Toyota screwed me - now what?
Discussion in 'Audio & Video' started by surf_taco_233, Mar 22, 2021.
  1. Mar 22, 2021 at 11:07 PM
    surf_taco_233
    surf_taco_233 [OP] Skrrrrr
    California
    2019 DCSB Cement
    Hey team - I’ve been completely abandoned by Toyota and need advice. Thank you all in advance!
    I bought a 2019 Tacoma Sr5 DCSB brand new in may 2019 and the entune Bluetooth calling feature stopped working about 3 months in. Whenever I’m on the phone, a call drops about 1 minute in. Doesn’t matter if it’s inbound or outbound and It’s not just my phone (iPhone XR) as I’ve tried with multiple other apple devices and none work.
    I’ve gone in to service centers for 4 separate visits, and they all could not fix the problem.
    Recently it was escalated to Toyota corporate and after two calls with a case manager and her superior they both said there is nothing we can do. They said that because the system works on an android device (but no iPhones) that it’s technically not a defective head unit and is not a breach of warranty. They said I can contact the BBB and review my local lemon laws if I want.
    I feel totally cheated on my purchase and if I were to resell the truck, I’d probably take a $5k hit on the resale price for a nonfunctional Bluetooth considering just about everyone has an iPhone.
    What can I do??
    TLDR; my entune Bluetooth never worked and Toyota said I’m basically screwed, even though my truck is under warranty.
  2. Mar 22, 2021 at 11:21 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I know this is probably not the answer you are looking for
    But a new aftermarket head unit would be far less expensive than selling the truck at a $5k loss?
  3. Mar 22, 2021 at 11:34 PM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    We talking about Bluetooth? Man we talking about Bluetooth?? Get rid of the smart phone
    before you get rid of the Tacoma. :anonymous:
  4. Mar 22, 2021 at 11:35 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    I think he's talking about bluetooth
    Hobbs likes this.
  5. Mar 22, 2021 at 11:36 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    BBB is worthless... Hopefully your state has a bureau of automotive repair.
    GarlicFarts likes this.
  6. Mar 22, 2021 at 11:51 PM
    surf_taco_233
    California
    2019 DCSB Cement
    Not actually selling the truck fellas - it’s the PRINCIPLE
    Man of Steel TRD likes this.
  7. Mar 22, 2021 at 11:54 PM
    Gyres01
    Gyres01 Well-Known Member
    Todd
    Bastrop, TX
    19' Silver TRD Sport
    Sucks they strung you along but yeah replace that HU with a bigger screen...
    Thunder Fist and TnShooter like this.
  8. Mar 23, 2021 at 1:01 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    So the real question is does bluetooth work on most other Tacomas same year. If yes Toyota needs to replace the unit simple. If answer was yes then tell Toyota you will be filing a NTSB case and doing this in a set time like 10 days and if they want you to not file this they need to replace your unit. If all Tacomas have intermittent bluetooth then file away and make Toyota response and have to fix everyones. You have to accept they are a large corporation and the bottom cost is all that matters and accept this problem as a challenge and in fact a game to play - then if all fails replace with aftermarket.
    wi_taco likes this.
  9. Mar 23, 2021 at 3:21 AM
    Tacoma Mike
    Southern Maine
    Have they checked for software updates?
    Updates are very common.
    If not
    get the radio number off the face plate.
    Very small usually on the rt lower side.
    I’ll check sometime today at work
  10. Mar 23, 2021 at 3:28 AM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
  11. Mar 23, 2021 at 3:30 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Does your bluetooth work fine for streaming music?
  12. Mar 23, 2021 at 6:11 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    It’s possible it’s an apple issue also. I have crapple to and I use bt headphones and also the watch to control my music and books. I work outside so sometimes digging my phone out to check messages or skip songs is a pita. The last couple of months I have had constant connectivity problems so your problem may not be your truck.
  13. Mar 23, 2021 at 6:22 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    So the head unit isn't working for a phone that isn't supported? Or is it not working at all?
  14. Mar 23, 2021 at 6:50 AM
    2017_TACOMA_LIMITED
    2017_TACOMA_LIMITED Well-Known Member
    2019 Pro/2017 Limited/2014 Limited
    My wife and I both have iPhones. Zero problems using bluetooth to connect to the truck to talk on the phone. Zero problems with her 2014 Limited, or the 2017 Limited I had, or 2019 Pro I have. We've used the iPhone X and now 12.
  15. Mar 23, 2021 at 7:00 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Good thing that your phone isn't also your vehicle key.
  16. Mar 23, 2021 at 9:57 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    FWIW. Not everyone has Apple phones.
    Frankly, I'd either change to an Android platform or replace the HU with an aftermarket.
    Be aware. Apple is known for quirks in their op systems that limit functionality.
    Aqualoon likes this.
  17. Mar 23, 2021 at 10:12 AM
    ThaiChillyTaco
    David
    There are people who still buy Androids?
  18. Mar 23, 2021 at 10:27 AM
    TX BAJA1
    TX BAJA1 Well-Known Member
    2021 LUNAR ROCK TRD PRO
    Toyota regularly updates the software on their head units for this type of issue. I'd frequently check with your dealer. It's frustrating and something Toyota has struggled with for the last few years.
    wi_taco likes this.
  19. Mar 29, 2021 at 1:33 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Those who don't want to be prisoner to the poison fruit do.
  20. Mar 29, 2021 at 1:49 PM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    Interesting article re: market share-
    https://www.mobileapps.com/blog/android-vs-ios-market-share
    Globally, Android dominates with almost 72% of the market, and rising.
    In the US, iPhone leads but it's only a 60%-40% split.
    MoneyMan55 likes this.
