Toyota Oil Filter (Made in Thailand) vs. the competition........
Discussion in 'Technical Chat' started by chris4x4, Nov 15, 2010.
  1. Aug 21, 2013 at 8:16 PM
    #541
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    There's an eBay vendor that charges $40 for a box of 10 shipped.
    Titus-Will is $88 shipped for 20 filters. The more you buy, the less the shipping and handling charges impact the cost.
    If you only want to buy one or two, your local dealership is going to be the most economical. If he tells you that it's $5 or $6, remind him that you can get them online for just under $4, but you prefer to give him your business.
  2. Aug 25, 2013 at 8:44 PM
    #542
    Aerial Tacoma
    Aerial Tacoma Well-Known Member
    Andre
    Kodiak Ak
    2010 TRD Off Road Access Cab
    TRD Cold Air Intake, TRD Catback, Original HomerTaco Raptor Grill, TRD Trail Teams "Black", Duratrac 265/75/16, ALL PRO apex rear bumper, Retrofits W/ BHLM halos and deamon eyes
    nice write up! browsed through the posts.. but not all, did you happen to compare the stock toyota vs the TRD filter? i just bought one so i am wondering after seeing this.
  3. Aug 25, 2013 at 8:51 PM
    #543
    Rich91710
    Rich
    Los Angeles
    08 Base
    TRD filter is identical to the K&N/Mobil-1 filter.
  4. Sep 1, 2013 at 5:42 AM
    #544
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Had a good laugh at Napa the other day. The same Napa Gold 1348 for my 2.7 fits my Sears Craftsman 20 hp riding lawn mower. Ohh,, the sinhumanity! :eek:
  5. Sep 5, 2013 at 1:51 AM
    #545
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    im tired of reading, been at work for 18 hours. a great trick i use for stubborn filters is i take a phillips screwdriver and punch it through the filter.. now you have a nice craftsman or snapon or mac or walmart stanley handle to turn even the tightest filter off :)
    i have always used the OEM filter, my gramps always said to and i figured it made sense. thanks for the OP and all the work
    i have another idea, get a bilge pump and fab up a tank with a filter mount and in a controlled environment test flow over a set time with some cheapo oil and play sand you can measure how much it actually holds before it gives up the ghost. I would be glad to do it but i cant afford a shit ton of filters.
    if someone had an extra engine stand i have a 22r block i can pull the rods and pistons out of and throw a compressor motor from an air compresser hanging out in my back yard (if it still works) on it to drive the crank and oil pump.. fill it up with 4 qaurts of oil install said filter add some sample dirt with some sort of measuring device over a period of time and find out when it stops pumping cleaned oil..
    i think it sounds pretty straight forward let me know what you guys think.
    i ran the k&n filter on my civic engines
    i ran the wix on my supercharged corolla once (ex wife drove it 500 miles) when it got home it was low on oil by 2 qaurts and knocking. it sat for about 6 months while i was in iraq and she was supposed to check the oil before the trip, i ran amsoil at the time and the wix was the "best" filter the parts store had while i was home, toyota was closed. im sure it was low to start with, and since i had to tear the engine open anyway i turned off the bypass and ran 11 psi untill she popped :) went a long way actually. im not blaming the filter, i blame the ex.
    i have worked on many, many old toyotas and the worst shape ones always had stp and fram filters. just throwing it out there.
  6. Sep 5, 2013 at 1:54 AM
    #546
    Konvict KROG
    Louisiana
    i used to buy my 22r filters with a discount back home for about $4
    the dealer sold out, they jacked the prices.. last time i was in they wanted 8.99..... i dug around untill i found a new one in the garage and im going to order them offline
  7. Sep 12, 2013 at 3:40 PM
    #547
    rande15
    rande15 Active Member
    ray
    new jersey
    13 tacoma dbl cab 4x4 TRD sport / 2017 Sport 4x4 Dbl cab
    What if u can get 90915 20004 filters? Use them? Better??
  8. Sep 12, 2013 at 3:56 PM
    #548
    beachingtaco
    beachingtaco "We have assumed control"
    Long Island, new york
    2012 DCLB trd sport
    westin nerf bars, ARE in-channel visors, Wet Okole's, mobtown tailgate skin, Tail Gate theft mod
    Great write up! Lots of good info in there!....I have a friend who own's a truck dealership and has been a top mechanic for probably 25 years. A while back I bought a new maxima which I asked him which filter I should use for oil changes and he said go with the stock filter. So that's what I've done and have had no problems, and from what you found out it looks like the stock one is the best.....
  9. Sep 12, 2013 at 11:01 PM
    #549
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not IMHO.
    They are a completely different design, and there has been a lot of speculation that they were designed only for the break-in period.
    One tech claimed that they did not have a bypass valve.
  10. Oct 8, 2013 at 4:37 PM
    #550
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    There's a bypass valve:
    The bypass valve's spring is the 4-prong piece in this photo (leftmost filter):
  11. Oct 8, 2013 at 4:58 PM
    #551
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    Wow nice job!!! Thanks!! I will stick with the factory filters!!!
  12. Oct 13, 2013 at 12:17 AM
    #552
    888
    888 Member
    Matthew
    Hilux 2.5 D4D
  13. Oct 13, 2013 at 12:35 AM
    #553
    Rich91710
    Rich
    Los Angeles
    08 Base
  14. Oct 14, 2013 at 2:53 PM
    #554
    BBlank12
    BBlank12 Active Member
    Brandon
    Dodge City KS
    01 prerunner 230k stock
    Kicker L7 with rocksford amp controlled by double din pioneer.blacked out grill with red yota emblem and SteelCityAirman Bed decals
    Has anyone used a John Deere Filter? part no. is TY15592E and is $3.89
  15. Oct 14, 2013 at 7:44 PM
    #555
    Rich91710
    Rich
    Los Angeles
    08 Base
    Why?
    Stock is not much more, readily available, and you know it's a quality filter, not one made for a piece of farm equipment.
  16. Oct 15, 2013 at 6:31 AM
    #556
    BBlank12
    Brandon
    Dodge City KS
    1. I work at John Deere. So they are available all the time and I get a discount on the filter.
    2. John Deere is farm equipment that has been testing filters for many years. I was just curious if anyone has used one if not I will get it a try. In all honesty I would trust a filter from them since they kind of need good filters to keep their machines running
  17. Oct 15, 2013 at 7:12 AM
    #557
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    Howdy Chris I have been running royal purple 5w-30 since I got my truck but I have used the "TRD oil filter" can you do a review on that to tell whether I wasted my money on the TRD oil filter before I buy number 4?
    I just did my oil change last week heres a pic of the oil attached to my post.
    Also I agree with Huckyourmeat lets see a TRD vs OEM toyota filter!
  18. Oct 15, 2013 at 8:55 AM
    #558
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I haven't had a chance to get my hands on a terd filter. If you want to send me one pM me for my address
  19. Oct 15, 2013 at 9:24 AM
    #559
    Red Rocket
    Red Rocket Member
    Southeastern NC
    Nice post !! I use the Toyota. I would not put a FRAM on anything I own...
  20. Oct 15, 2013 at 9:33 AM
    #560
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Not True...it can be had for $5.74 from Amazon, and Purolator routinely offers rebates on the PureOne filter ($2 off)
    As for the PureOne filter, I would argue that filter is made of better materials (Silicone Bypass Valve) as opposed ot the Nitrile one on the Toyota filter. Also the Purolator is made in the USA, where the Toyota filter is made in Thailand. At the end of the day both ar good filters and do what their supposed to :D
