Toyota Oil Filter (Made in Thailand) vs. the competition........
Discussion in 'Technical Chat' started by chris4x4, Nov 15, 2010.
  1. Mar 4, 2013 at 8:07 PM
    #481
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    There are still steel wear surfaces, but the filter itself catches anything large enough to damage the bearings.
    Magnetic oil drain plugs are misleading. Yes, they do show residue... but that is from the pan... before the oil passes through the filter.
    UOA tells how much iron is in the used oil and not trapped by the filter.
  2. Mar 16, 2013 at 11:07 AM
    #482
    Kylec82
    Kylec82 Jack of all trades, Master of none!
    Kyle
    Huxley, IA
    08 TRD Sport Dbl Cab
    Weathertech Floormats, Bak RollX Tonneau,Blacked out emblems, Powder coated wheels
    As a mechanic myself, along with my other mechanic friends, we have been referring to Fram filters as "the orange can of death" for years. Thanks for the pictures and info, way to spread the word.
  3. Mar 18, 2013 at 4:03 PM
    #483
    tomciopaluch
    tomciopaluch New Member
    tomasz
    Allentown
    Well just got 10q from AA of Pennzoil Platinum and 2 k&n filters for $44 after $20 rebate that deal is still on at Advanced Auto. I never used k&n oil filters lets hope they perform as advertised.
  4. Mar 18, 2013 at 6:12 PM
    #484
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    If you have the 2.7L engine you will like the K&N Filter. The filter uses a 1" socket to install and remove.
  5. Mar 18, 2013 at 7:41 PM
    #485
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Oh man now I have to stop buying Mobil filters. Will have to switch to Bosch for filters
  6. Mar 18, 2013 at 8:34 PM
    #486
    Rich91710
    Rich
    Los Angeles
    08 Base
    Fixed that for you.
    Never use any kind of tool to install a filter without using a torque wrench.
    Even my wimpy hand can get 3/4 turn on a filter.
  7. Mar 19, 2013 at 7:38 AM
    #487
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    What is the recommended torque setting Rich?
    Seems easy enough to do.
  8. Mar 19, 2013 at 7:48 AM
    #488
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Hand tight.
  9. Mar 19, 2013 at 7:31 PM
    #489
    Rich91710
    Rich
    Los Angeles
    08 Base
    Bingo.
    Someone posted the spec from Ford a few days ago. It's not much, but all I've ever read from Toyota is 1/2 to 1 turn beyond gasket contact.
  10. Mar 21, 2013 at 11:48 AM
    #490
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I go with 1/2 turn. I've had my share of taking off stuck filters including my own and the oil changes I do for friends. Not fun... Especially in an old Honda CRV where the filter is tucked up above the CV axle...
  11. Apr 11, 2013 at 7:39 PM
    #491
    yrffej
    yrffej Active Member
    '05 prerunner trd sport
    regarding the magnetic drain plug comment....
    if it catches metal filings in the pan vs the filter.... good enough.
    it's better to capture the filings wherever they are.... and restrict filings from flowing/recirculating with the oil....
    that being said,
    I cannibalized a defective computers hard drive, magnet
    (you won't believe just how powerful/strong those little magnets are, until you actually put one in your hand)
    I keep a hard drive magnet stuck to the top of my oil filter.... always....
  12. Apr 11, 2013 at 7:58 PM
    #492
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    x2
    Hard drive magnets are THE SHIT. Don't make the mistake of putting your fingers between two loose ones!
    I have one mounted on: each diff plug, trans plug, transfer case plug, oil plug, oil filter, and radiator cap. Like Jeff says: if it catches even a little bit of errant metal (which it does, if you've ever inspected a magnetized plug), then why not do it??
  13. May 13, 2013 at 6:46 AM
    #493
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    Does anyone know if the 4 cyl oil filter (part # ends in ZZ1) can be used on a 6cyl TRD, who's oil filter part # ends in ZZ3? are they interchangeable?
  14. May 13, 2013 at 7:52 PM
    #494
    Rich91710
    Rich
    Los Angeles
    08 Base
    They are interchangeable, but the normal way to go is to use the -3 on the 4 cylinder since it's a slightly taller filter.
    Makes for easier removal with the exhaust and filter heat shield down there.
  15. May 13, 2013 at 11:19 PM
    #495
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Recently discovered denso oil filters are very similar to Toyota filters. Non made in Japan ones. Ill cut one open to compare
  16. May 14, 2013 at 4:50 AM
    #496
    tombiosis
    T
    Ottawa Canada
    hunh?
    The oil filter is located at the top of the engine. Nothing in the way up there???
  17. May 14, 2013 at 6:00 AM
    #497
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    On the 4 banger its on the side.
  18. May 21, 2013 at 4:43 PM
    #498
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Doesnt denso make the toyota filter?
    Their name is on it.
    Look at the photos at the beginning of the thread.
  19. May 21, 2013 at 5:01 PM
    #499
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Well I failed... I was looking at my denso one and a Toyota one and was looking at the inside from the bottom and noticed both look similar. I get the denso ones for 3 bucks a pop.
  20. May 22, 2013 at 5:59 PM
    #500
    hantavirus
    hantavirus New Member
    Bakersfield
    '95 Xtra Cab
    Excellent research. Thanks for doing the work for us. I'll be locating a local vendor for the Toyota filters myself.
