Toyota PIDs Added HP Tuners
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HPTuners, Jun 24, 2019.
  1. Jun 24, 2019 at 3:28 PM
    HPTuners
    HPTuners [OP] Well-Known Member
    Toyota PIDs Added
    The following PIDs have been added for the Toyota Tundra 3UR-FE, 3UR-FBE and Tacoma 1GR-FE
    • MAF Voltage
    • Throttle Driver Demand
    • Throttle Desired Angle
    • Air Load
    • Air Load for Spark
    • Base Advance
    • HO-LO Interp. Spark
    • Base Final Advance
    • Base Final w/o Knock Advance
    • Knock Correction (+Adv/-Ret)
    • Knock Correction Offset
    • Knock Learn Factor
    • Cam Spark Advance
    • Cranking Advance
    For the full VCM Editor Change Log, please see the following link:
    http://www.hptuners.com/help/vcm-editor/changelog.html
    For the full VCM Scanner Change Log, please see the following link:
    https://www.hptuners.com/help/VCM-Scanner/changelog.html
    For more information, and to view the latest supported vehicles list, click here.
  2. Jun 24, 2019 at 3:38 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
  3. Jun 24, 2019 at 8:32 PM
    pineapplesteaktaco
    pineapplesteaktaco Active Member
    2013 Barcelona Red Tacoma
    Do you offer pretuned options for general sale or is this for tuners only? I wouldn't mind getting something to do some minor improvements to fuel consumption and power when needed.
  4. Jun 25, 2019 at 4:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  5. Jun 25, 2019 at 5:22 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  6. Jun 27, 2019 at 1:37 PM
    HPTuners
    The MPVI2 does not come with a premade tune but it is used by both professional tuners and hobbyists. With a bit of research you can read the stock file for your car and make some minor adjustments on your own. If you end up wanting a custom tune made by a professional down the road, they can use your MPVI2 interface to create that for you.
