Toyota Oil Filter (Made in Thailand) vs. the competition........
Discussion in 'Technical Chat' started by chris4x4, Nov 15, 2010.
  1. Oct 26, 2011 at 8:15 AM
    #401
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Probably not since the outside diameter is 3.65 in and mine is 3 in. However I found that the HP-2009 is the same diameter and thread size but is 1.25 in taller.
    My next filter will be the HP-2009.
  2. Oct 26, 2011 at 9:58 AM
    #402
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Still likeing my Napa Golds. I am an old stuck in the mud I guess.
  3. Nov 7, 2011 at 9:36 AM
    #403
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    I try to get oem filters whenever there is a 15% dealer coupon.
  4. Nov 7, 2011 at 3:38 PM
    #404
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Where do you find these 15% dealer coupons:confused: Thanks.
  5. Nov 13, 2011 at 5:20 PM
    #405
    Blake28104
    Blake28104 Active Member
    Blake
    Phenix City Alabama
    09 Prerunner SR5 W/ 3" Toytec Lift
    Areo Turbine Muffler 4" Roll SS Tips at 45 3'' Toytec Lift Toytec Rear 2" AAL's 20" KMC Monsters Nitto Terra Grapplers 33" 275-60-20 6000K Fog 6000K RETROFIT Headlight HIDs BY: Morimoto LED Led Corner Lights LED Tag Lights Flat Tinted Tag Cover Memphis PR1000.1 Amp 2 Rockford Fosgate P3s Scanguage11
    I have that same problem when i crank my truck up and drive at low idle it makes a very quite ticking sound only for like 30 seconds when i barely press the gas. and it only dose it when its cold and this is the first time its started doing it and i just tried a mobile one filter. i use to use fram . i think they are all garbage till after the vid. post !!! looks like i'm going back to Yota filters for now on !
  6. Nov 16, 2011 at 6:07 PM
    #406
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Denso Aftermarket also makes a filter PN 150-1003 that fits everything from Chrysler 300s to Tacomas to Tundras.
    There is info here along with the dissection shots. Looks like it has a different construction from the Denso Toyota OEM YZZD3 filter. [​IMG]
  7. Nov 24, 2011 at 9:20 AM
    #407
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
  8. Dec 2, 2011 at 10:51 AM
    #408
    tacomahq
    tacomahq Active Member
    Denver, CO
    I wrote the oil filter comparison you found on StumbleUpon, and while I didn't break down the filters the same way as the main post in this thread (and that post is awesome), I did do a few things differently.
    First, here's a direct link: http://parts.olathetoyota.com/tacoma-oil-filter-comparison.html
    1. I measured the surface area of the filter medium, because I felt that a larger surface area generally makes for a better filter.
    Filters are a compromise - they must clean the oil, but they must also have a high flow rate for times when the engine is really running hard or during start-up when oil doesn't flow quickly.
    2. I looked at each filter material under a microscope.
    While I had hoped to get a sense of the ratio to filter thread size to void space size, it really wasn't practical to measure. However, I did get a sense of the material. Wix, K&N, Toyota, and Fram all seem to use essentially the same material in at least one of their filters. Fram's "extra guard" filters use a thicker, heavier material that isn't quite as good (in my opinion) as the standard Fram filter, even though the ExtraGuard promises better performance...as I said above, a filter has to flow oil or it won't clean. Thicker, heavier filter paper isn't necessarily a good thing.
    3. I measured filter canister surface area, which relates to cooling.
    Filters help cool oil, and bigger filters are better.
    While I'm not trying to take anything away from the filter comparison leading this thread, I think it's worth a look. It's a reasonably short read.
    If you have any comments, let me know.
    Jason Lancaster
    Editor of TacomaHQ.com and guest author for Parts.OlatheToyota.com
  9. Jan 1, 2012 at 8:47 AM
    #409
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I use the toyota filter 90915-YZZG1. I just bought 2 more yesterday and noticed that it says it made in the USA. I was under the impression that all toyota filters where made in japan. After reading this thread, realized that there is the one made in Thailand. 90915-YZZD1. I understand that the one made in Thailand is just a bit longer. Is there any other difference? And is the USA one just as good as quality as the Thailand one.
  10. Jan 2, 2012 at 9:24 AM
    #410
    tacomahq
    Denver, CO
    I'm pretty sure you can't order YZZG1's anymore from Toyota...you must have gotten a couple that were sitting on someone's shelf for a while.
    They are a bit shorter, but otherwise I do believe they are identical. As far as quality, everything Toyota touches (except maybe accelerator pedals, LOL) is generally pretty good.
  11. Jan 3, 2012 at 12:45 PM
    #411
    tacoma guy
    Joe
    Phoenix Az.
    Thanks tacomahq, your the only one that chimmed in. After calling all over town, the yzzG1 replaced the yzzD1. Thats what thay are telling me.:confused: But your right anything Toyota makes is the best !
  12. Jan 5, 2012 at 4:35 PM
    #412
    tacomahq
    Denver, CO
  13. Jan 5, 2012 at 9:27 PM
    #413
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I run these on my truck. Offers increased capacity, while remaining interchangeable with the 90915-YZZG1. :thumbsup:
  14. Jan 16, 2012 at 4:11 PM
    #414
    Extreme2
    Extreme2 New Member
    Texas
    4x4 xtracab SR5 V6
    I have been using Wix filters on my Tacoma 2003 4x4 V6 and she is currently approaching 160,00 .... She has done great. In the beginning all I had to do was change the oil, air filter .... and did nothing to her until 121,000 miles at which time I changed my Timing Belt, water pump, belts, and spark plugs and only my front brakes. My spark plugs still had 10 percent left on them as well as my front brake pads. I have always had Toyota and have always been happy with the product .....
  15. Jan 24, 2012 at 7:04 PM
    #415
    Foxbat
    Foxbat Member
    Pennsylvania
    06 Tacoma
    Step rails
    Great comparison and hats off to you for the work you put into this. I used some dog meat filters in the past but will use OE from now on to keep the engine and synthetic flowing smoothly.
    Laughed at the use of murder term and your description calling crap for what it really is. Cool and Thanks:D
  16. Jan 29, 2012 at 6:09 PM
    #416
    1FSTLS1
    1FSTLS1 Well-Known Member
    Fram filter is going back to walmart! Think I will stick with Toyota or the Wix.
  17. Feb 10, 2012 at 9:09 PM
    #417
    clcoyle
    clcoyle Well-Known Member
  18. Feb 13, 2012 at 11:33 AM
    #418
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I dont know where to stick this but here is fluid chart for 2006-2009 Toyota vehicles
    TS-TR-0063-W.pdf
  19. Feb 24, 2012 at 10:54 AM
    #419
    Rennadair
    Rennadair Active Member
    Renn
    Charleston sc
    08 prerunner trd sport
    flowmaster true duals, airaid cai
    cool stuff
  20. Feb 24, 2012 at 11:34 AM
    #420
    40950
    CR, WA
    stock
    Just pulled a oil change yesterday. Original brake shoes are still good,,,185,000K on those suckers.
