Toyota prerunner differential oil
Discussion in 'Toyota Trucks & SUVs' started by Snoop, Oct 3, 2009.
  1. Oct 3, 2009 at 10:55 AM
    Snoop
    Snoop [OP] New Member
    Richard
    Nanaimo, BC
    2006 Pre-Runner
    I just had my 2006 Tacoma (PreRunner, 2WD) in for it's 30,000 mile service. The shop (not a dealer) said that they didn't change the gear oil in the differential because they were not sure if it is a limited-slip differential or not, and supposedly two different kinds are used. They said that I might be able to tell using the VIN. Can anyone help? I tried googling and no results, and had a quick look in here but still a little unsure.
  2. Oct 3, 2009 at 11:11 AM
    SantaCruz'n
    SantaCruz'n Well-Known Member
    Logan
    Temecula
    Saving for the 2013
    I just changed my Diff oil with 3 quarts of oil and 1 tube of LSD oil. I have a 2005 Prerunner
  3. Oct 3, 2009 at 11:22 AM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
  4. Oct 3, 2009 at 1:21 PM
    Snoop
    Richard
    Nanaimo, BC
    2006 Pre-Runner
    I've got the sticker that says C6... nothing else. Not much help there I am afraid!
  5. Oct 3, 2009 at 1:29 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    If you don't have the "LSD OIL ONLY" sticker, you should not have anything to worry about. There is always a chance that your sticker fell off, although, if you don't have a TRD Sport, chances are about 30:1 that you do not have an LSD. The only way you could have got an LSD was to have one special ordered from the port or to have had one installed your self.
    If you are really paranoid about this, go ahead and just put the LSD additive in your rear diff oil. It will no absolutely no harm to the rear in if you don't have an LSD, and if by some small stroke of luck you do have one, it will eliminate the possibility of chatter. The additive is only about 7 dollars for the rear end. (note that only the rear end has a LSD in any of the Tacoma applications)
  6. Oct 3, 2009 at 1:33 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Just look for the LSD sticker.
  7. Oct 4, 2009 at 7:04 AM
    Snoop
    Richard
    Nanaimo, BC
    2006 Pre-Runner
    You guys have all been great. I'll get that gear oil changed today!
  8. Feb 7, 2010 at 2:27 AM
    Got Tacoma
    Got Tacoma Well-Known Member
    Gila
    Arizona
    2010 Dbl. Cab Sb 4 x 4 Trd
    Undercover Tonneau, Roof Rack, ABR Bumper, Warn 9.5xp, OME 886, Dakar leaf springs, Bilstein 5100 Struts and shocks
    Jack up the rear of the truck making sure both tires are off the ground. With the truck in neutral and the parking brake released using your hands rotate one tire in the forward direction. If the other tire rotates in the opposite direction then you have an open differential. If both tires rotate in the same direction then you have a limited slip or posi rear differential.
