Toyota Refuses To Replace My Frame
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyotaRacingDev, Dec 11, 2018.
Will Toyota Do Frame Replacement
  1. No
    8 vote(s)
    25.0%
  2. Keep dreaming
    24 vote(s)
    75.0%
  1. Dec 12, 2018 at 3:10 PM
    #101
    Markcal
    Markcal Well-Known Member
    Yeah, Canada doesn't have the same warranty as the USA.
  2. Dec 12, 2018 at 3:16 PM
    #102
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    That's awesome. Like I said, he heard from the horses mouth he was good for 15 years from ISD.
  3. Dec 12, 2018 at 4:09 PM
    #103
    JRVfromDVT
    JRVfromDVT Well-Known Member
    Southern Vermont
    2006 Tacoma Access Cab
    He did own a 1st gen prior to getting his 2010 DC. That truck had the frame replaced a month or two before he traded it in. He was anticipating having til 2022 to get the frame replaced. Seems like Toyota had different plans
  4. Dec 13, 2018 at 5:10 AM
    #104
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    There fact that any vehicle has a rusting frame past the year 1990, and even more so past the year 2000 is just pathetic honestly. Such an archaic easy to fix problem
  5. Dec 13, 2018 at 5:13 AM
    #105
    Itchyfeet
    Itchyfeet Well-Known Member
    Boatbldr likes this.
  6. Dec 13, 2018 at 11:44 AM
    #106
    96carboard
    96carboard Well-Known Member
    Not accurate.
    Failing to maintain a frame (regardless of choice in undercoating) will destroy it.
    Applying something like a rubberized undercoating (or paint, or basically anything besides just plain old OIL) to a frame that is *ALREADY RUSTED* can make things worse.
  7. Dec 13, 2018 at 11:49 AM
    #107
    96carboard
    Its actually worse than it used to be.
    And by that I do NOT mean that cars rust worse than they used to, but rather that the environment is a heck of a lot more HOSTILE than it used to be.
    Salt didn't used to be as prevalent as it is now. Now, they just dump a billion tons of salt ever 10 feet on every road you ever drive on. Used to be that they were smart enough to use this other stuff called SAND on a lot of roads (not all, but lots more than they use now), which would get you lots of traction, without murdering metal. They also have this sticky saline slime that they spread on roads out of tanks now that they didn't used to use. That stuff is REALLY horrible.
    And on top of that, if cars didn't rust out, how would they keep selling more of them? Obviously if you want to add 30 years to a car's life, you just have to galvanize the thing.
  8. Dec 13, 2018 at 11:52 AM
    #108
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    Aaaand that dealer was? Feel free to PM me the info. Not far from you and soon to be ready for a frame inspection .
    lynyrd3[QUOTED] likes this.
  9. Dec 13, 2018 at 12:08 PM
    #109
    lynyrd3
    Bill
    East Central Upstate NY
    Well I bought my Tacoma new at Johnston’s in New Hampton ( Middletown) but I live in Columbia county so Kinderhook Toyota is the local dealer that passed it . 6-10 months later I made an appointment for the driveshaft /u joint TSB at Johnston’s and sure enough they said I needed my frame inspection. So I said :yes: and sure enough they found a hole that was so obvious I don’t know how I didn’t see it !
    pmstoy10[QUOTED] likes this.
  10. Dec 13, 2018 at 12:12 PM
    #110
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    As with most things in life, its not as simple as you think it is.
    What exactly is this easy fix you speak of?
    blu92in99 likes this.
  11. Dec 13, 2018 at 12:13 PM
    #111
    TacomaMike37
    13' DCLB MGM
    How exactly do you weld a galvanized frame without poisoning yourself?
  12. Dec 13, 2018 at 12:14 PM
    #112
    96carboard
    Make the vehicle out of 100% marine grade stainless steel.
  13. Dec 13, 2018 at 12:14 PM
    #113
    96carboard
    How what?
  14. Dec 13, 2018 at 12:15 PM
    #114
    96carboard
    Why would you want to weld a galvanized frame?
  15. Dec 13, 2018 at 12:16 PM
    #115
    TacomaMike37
    13' DCLB MGM
    Crawl under your truck and count the number of welds to the frame
  16. Dec 13, 2018 at 12:16 PM
    #116
    TacomaMike37
    13' DCLB MGM
    Yeah cause that is financially feasible.
    lynyrd3 likes this.
  17. Dec 13, 2018 at 12:19 PM
    #117
    Hunter4950
    Hunter4950 Well-Known Member
    Cant argue with that guy he thinks hes Einstein
  18. Dec 13, 2018 at 12:20 PM
    #118
    96carboard
    Are you under the mistaken impression that you would have to galvanize the frame BEFORE it is welded? That would be really silly, and quite ineffective, since the welded areas would not be protected. You would build the frame out of steel, COMPLETE, and THEN galvanize it.
    You're mistaking "value" with "cost".
  19. Dec 13, 2018 at 12:24 PM
    #119
    Hunter4950
    Genius!
    lynyrd3 likes this.
  20. Dec 13, 2018 at 12:26 PM
    #120
    lynyrd3
    Bill
    :spending::spending::spending:
