visible with out adding extra gauges. But crappy fuel, dusty environment, and crappy oil will shorten filter maintenance interval.
  8. Jan 4, 2011 at 9:07 AM
    #268
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The bypass valve only works if the filter becomes clogged, or restricted. RPM of the engine doesnt cause the oil pressure to become high enough to require bypassing the filter.
  9. Jan 4, 2011 at 9:29 AM
    #269
    Dilley
    WA
    06 2.7L
    all true.. but WIX and K&N bypass valve are on the bottom.. dollar for dollar OEM best buy.. I would need some tests but I think the WIX would out perform OEM because of the bypass valve.. Prob not measurable enough to make it worth the extra $.. this is a very good thread and I have learned a lot.. I am swithching to OEM.. FROM FRAM!.. :mad:
  10. Jan 4, 2011 at 9:40 AM
    #270
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Chris4x4, are TRD filters available in your area? The TRD filter has a welded nut on top and looks suspiciously like the K&N. I wonder if it's in fact inferior to the regular OEM filter.
    This factory project X-Runner still uses the regular OEM filter, despite all the other upgrades, including maybe even dry-sump lubrication:
  11. Jan 4, 2011 at 10:42 AM
    #271
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The only way to judge a filter based on the bypass valve, is weather or not it leaks. If you change your filter with each oil change, your filters bypass valve should never be excorsised. Once again, the bypass valve only comes into affect if the filter is plugged, or severly restricted. Your better off gauging a filter by the media in which it uses to filter the crap out of the oil. More media = can hold more crap, without plugging up.
    I dont have access to the TRD filter yet.
  12. Jan 15, 2011 at 8:55 AM
    #272
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Hey Chris, can you test the AMSoil Filters? I have boughten them several times, and at $12, I want to know what I'm getting :p
  13. Jan 15, 2011 at 9:22 AM
    #273
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When I get the money, Yes.
  14. Jan 15, 2011 at 10:00 AM
    #274
    Supra TT
    Eric
    Indiana
    Great! Thanks for spending the time and money for everyone to show what is actually in an oil filter. :thumbsup:
  15. Jan 15, 2011 at 10:38 AM
    #275
    Cutter29
    Cutter29 Well-Known Member
    Utah
    15 Tundra TRD PRO
    not to single you out but if there is a filter that you or anyone else would like to see added to the list why not man up and send chris the money or the filter? i know someone else sent him some. $5-12 isn't that much during an oil change but for this purpose it adds up fast.
    thanks for doing this chris
  16. Jan 15, 2011 at 11:06 AM
    #276
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
    :popcorn:awesome thanks for the info!
  17. Jan 15, 2011 at 12:13 PM
    #277
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    I sent Chris 30 dollars worth of oil filters so that we can all learn and know what goes on inside these filters. I would like to send him some more, from Napa, O'Reillys, Carquest, to make sure OEM really is the best or if we can at least find a comfortable substitute. For now, OEM Is a Definate win. :D
  18. Jan 15, 2011 at 12:15 PM
    #278
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Thanks chris.....i will be using the toyota OEM filter on my next oil change.
  19. Jan 18, 2011 at 8:42 PM
    #279
    Supra TT
    Eric
    Indiana
    Pm sent to Chris
  20. Jan 24, 2011 at 11:23 AM
    #280
    th3duke
    th3duke Active Member
    I'm not sure if this site was discussed; but it does mention the Toyota in comparison.
    hxxp://minimopar.knizefamily.net/oilfilters/toyota.html
