Toyota Oil Filter (Made in Thailand) vs. the competition........
Discussion in 'Technical Chat' started by chris4x4, Nov 15, 2010.
  1. Feb 8, 2014 at 1:11 AM
    #581
    jahjah
    jahjah New Member
    Many years ago, I bought a used junker that took a very standard filter. I had several new filters in my shop that I wasn't really planning to use. I decided to see if one of them would clean up the dirty oil in the corolla. I installed a Fram filter and ran it for about an hour. Of course, it was a subjective test but I really couldn't see any significant improvement. Also, the Fram didn't have an anti-drain back filter and when I took it apart, part of the paper element was torn. I don't think they know which vehicles need the valve. I installed a standard Purolator filter. After an hour, the oil was perhaps cleaner but still dirty. I installed a Lee filter. That cleaned it up noticeably but it was still dirty. (I don't think Lee is around anymore) I then installed my last filter, a Hastings. When I checked the dipstick, at first I thought there was no oil on it. Dipping it again, I looked closer. The Hastings had so completely filtered the oil that it was light golden in color. Upon disassembly, the filter was very well made. I continued to use them and extended my change duration. I have also used some Purolator One filters
    I use OEM Toyota filters for warranty purposes now. I don't know if the Hastings filters are still exceptional or not. I know they make a high end filter with a filter inside the filter design but they are expensive.
    I don't know if the square area of media is a totally valid way to compare filters. It probably is.
    The Purolator One filter specs are available for what percentage is trapped at different micron specs. Most filter specs do not relate to a small enough particle.
    It would be cool if you looked at a Hastings. I'm curious if they are still exceptional.
  2. Feb 8, 2014 at 1:43 AM
    #582
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Total Chaos Mid Travel, Sway away coilovers,31x10.50x15 goodyear wrangler authority's
    Great write up! Ive always used the Toyota filters. Id like to see same test done on synthetic oil brands. Walmarts supertech brand V Mobil 1 synthetic. Ive heard the oil breaks down the same but havent seen any real testing to prove it. Why pay more just for a name or advertisement gimmick!
  3. Feb 8, 2014 at 2:07 AM
    #583
    00PowderSpecial
    00PowderSpecial Well-Known Member
    Chad
    Newfoundland, Canada
    09 TRD DC
    Excellent review! I usually bought whatever filter at canadian tire, an dit was usually the mobil 1 when it was on sale. Was there last week to get things to do an oil change and noticed it was $15! So I went to toyota to pick one up and there only $9. Think I'll be buying online now though.
  4. Feb 8, 2014 at 6:22 AM
    #584
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Skimmed off of Hastings filter site:
    In 1995, Hastings Premium Filters became part of CLARCOR. Other CLARCOR companies — Airguard, ATI, Baldwin Filters, Clark Filter, Facet International, FPI, PECOFacet, Purolator Air, Purolator Engineered Filtration Products, Purolator Facet, Total Filtration Services and United Air Specialists — along with Hastings Premium Filters, are able to share the latest ideas and technology and create solutions that lead to better products.
  5. Feb 9, 2014 at 3:43 AM
    #585
    jahjah
    jahjah New Member
    Mod, I saw that information on their site. While it could indicate that a Hastings filter is the same as a Purolator filter, that may not be the case. If you dig down into their pdf spec sheets, it is interesting to note that they use a Powder Technologies Inc. test dust in their contaminant efficiency test. This is the company that is credited with establishing an ISO standard for filtration testing. There is a specific % of each micron size in the test dust down to 1 micron. This results in a lower efficiency value (in the 80+% area) than other companies that report 99+% efficiency because they are looking at the trapping ability of a 30 micron particle. The honesty is refreshing.
  6. Feb 9, 2014 at 6:31 AM
    #586
    Mod
    CR, WA
    stock
    I had to google Purolator Facet,,never heard of that one. Seems to be a specialty/custom filter side company. They also do acoustic attenuation studies. Maybe just a think tank group. I'm thinking Clarcor just holds the Purolator air filter holdings, and the complete side of Hastings with each company doing there own thing for the most part. Could be wrong.
  7. Feb 9, 2014 at 12:51 PM
    #587
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Bosch purchased Purolator oil filters around 2004.
    This happened about the same time that Champion Labs began producing the "E-Core" design (arguably worse than Fram).
    Prior to the purchase:
    Bosch, Supertech, AC-Delco Duraguard, STP (and others) = Champion Labs standard filter.
    Purolator = Purolator
    Mobil-1, K&N, AC-Delco Duraguard Gold = Champion Labs premium synthetic media
    After the purchase:
    Supertech, AC-Delco, STP (and others) = Champion Labs standard filter using E-Core design.
    Bosch, Purolator = Bosch ownership, Purolator production facilities.
    Mobil-1, K&N = Champion Labs premium synthetic media
    AC-Delco Duraguard Gold = Discontinued
    Prior to the changes, I would have used any of the filters listed.
    After the changes, I would use nothing but Bosch/Purolator or the premium.... assuming that an OEM Toyota filter is not available.
    Supposedly, the Toyota TRD filter is a Champion premium. I've seen a few reports that it has been inspected and found to be the same as the Mobil-1. I have also heard the same for Royal Purple.
    Amsoil oil filters are Wix, but they tend to "cheap out" a bit, meaning if you take two EAO filters, one with a 2.5" tall can, and one with a 4" tall can, they will both have the same filter element inside, so the taller can doesn't gain any filtration area.
  8. Feb 9, 2014 at 12:53 PM
    #588
    Rich91710
    Rich
    Los Angeles
    08 Base
    Lee was a Purolator product.
  9. Mar 10, 2014 at 2:17 PM
    #589
    1tacoplease
    1tacoplease I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    Any thoughts or recommendations on the TRD oil filter?
  10. Mar 10, 2014 at 7:47 PM
    #590
    Rich91710
    Rich
    Los Angeles
    08 Base
    It's a decent filter.
    Same as the K&N and Mobil-1... made on the same line side by side.
  11. Apr 3, 2014 at 11:34 AM
    #591
    rocklobster24
    rocklobster24 New Member
    David
    Marylnd
    98 tocoma sr5
    Stock, except bilstien shocks
    Great views thanks, I bought a magnetic oil drain plug I'll see what I pick up next oil change. Too bad I bought a k&n anybody here think that champion synthetic oil on Auto anything is any good. wally world has 5Qt container of mobile 1 syn for 25 bucks better than Advanced for 37 bucks.
  12. Apr 3, 2014 at 8:09 PM
    #592
    Rich91710
    Rich
    Los Angeles
    08 Base
    Go with Mobil-1. Never heard of "Champion Synthetic"... it's definitely a private label from another manufacturer... possibly Mobil-1, possibly Castrol (group-III mineral base and certainly not worth $60 for a case).
  13. Apr 16, 2014 at 2:19 AM
    #593
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    I work as a tractor and grounds equipment mechanic. I have now for 31 years, at the local school board. We only use Fram oil filters. I have never seen an oil filter related damaged engine in all of this time. However, because of this write up, I'll never again use one on my personal vehicles. Thanks.
  14. Apr 16, 2014 at 5:32 AM
    #594
    jahjah
    jahjah New Member
    Fram advertising has been very effective. Unfortunately, their filter aren't.
    I have seen several that were assembled so hastily that the ends of the filter element was not attached.
    Now they have designer filters to create a "premium purchasing experience" by getting people to think that a high mileage or synthetic oil engine needs a different filter.
    Fram banks on the fact that oil contaminants slowly wear out engines in a manner that is essentially impossible to quantify on a small sample basis. How many engines that Fram wears out early equals the loss of a complete power unit?
    Basically, it comes down to the fact that frequent oil changes are a better deterrent to wear than the best filters because the change removes abrasive contaminants and corrosive chemical from the engine.
    If your school board is going to support a filter, why not support one that costs the same but filters well?
    Some filter brands are being made in China now, including Fram. It is nearly impossible to maintain a quality control program in a Chinese factory.
  15. Apr 18, 2014 at 2:18 AM
    #595
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    It's all about specs an low bids....We also use HORRIBLE Champion spark plugs and no-name no-sevice rated motor oil in 15w40. We had a vendor selling us batteries...I noticed and pointed out that a batch of them were actually "rebuilt" lead acid batteries and not new, sealed gel batteries like we needed and had paid for....They complained that we were picking on them because they are a "minority" vendor, I guess black owned, like it matters, and won the case. They still slip in a clearly used battery every now and then and many arrive dead and with internal shorting issues. This is my situation.
  16. May 11, 2014 at 9:10 PM
    #596
    MrDFixIt
    MrDFixIt Member
    Dick
    Roanoke, VA
    '13 TX Pro
    This is an EXCELLENT thread and write-up on the topic.
    I am fairly certain that if you open the Wix "XP" variety of the 51348 you will find that it is identical to the Amsoil brand filter with the synthetic media.
    Again, GREAT job on this!
  17. May 11, 2014 at 9:23 PM
    #597
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yup.... Amsoil is Wix.
  18. Jun 28, 2014 at 5:42 PM
    #598
    DirtyDTaco
    DirtyDTaco Talk slow, shoot fast.
    Matthew
    Mississippi
    '00 XtraCab 4x4 3.4L V6 5-Speed, 240K miles
    Polk 6.5" Coaxial Door Speakers, Pioneer DEH-X6500BT Head Unit, Black Bed-Lined Badges, 15% Tint, JL Audio 10" BassWedge, Alpine 500w Mono Amp
    ^So are napa filters if anybody hasn't already said it.. Just drop the 5 from the wix number and there you have the napa number. 1348.
  19. Aug 12, 2014 at 5:57 AM
    #599
    MateoTorgy
    MateoTorgy Well-Known Member
    Mateo
    Minnesota
    2014 TRD OR AC 6 Cyl
    A link to this thread has been posted in many other forums, including the Rav4 and a Tundra forums in addition to Bobistheoilguy.
  20. Aug 12, 2014 at 6:03 AM
    #600
    MateoTorgy
    Mateo
    Minnesota
    For what it's worth, the bitog thread includes a post showing a graph comparing efficiency ratings of some of these filters including the Toyota. While the 100% synthetic filters achieve a 99% rating, the Toyota has a disappointing 51% rating. Looks and amount of material are one thing. Engineering, the molecular composition of the media, and actual tested performance are another. My gut tells me to stick with the M1 EP but I've ordered the Toyota from Amazon anyway just to compare the two.
