Toyota Oil Filter (Made in Thailand) vs. the competition........
Discussion in 'Technical Chat' started by chris4x4, Nov 15, 2010.
  1. Apr 11, 2016 at 4:23 PM
    #721
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Your fav. OEM is cheap on ebay covers warranty. Why worry? Or read 47 pages of shit.
    CusterFan and IronPeak like this.
  2. Apr 16, 2016 at 9:41 PM
    #722
    TacoYes
    TacoYes Well-Known Member
    2011 Silver 2.5 Door
    Black Wheels, Grill, Running Boards
    Just to confirm, I have a 2011 2.7. The Toyota filter 90915-YZZD1 is the correct filter? When looking for the filters I also see 90915-YZZG1, does this work also. I read at least 10 pages of this specific forum, excellent information, thanks Chris for your time and effort.
    Found one person say all the filters are interchangeable except for the smaller cars. Just want to confirm this before buying 10 filters. I found 10 filters for 45 on eBay and in the description it states it comes with the 1 year 12000 mile warranty from the dealership. As others have stated they are worried about fakes, I think this seller is legit.
    This what's in the description; "You are purchasing parts & accessories from East Madison Toyota Scion, serving our Toyota Scion customers in Madison, WI. We understand what our customers expect and deserve. Every part or accessory purchased from us will come with your receipt as well as Toyota’s 1 year/12,000 MILE warranty honored nationwide by authorized Toyota Dealers."
  3. Apr 17, 2016 at 12:22 AM
    #723
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    90915-YZZD1 is stock number for the 2TR-FE, but you can use the larger oil filter 90915-YZZD3 that is meant for the 4.0L engines. I have it on my truck and sometimes if you go to the dealer, they'll give you the 90915-YZZD3 filter as well. It'll hold more oil than the D1 filter so should give you for protection. So get the D3 filter.
    Camelback Toyota parts online you can get the filter for $3.89 and they have free shipping (order over $150) and a small discount if you use TWpartz coupon code. I both some parts so it was easy to get over $150.
    nikkerton likes this.
  4. Apr 24, 2016 at 9:47 PM
    #724
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Good thread, wouldn't put a Fram on my lawn mower. They suck that bad! That extra guard is dubbed the Orange Can of Death for a very good reason!
    I'd use Toyota filters if I could get them here locally but the nearest dealership is over 100 miles away so I use Purolator Classics or Motorcraft filters on my truck. Both are high quality and available everywhere. Purolator makes Motorcraft so they are of very high quality. Ford uses an exact equivalent filter that Tacomas use on their Focuses and Escapes if anyone is wondering if they are safe to use.
  5. Apr 24, 2016 at 9:59 PM
    #725
    TacoYes
    Kolunatic and Markcal like this.
  6. Apr 28, 2016 at 6:53 AM
    #726
    MateoTorgy
    MateoTorgy Well-Known Member
    Mateo
    Minnesota
    2014 TRD OR AC 6 Cyl
    I'm switching from Mobil 1 M1-102 to Toyota. Hat in hand. Falling on the sword.... I've been doing some research and seeing the point that greater filtration (more filtration media etc...) isn't necessarily better in that it tends to restrict flow. These are extremely important issues folks. I spend a great deal of time deliberating them. Someday this information will save the world. Just watch.
  7. Apr 28, 2016 at 9:51 AM
    #727
    TacoYes
    I have always used Mobil 1 oil, recently the extended (15K). I typically used the Mobil 1 filter or Bosch, 11$ - 12$. This thread help me feel good with switching to the Toyota filter. Having always changed the oil around the 7500 mark, I am thinking about running the (very clean looking oil at 7500) oil to 10k and changing the filter out at 5k.
    Just an FYI the $40 special on ebay ends at midnight Saturday (4-30-2016). You have to put it in your cart to get the $5 off.
  8. May 4, 2016 at 8:11 PM
    #728
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Long thread. Took me a few hours to go through it all. Great job Chris 4x4 on the filter examination.
    In my opinion WIX and Toyota filters are in the same boat filtration wise. They are okay but from what I have seen the WIX is close to 40 microns absolute (98.5%).
    Baldwin B243 is an upgrade in filtration and works great in my 2TR-FE and also my brothers 1GR-FE. The filter is a 30 micron absolute and 12 microns at 50% of the first pass which is perfect for both engines. WIX has claimed 20 microns at 95% but the same rating is used on nearly all the filters I've checked that fit. 51515, 51516, 51348 all have the same beta ratio. The Thailand TRD and USA built TRD oil filters are 2 totally different animals. The Thailand version is sub standard in my opinion. The USA built (Champion Labs) filter is okay but no better than many other Champion Labs filters. Purolator Pure One is a great filter as is the Motorcraft FL400s and the FL910s. Both built by Purolator for Ford with a top/thread mounted bypass valve.
    Now for some food for thought.
    As far as I know the filter is the oil bypass valve for the engine in the case of the 2TR-FE and possibly the 1GR-FE and idle oil pressure averages 20-30 PSI. So in the case of most filters the bypass valve is set at 8-12 PSI meaning the idle oil pressure is opening this valve and it is running constantly open and some oil is bypassing the filter completely. The Motorcraft FL400s has a bypass set at around 20 PSI which means the oil bypass is again open but not nearly as much as a filter with a 8 to 12 PSI bypass spring. This would mean at idle more oil will be forced through the element rather than around it. This is why it is important to have good air filtration as the contaminants that enter the engine will be suspended in the oil and act as an abrasive. Bad air filtration is the cause for many premature engine failures more so than filters that only capture 40 micron particles.
    Just my 2 cents on the topic.
    Vigo likes this.
  9. Jul 31, 2016 at 12:40 PM
    #729
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
  10. Jul 31, 2016 at 9:08 PM
    #730
    2004TacomaSR5
    Jon
    Montana
    I prefer regular oil filters myself. The problem with those synthetic fiber/wire mesh filters is they are a bit more restrictive to oil flow than standard filters. How much more is difficult to know, but I personally prefer a filter that's less restrictive with good filtering ability (OEM Toyota, regular WIX, Purolator Classic, etc) versus a filter with more restrictive filtering and a tad bit better filtering ability and holding capacity. I also don't believe in running a single filter multiple OCI's either. Change the oil, change the filter, every time for me!
    TOMB likes this.
  11. Nov 28, 2016 at 6:13 AM
    #731
    rcw65
    rcw65 Member
    Rick
    SC
    2017 Toyota Tacoma TRD PRO - Super White
    275 x 70 x 16 BFG KO2, removed charcoal filter, K&N filter, LED for; interior lights, bed, back-up and license plate. Pioneer 8200 NEX / car play / Idatalink, Raised Tacoma black letters ( tailgate) Red line Tuning hood quick lift Elite, Factory roof rack.
    Engine Oil Filter Study BY: Russ W. Knize.
    Warning!
    These pages are NOT to be taken as gospel. The primary motivation behind this study was to provide information about what oil filter brands are made by which manufacturers. The secondary motivation was to uncover some of the obvious internal construction issues of these manufacturers. This "study" is not a "test". The SAE J806 and J1858 tests were designed to test the filtration capability of these filters, but unfortunately they have several short comings. These include issues such as anti-drainback valve functionality (valve train noise, etc.), filter element containment capability (how long before it blocks and bypasses--related to surface area), and many testimonials that appear to point in the direction of certain manufacturers. It has been my hope to shed some light in the direction of these issues. While my infamous "two eyes and common sense" approach may not be the most scientific, it is the best I could do considering there was no personal return on the investment of time and money I put into it.
    The primary shortcoming of this study is the small sampling size. I only tested the Ford 5.0L filter. It has come to my attention that some brand names use different manufacturers for different applications. Another shortcoming is the lack of testing of the filter element media itself. Unfortunately I have neither the time nor resources to do this.
    I invite anyone with the means to take a larger sampling size and conduct a more complete study, which may include private SAE tests. I also invite anyone to repeat a study similar to this one on other model filters.
    With all of that said, please make your own judgements. Use this study only as a source of some information that may give you a better idea about which filter brands to steer clear from. It should be obvious that some manufacturers are not being honest about their product. The next time you buy a filter for your car, buy two and hack one open to see what you have. My intent was to give you some information and alert you to some little-known issues, not to tell you what to think.
    Description
    One weekend I set out to every auto parts store in my area and bought every brand of oil filter I could find. I chose to get the filter for the early Ford 5.0L V8 engine. The reason is that this is a popular filter, it is large so that I can unveil any fake miniature internal components. I was able to find 20 different filters spanning several brand names. They are (in alphabetical order):
    AC Delco Duraguard PF2
    AC Delco Duraguard PF2L
    AMSOIL SDF15
    Car And Driver SF-1A
    Champ
    Deutsch D539
    Deutsch D545
    Fram Extra Guard PH8A
    Fram Tough Guard TG8A
    Fram Double Guard DG8A
    Hard Driver HD01
    Mobil 1 M1-301
    Motorcraft FL-1A
    NAPA Gold 1515
    Penzoil PZ-1
    PowerFlo SL30001
    ProLine PPL-30001
    Purolator Premium Plus L30001
    Purolator Premium Plus L390001
    Purolator Pure One PL30001
    Quaker State Q58A
    STP S-01
    Wix 51515
    Disassembly and Measurements
    Basically, I cut open each filter on a lathe and took measurements of many of their attributes. Simply cutting them open revealed some very interesting (and disturbing) information.
    The sections below detail each of the filters I tested. A summary of the measurements I took can be found in a table for each. I noticed that other filter part numbers for the same brand were designed a bit differently. This is probably because of the shape of the can and the requirements for that engine. Here is a description of each table entry:
    Average Retail Price
    The average of all the retail prices I found for this filter (to the nearest $0.50)
    Cartridge Length
    The length of the filter cartridge, including end caps
    Cartridge Outside Diameter
    The outside diameter of the filter cartridge element pleats
    Cartridge Inside Diameter
    The inside diameter of the filter cartridge inside support tube
    Cartridge Pleats
    The number of pleats (or folds) in the element while in the cartridge
    Cartridge End Cap Type
    The type of material used to construct the end caps
    Anti-Drainback Valve Type
    The valve design and construction material
    Bypass Valve Type
    Element Type
    The type of material used to construct the filter element and the seam seal
    Element Length
    The overall length of the element when removed from the cartridge and stretched out
    Element Width
    The width of the stretched-out element
    Element Surface Area
    The calculated surface area of the cartridge using the above two values
    Shell Thickness
    The thickness of the metal used to construct the filter's shell
    Backplate Thickness
    The thickness of the metal used to construct the filter's backplate
    Gasket Type
    The type of material used to construct the backplate sealing gasket (O-ring)
    Hydrostatic Burst Pressure
    The amount of pressure that the filter case can withstand for a short duration without failure.
    SAE J806 Filtration Efficiency
    See the SAE Tests section for more details on this test.
    SAE J1858 Filtration Efficiency
    The construction of the anti-drainback and bypass valves is an important feature. Many are made of nitrile rubber. As long as they have good sealing surfaces, they generally work fine. However, nitrile rubber gets stiff in extreme cold and will likely fail to seal in those conditions. Silicone rubber seals or steel valves are not prone to this. Many bypass valves are spring-loaded steel and work well. Some are spring-loaded plastic and are often not molded well enough to make a decent seal, allowing oil to leak past them.
    Probably the most important value here is the element surface area. This determines the amount of filter media that is available to trap particles. The smaller the area, the sooner the filter will become plugged and will end up bypassing much of the oil instead of filtering it. More pleats in the elementdoes not necessarily mean more surface area (as you will soon see). In fact, too many pleats can end up restricting the flow too much because there is not enough space between them to allow oil to flow.
    The shell and backplate thickness are only relevant if your engine’s oil system operates at unusually high pressures. Even the cheapest filters have to be strong enough for stock oiling systems, or they will not pass SAE tests.
    The SAE filtration efficiency tests are from the manufactures, and are only available for the filters I could find the information for.
    Other measurements and values are debatable and I will allow you to draw your own conclusions from them.
    SAE Tests
    All filters have to pass SAE (Society of Automotive Engineers) tests to prove that they can truly filter out small enough particles. There are two tests available for automobile engine oil filters. All filters must pass the J806 test, but the new J1858 is much more meaningful. Currently the J1858 test is optional. Really, it's a way for high-end filter manufacturers to show off their great filters.
    The SAE J806 test uses a single-pass test, checking for contaminant holding capacity, size of contaminant particles trapped, and ability to maintain clean oil. As an amendment of the J806 test, the multi-pass test also looks for filter life in hours, contaminant capacity in grams, and efficiency based on weight. The efficiency of the filter is determined only by weight through gravimetric measurement of the filtered test liquid. Typical numbers for paper filter elements are 85% (single pass) and 80% (multi-pass).
    The SAE J1858 test provides both particle counting and gravimetric measurement to measure filter capacity and efficiency. Actual counts of contaminant particles by size are obtained every 10 minutes, both upstream (before the filter) and downstream (after the filter), for evaluation. From this data filtration ratio and efficiency for each contaminant particle size can be determined as well as dust capacity and pressure loss as a function of time. Typical numbers for paper element filters are 40% at 10 microns, 60% at 20 microns, 93% at 30 microns, and 97% at 40 microns.
    AC Delco
    Duraguard PF2
    Some years ago, a study was done on oil filters that uncovered the Fram filter farce. They named AC Delco’s filter to be one of the better models. Later, AC Delco changed their design and went to a cheaper setup made by an offshore manufacturer. Even so, I definitely recommend this filter over the design of any Fram filter. In fact, I even recommend it over the low-end Wix and I (personally) prefer it over the Purolators.
    The filter cartridge has a large outside diameter with deep pleats, which gives the filter element the maximum flow possible. At first glance, it appears to have little filter element media, but the surface area measure was suprising: 315 sqin. The unit had a solid top end cap because the bypass valve is at the bottom, which is a well-constructed spring-loaded steel with a nitrile seal design. The nitrile rubber diaphram-type anti-drainback valve doubles as the seal between the bypass valve and the cartridge. The only drawback to this design is that the bypass valve seats metal-to-metal against the backplate. This could allow oil from the clean side of the filter to seep back into the oil pan, but it won't allow the dirty oil in the filter to seep back. Oil that is in the main gallery usually leaks out through the main bearings anyway while the engine sits. This is a better alternative to the high-end Wix, which can allow oil to seep from the dirty side of the filter to the clean side.
    The telltale signs for an AC Delco filter are: 5 large holes for the oil inlet and 6 spot welds on the rim surrounding them. There are no crimps holding the gasket in place. When you look through the inlet holes, you can see the metal bypass valve with its 12 small holes and the black anti-drainbackvalve diaphram around it. Through the center outlet hole, you can see the spring for the bypass valve.
    Exploded view:
    $3
    Cartridge Length
    4.625 inches
    3.375 inches
    1.375 inches
    Cartridge Pleats
    36
    Stamped steel
    Nitrile rubber diaphragm
    Bypass Valve Type
    Spring-loaded steel
    Element Type
    Paper media, glued seam
    Element Length
    70.0 inches
    Element Width
    4.500 inches
    315 square inches
    Shell Thickness
    0.015 inches
    Backplate Thickness
    0.100 inches
    Gasket Type
    Nitrile rubber
    Unknown
    Unknown
    Unknown
    Car And Driver
    SF-1A
    This filter is a Champion filter with the one-piece filter cartridge and the fragile paper filter element.
    $3
    Cartridge Length
    4.000 inches
    3.250 inches
    1.625 inches
    Cartridge Pleats
    54
    Stamped-steel, with bypass valve
    Bypass Valve Type
    Spring-loaded steel, nitrile seal
    Element Type
    Element Length
    87 inches
    Element Width
    3.875 inches
    337 square inches
    Shell Thickness
    0.012 inches
    Backplate Thickness
    0.102 inches
    Gasket Type
    Nitrile rubber
    Unknown
    Unknown
    Unknown
    Champ
    This filter is manufactured by Champion Laboratories, Inc. (same guys who make the spark plugs), and is sold under several other brand names. Champion admits some of these outright, and they are: Lee, Lee Maxi, and STP. Though they claim the Lee Maxi is a higher quality filter, they make no claims as to why. It sounds more like a marketing scheme to me.
    The Champion design has metal end caps on the filter cartridge, with the bypass valve stamped right into the bottom end cap like the Purolator. I refer to this as a one-piece filter cartridge.
    Though definitely not the same design as the Purolator, it does use the same type of leaf-spring-type spacer at the top of the cartridge and the nitrile anti-drainback valve, which doubles as the cartridge-to-backplate seal, at the bottom. The drawback to this one-piece cartridge is the rather fragile filter element paper media. It is a thin, brittle paper that rips fairly easily. It was difficult to disassemble these cartridges without destroying the filter element. One other issue is that I sometimes noticed some rust on the backplate of these filters. Since the rust is usually around by the inlet holes, any loose rust would be caught by the filter.
    The telltale signs for a Champion filter are: 6 large holes for the oil inlet, one of which is larger than the others. Only the black anti-drainback valve can be seen through the inlet holes. There are 6 large crimps holding the gasket in place. Through the center outlet hole, you can see the bypass valve spring. Usually, the backplate metal is dull, or even rusty.
    Deutsch
    D539
    $3
    Cartridge Length
    4.000 inches
    3.250 inches
    1.625 inches
    Cartridge Pleats
    55
    Bypass Valve Type
    Element Type
    Element Length
    88.5 inches
    Element Width
    3.875 inches
    343 square inches
    Shell Thickness
    0.012 inches
    Backplate Thickness
    0.102 inches
    Gasket Type
    Nitrile rubber
    Unknown
    Unknown
    Unknown
    Fram
    Years ago Fram was a quality filter manufacturer. Now their standard filter (the radioactive-orange cans) is one of the worst out there. These filters are manufactured by Allied Signal, Inc. Please do not buy these filters. By boycotting it, we may be able to cause some change. I have personally had one if these filters fail and actually cause engine damage due to bits of paper and glue floating around in the engine.
    For some inside dirt on Fram filters, see this email from an Allied Signal production engineer.
    This filter cartridge has a small outside diameter with a rather low filter element surface area (193 sqin), and features cardboard end caps that are glued in place. The rubber anti-drainback valve seals against the cardboard and easily leaks, causing dirty oil to drain back into the pan. If you have a noisy valve train at startup, this filter is likely the cause. The bypass valves are plastic and are sometimes not molded correctly, which allows them to leak all the time, but they often leak anyway. The backplate has smaller and fewer oil inlet holes, which may restrict flow, and is made of thin material.
    The telltale signs for a Fram Extra Guard are: It has 8 small holes for the oil inlet and a thin, cheap-looking backplate, and is currently stamped with a “2Y”. There are 5 very small crimps holding the gasket in place. If you look into the center hole all the way to the top of the filter, you will see a kind of “button” in the end cap of the cartridge (which looks like it's made of metal from there). This is the plastic bypass valve.
    Exploded view:
    $3
    Cartridge Length
    4.125 inches
    3.000 inches
    1.375 inches
    Cartridge Pleats
    34
    Cardboard
    Bypass Valve Type
    Spring-loaded plastic
    Element Type
    Paper media, stamped metal seam
    Element Length
    47.5 inches
    Element Width
    4.063 inches
    193 square inches
    Shell Thickness
    0.015 inches
    Backplate Thickness
    0.089 inches
    Gasket Type
    Nitrile rubber
    Unknown
    Unknown
    Unknown
    Even with all the problems of the other Fram filters, this one is not too bad. Aside from the filter cartridge, it is a very good design. Too bad Framcan’t get passed the cardboard end caps.
    It has an improved filter element with more surface area (248 sqin), a heavy silicone anti-drainback valve with a good sealing surface, the same plastic pressure relief valve but with an integral screen to keep out large particles, and enough inlet holes for good flow. The only real drawback to this filter is that it is capped on each end with cardboard instead of metal.
    The telltale signs for a Fram Tough Guard filter are: It has a better backplate that is usually shiny, with six larger holes for the inlet and 6 spotwelds around the them. There are 6 large crimps holding the gasket in place. When you look through the inlet holes, you can see the orange anti-drainback valve. If you look into the center hole all the way to the top of the filter, you will see a kind of “button” in the end cap of the cartridge (which looks like it's made of metal from there). This is the plastic bypass valve.
    $5
    Cartridge Length
    4.125 inches
    3.000 inches
    1.625 inches
    Cartridge Pleats
    50
    Cardboard
    Silicone rubber diaphragm
    Bypass Valve Type
    Spring-loaded plastic with integral screen
    Element Type
    Element Length
    61.0 inches
    Element Width
    4.063 inches
    248 square inches
    Shell Thickness
    0.015 inches
    Backplate Thickness
    0.187 inches
    Gasket Type
    Nitrile rubber, PTFE-treated
    Unknown
    Unknown
    Unknown
    Far Left: extra guard cartridge. Left: Double Guard. Right: Tough Guard
    This is a frustrating filter. Please do not buy it. It is one of the most expensive filters you can buy and it is junk. Inside is a basic Fram Extra Guard (PH8A) filter element that has larger diameter
    holes at the end and has been pre-oiled. You can see this in the picture above (far left). I assume this is to hold the Teflon particles in the filter element before the unit is installed. Don’t put Teflon in your engine. It does not belong there! DuPont does not recommend using their Teflon product in internal combustion engines.
    Although it has the worst filter element possible (193 sqin), it does have a clever spring-loaded nitrile rubber anti-drainback valve and bypass valve combination. Too bad the rest of the filter is worthless. Please don’t buy this filter!
    The telltale signs for a Fram Tough Guard filter are: It has a better backplate that is usually shiny, with six larger holes for the inlet and 6 spotwelds around the them. The backplate should be
    stamped with a “1K”. There are 6 large crimps holding the gasket in place. The anti-drainback valve diaphram behind the inlet holes is black. If you look into the center hole all the way to the top
    of the filter, you will not see the “button” in the end cap of the cartridge (which looks like it’s made of metal from there).
    $10
    Cartridge Length
    4.125 inches
    3.000 inches
    1.625 inches
    Cartridge Pleats
    38
    Cardboard
    Bypass Valve Type
    Nitrile rubber, integral
    Element Type
    Element Length
    47.5 inches
    Element Width
    4.063 inches
    193 square inches
    Shell Thickness
    0.015 inches
    Backplate Thickness
    0.187 inches
    Gasket Type
    Nitrile rubber
    Unknown
    Unknown
    Unknown
    Mobil 1
    M1-301
    Like the Champion, this filter is made by Champion Industries. However, it uses a unique end plate and a thicker can that make it the strongest filter available for wide-distribution retail sale. It also does not use the fragile paper media of the Champion filter. I’m happy to say that this filter is NOT a fake. It is definitely a unique design.
    It uses a synthetic fiber element that can filter out very small particles and is much stronger than the fragile, Champion paper media. It is rated just under the Purolator Pure One as far as filtering capability, but is still very much above conventional paper filters. It also has a very strong construction to withstand high-pressure spikes during start-up. Given the choice between the Purolator Pure One and the Mobil 1 filters, I would choose the Mobil 1 because of the restriction concerns of the Pure One and that pesky assembly string. However, as with all Mobil 1 products, expect to pay 2 - 3 times as much for this filter.
    Exploded view:
    $10
    Cartridge Length
    4.250 inches
    3.250 inches
    1.625 inches
    Cartridge Pleats
    52
    Bypass Valve Type
    Element Type
    Synthetic media, glued seam
    Element Length
    85 inches
    Element Width
    4.125 inches
    351 square inches
    Shell Thickness
    0.022 inches
    Backplate Thickness
    0.138 inches
    Gasket Type
    Nitrile rubber
    600 psi
    Single pass: 98%
    Multiple pass: 95%
    Unknown
    Motorcraft
    Long Lasting FL-1A
    This is an interesting filter. Basically, it is a Purolator Pure One filter cartridge in a Purolator Premium Plus case. Don’t be fooled by the differently-shaped holes cut into the oil inlet. This is the only difference. This is a good filter design and if you want to get a Purolator Pure One filter, getthis one instead: it is cheaper.
    Like the Purolator Pure One, this filter cartridge features a very large element surface area (400 sqin), but with many pleats (64). This packs the filter together rather tightly and may restrict flow somewhat. I could identify the Pure One element media by a purple dye they use at the seam. It also has the mysterious assembly string wrapped around the outside of the element. Like the Purolators, it features a spring-loaded metal bypass valve and a nitrile rubber diaphram-type anti-drainback valve. The bypass valve is stamped right into the bottom end cap of the cartridge, so it is all one piece.
    This data is taken from the Purolator specs and are not from Motorcraft:
    $3
    Cartridge Length
    4.125 inches
    3.250 inches
    1.625 inches
    Cartridge Pleats
    64
    Bypass Valve Type
    Spring-loaded steel
    Element Type
    Element Length
    100.0 inches
    Element Width
    4.000 inches
    400 square inches
    Shell Thickness
    0.011 inches
    Backplate Thickness
    0.120 inches
    Gasket Type
    Nitrile rubber
    Unknown
    Single pass: 99.7%
    Multiple pass: 96%
    Unknown
    NAPA
    1515 Gold
    This filter is a Wix filter with the two-piece filter cartridge. As with the Wix filter, the metal bypass valve seats on the metal cartridge end cap with no gasket of any kind. Some small amount of oil probably leaks through there. It also has the tougher paper filter media of the Wix.
    $5
    Cartridge Length
    4.000 inches
    3.250 inches
    1.625 inches
    Cartridge Pleats
    59
    Stamped-steel
    Bypass Valve Type
    Element Type
    Element Length
    87 inches
    Element Width
    3.875 inches
    337 square inches
    Shell Thickness
    0.014 inches
    Backplate Thickness
    0.104 inches
    Gasket Type
    Nitrile rubber
    Unknown
    Unknown
    Unknown
    51515 Silver
    This filter is a champion filter with the one-piece filter cartridge. As with the other Champion filters, it has the fragile paper media for a filter element. This is based off of my observation of the filter’s case. I did not purchase this filter to tear down, but may do so in the future.
    Penzoil
    PZ-1
    This filter was a big disappointment, but I knew what I was in for the moment I took it out of the box. It is a Fram Extra Guard (PH8A) in every way, shape, and form. The only difference is the yellow paint and Penzoil logo. As with the Fram, please do not buy this filter. Penzoil is insulting their own name by putting it on this filter, but obviously they are not interested in selling a quality unit.
    All the measurements were exactly the same as the Fram Extra Guard PH8A.
    $2
    Cartridge Length
    4.125 inches
    3.000 inches
    1.375 inches
    Cartridge Pleats
    34
    Cardboard
    Bypass Valve Type
    Element Type
    Element Length
    47.5 inches
    Element Width
    4.063 inches
    193 square inches
    Shell Thickness
    0.015 inches
    Backplate Thickness
    0.089 inches
    Gasket Type
    Nitrile rubber
    Unknown
    Unknown
    Unknown
    PowerFlo
    SL30001
    As you may suspect by the part number, this filter is a Purolator Premium Plus. There were no manufacturing differences, but the cost was an average of $2 instead of $3.
    ProLine
    PPL-30001
    Yet another Purolator Premium Plus. All measurements were the same. The cost was $2. One thing I noticed with this particular example was that the mysterious assembly string was tied too tight and had damaged the filter element. Although only this one had the problem, I am suspicious of this filter design as a whole (including all of the Purolators).
    [​IMG] <- With String - String Removed -> [​IMG]
    As you may be able to tell, the string did not rip into the filter element, it only crushed it. There was no evidence that the element had been compromised. Out of the 8 Purolators (and clones) tested, this was the only one with a problem.
    Purolator
    Premium Plus L30001
    Left to Right: Motorcraft, Purolator Pure One, Purolator Premium Plus
    Here is a fairly well designed filter, especially for the price. One odd thing about Purolator’s filters is a string that is always wrapped around the filter element. I assume that this is there to hold the element in place while the glue in the end caps cures. Of all the Purolator-based filter I tested, there was one (the ProLine) that had filter element damage from this string. Although it was one of five tested, I am weary of this design. Even though the element was crushed a bit, it was not ripped. I will take apart a used one at my next oil change.
    The filter cartridge has an impressive surface area of 316 sqin, which is very close to the AC Delco Duraguard. The difference is that Purolator's filter element is compressed into more pleats (51) than the AC Delco. This may restrict flow somewhat, but not as much in this model than the Pure One. It features a spring-loaded metal bypass valve and a nitrile rubber diaphram-type anti-drainback valve, which doubles as the seal between the backplateand the cartridge. Like the Champion, this bypass valve is stamped right into the bottom end cap of the cartridge, so it is all one piece.
    The telltale sign for a Purolator filter are: 8 medium-sized holes for the oil inlet and nothing but a black (or orange for the Pure One) diaphram to be seen through them. There are 6 large crimps holding the gasket in place. Through the center outlet hole, you can see the spring for the bypass valve.
    Exploded view:
    $3
    Cartridge Length
    4.125 inches
    3.250 inches
    1.625 inches
    Cartridge Pleats
    51
    Stamped-steel
    Bypass Valve Type
    Spring-loaded steel
    Element Type
    Element Length
    79.0 inches
    Element Width
    4.000 inches
    316 square inches
    Shell Thickness
    0.011 inches
    Backplate Thickness
    0.115 inches
    Gasket Type
    Nitrile rubber
    Unknown
    Unknown
    Unknown
    Pure One PL30001
    This filter has a few improvements over the Premium Plus. It has a denser filter media to filter out smaller particles and more surface area to make up for the flow restriction. Aside from those the cartridge is the same construction as the Premium Plus.
    The filter cartridge has an even more impressive surface area of 400 sqin. The potential issue is that this filter element is compressed into even more pleats (64) than the Premium Plus. This may restrict flow more than it helps relieve it. It also features a spring-loaded metal bypass valve and a silicone rubber diaphram-type anti-drainback valve, which doubles as the seal between the backplate and the cartridge. The bypass valve is located at the base of the cartridge, not at the top.
    $5
    Cartridge Length
    4.125 inches
    3.250 inches
    1.625 inches
    Cartridge Pleats
    64
    Stamped-steel
    Bypass Valve Type
    Spring-loaded steel
    Element Type
    Element Length
    100.0 inches
    Element Width
    4.000 inches
    400 square inches
    Shell Thickness
    0.011 inches
    Backplate Thickness
    0.115 inches
    Gasket Type
    Unknown
    Single pass: 99.7%
    Multiple pass: 96%
    Unknown
    Quaker State
    QS8A
    Yet another Purolator Premium Plus. Who are these people fooling? Cost was a bit over $2. If you like Purolators and you like the color green, buy this filter.
    STP
    S-01
    This filter is the Champion Industries filter with the one-piece filter cartridge and the fragile paper element.
    $3
    Cartridge Length
    4.000 inches
    3.250 inches
    1.625 inches
    Cartridge Pleats
    58
    Bypass Valve Type
    Element Type
    Element Length
    93 inches
    Element Width
    3.875 inches
    360 square inches
    Shell Thickness
    0.012 inches
    Backplate Thickness
    0.102 inches
    Gasket Type
    Nitrile rubber
    Unknown
    Unknown
    Unknown
    Wix
    These filters are manufactured by the Dana corporation, who also manufactures all of the Wix clones. These include NAPA and many OEM filters.
    NOTE: This section of the page was incorrect in regards to the “low-end” and “high-end” Wix concept. What I thought was a “low-end” Wix is actually manufactured by Champion Industries. My thanks to those who pointed this out to me. If you see any remaining references to low-end and high-end Wixfilters, let me know. Hopefully I found them all.
    This filter has metal cartridge end caps, but has a separate bypass valve that rests against the bottom end cap, like the AC Delco. I refer to this as a two-piece filter cartridge. Like the Champion, it uses an anti-drainback valve that doubles as the bypass valve-to-backplate seal. Instead of the leaf-spring-type spacer that most filters use, these use a stiff coil spring at the top of the cartridge. Like the Purolator, the filter element paper media is stronger than the Champion media. The only drawback to this design is that the bypass valve seats metal-to-metal against the bottom cartridge end plate. This could allow dirty oil to seep from the dirty side to the clean side of the filter, bypassing the element. The design will not allow oil to seep back into the pan, though.
    The telltale signs for a Wix are: 6 large holes for the oil inlet with only the black anti-drainback valve to be seen through them. There are 6 “notches” that hold the gasket in place. Through the center outlet hole, you can see the bypass valve spring. Usually the backplate metal is shiny.
    51515
    This filter features a good surface area, but a lot of shallower pleats. This makes it similar to the Purolator’s pleats.
    $5
    Cartridge Length
    4.000 inches
    3.250 inches
    1.625 inches
    Cartridge Pleats
    61
    Stamped-steel
    Bypass Valve Type
    Element Type
    Element Length
    90 inches
    Element Width
    3.875 inches
    349 square inches
    Shell Thickness
    0.014 inches
    Backplate Thickness
    0.104 inches
    Gasket Type
    Nitrile rubber
    Unknown
    Unknown
    Unknown
    Conclusions
    All of this information can be a bit overwhelming. When it comes down to it, all of the lower-priced filters ($5 or below) have they ups and downs. In reality, there are only five different manufacturers available. Here are the low-cost filters that I feel safe using, based on all this information (in alphabetical order): AC Delco, Purolator, and Wix. Here are my reasons for each:
    I like the deep pleats of the AC Delco’s filter element and the fact that it is not weak like the Champion. I also like the way that the anti-drainbackvalve diaphram makes a positive seal to the filter cartridge and to the bypass valve, which sort of “snaps” into the diaphram. The fact that the bypass valve seats against the backplate metal-to-metal is not a big deal. It probably doesn’t leak anyway, but if it does, only clean oil can get back into the pan. In case you haven’t noticed, I like this filter. :) It is the best filter that you can buy for $3.
    The Purolator is a very solid design. It seems to have the toughest paper filter element of them all and the bypass valve is built right into the cartridge. There are no internal sealing problems with this filter at all. I wish the inner diameter of the cartridge was smaller so that the pleats could be fewer and deeper. The Premium Plus version looks like it flows fine, but the Pure One or Motorcraft versions seem to be packed a bit too tightly. That assembly string still bothers me somewhat, but not enough to avoid these well-made filters completely. My ‘88 Shadow ES (as of 2/24/99) has a Purolator Premium Plus in it right now. I plan to cut it open and see how it holds up at the next oil change.
    I don’t care for the Champion filters. The filter elements are way too fragile to give me much confidence in them. That, along with the rusty backplates, makes me shy away from them. Some decent filter material and a little oil used during assembly would make this into a fine filter. Like the Purolator, I like how the bypass valve is built right into the filter cartridge. This filter has no internal sealing problems, either. Even so, I won’t be using them.
    The Wix filter is a very well made filter. My praise goes to Dana for putting some effort into it. Aside from being a stronger case, it also uses a much better filter element (about the same as the AC Delco). Like the AC Delco, it also has a minor internal sealing problem. In this case, the bypass valve has a metal-to-metal seal to the filter cartridge. It probably doesn’t really leak either, but if it did, dirty oil could get to the clean side of the filter. Otherwise it is a good filter. Given the choice between the Wix and the AC Delco at the same cost, I'd pick one while blind-folded. However, the Wix is about twice the price, so...
    If money is no object, I would go with the Mobil 1. Although it has Champion internals, it has a really tough synthetic fiber filter element, which is the Champion’s only major downfall. The element is stronger and thicker than the Purolator, but they claim that it flows just as good as paper. As with the other low-end Wix filters, it has no internal sealing problems. The $10 price tag is a bit steep, but it is the best filter you can buy retail. Watch for “Mobil 1 Oil Change” sales, which includes 5 quarts of Mobil 1 synthetic oil and a Mobil 1 filter. Granted, there are probably better filters available through mail order, but I haven't tested those yet...
    I reserve the right to change my opinion at any time. It could easily change if another filter (or one of the filters I am waiting on) comes around and is better.
    It should be clear that Mopar filters are really nothing special. Unless you are trying to have a perfect restoration and need that Mopar logo, there is no reason why you should be buying Mopar oil filters. Most of them seem to currently be Purolators or Champions, but that could change at any time.
    See the AC Delco, Champion, Fram, Purolator, and Wix sections for information on how to identify these manufacturers by looking at the backplate. The tell-tale signs are always there.
    Copyright © 1996-2003 Russ W. Knize.
    TacoSuprise likes this.
  12. Nov 28, 2016 at 6:30 AM
    #732
    rcw65
    rcw65 Member
    Rick
    SC
  13. Dec 1, 2016 at 5:00 PM
    #733
    2004TacomaSR5
    Jon
    Montana
    Picked up my first OEM filter yesterday. Going to change the oil and filter Saturday and see how she stacks up! Went with the YZZD3 featured here over the YZZD1 that my truck calls for. I like the idea of a filter with more media and holding capacity since I run 7500 miles on synthetic.
  14. Jan 18, 2017 at 7:15 PM
    #734
    sy272004
    sy272004 Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    Thanks for comparing. Looks like I'm gona order Toyota filters
  15. Feb 18, 2017 at 9:40 AM
    #735
    Kevmeistah21
    Kevmeistah21 Well-Known Member
    Kevin
    Pasadena, CA
    2015 DCSB TRD SPORT 4x4
    5100/887 LR UCA HS 3-Leaf AAL's SCS Stealth 6's BFG Ko2 285/70/17
    I believe I saw a post on here saying oem tundra filters work on our 4.0 tacomas. Same quality just larger filter. Is this true?
  16. Feb 18, 2017 at 9:44 AM
    #736
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    yzzd3
  17. Apr 12, 2017 at 9:33 AM
    #737
    lennyk
    lennyk Well-Known Member
    Mountain Top, PA
    Magnetic Gray Metallic
    Nice write up - THANKS
  18. Apr 20, 2017 at 1:41 AM
    #738
    Iron Ikaika
    Iron Ikaika Well-Known Member
    Jay
    Keolu Hills
    '07 DCSB Sport
    Stock, for now.
    It looks like it's the YZZD3 for me.
  19. Apr 23, 2017 at 7:09 PM
    #739
    2004TacomaSR5
    Jon
    Montana
    The oem Tundra filter is the oem filter for the 4.0 V6. It's the YZZD3 and it or the shorter YZZD1 can be used as well, the D1 is used on the 4 cylinders and older V6's, I run the D3 on my 3.4 because I like the increased filtering capacity and being able to dump a full 6 quarts in to simplify things.
  20. Aug 10, 2017 at 8:01 AM
    #740
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
