Toyota Silicone question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lentsnh, Oct 26, 2009.
  1. Oct 26, 2009 at 11:01 AM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    I did the BHLM and I got alittle bit of the Toyota Silicone on the HL lense. Whats the best way to get it off?
  2. Oct 26, 2009 at 11:12 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i used wd-40 to clean mine when i did them.
  3. Oct 26, 2009 at 11:15 AM
    Lentsnh
    Will that get it off the silicone? Its been on for about 2 days
  4. Oct 26, 2009 at 11:18 AM
    paintdiddy
    shithead
    silver bullet
    it did for mine after i baked them back together. i would assume most household products would damage the lense. get a soft rag and use it with the wd-40. a nice long finger nail helped me out too.
  5. Oct 26, 2009 at 11:22 AM
    Lentsnh
    I tried rubbing alcohol and the plastic-X stuff.
    Ill try WD-40 today
  6. Oct 26, 2009 at 11:26 AM
    paintdiddy
    shithead
    silver bullet
    post pics of what it looks like. mine didnt have an overkill amount on them but enough to notice i screwed up.
  7. Oct 26, 2009 at 11:40 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Goo-gone
  8. Oct 26, 2009 at 11:58 AM
    TacoMOnster07
    TacoMOnster07 Well-Known Member
    Pennsylvania
    07 DC 6speed 4x4 BSP Sr5
    BHLM, Grillcraft, Urd SS, Urd TCAI, Urd MAF Calibrator, AeroTurbine Exhaust, TacoTune Single Din, Two 8" Infinity Subs, 12-13000 HID's, Xtreme Bedrack light bar with two KC 4 by 6 lights.
    If it's the gray caulk that seals the lens to the housing try heating it up again and wipe off as much as you can, then use cleaning solvents.
  9. Oct 26, 2009 at 1:21 PM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Isnt the light plastic? I would go easy on the solvents as it could etch the plastic. Try heating/scraping it off with a plastic squeegee first.
  10. Oct 26, 2009 at 7:29 PM
    Lentsnh
    Yeah thats what it is... The gray silicone. It got on the gloves with out me knowing before it was too late..
    Can I use a razor blade?
  11. Oct 27, 2009 at 12:09 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Do NOT use a razor blade on plastic. Just use Goo Gone and your finger nail. It's not silicone BTW.
  12. Oct 27, 2009 at 5:45 PM
    Lentsnh
    Ok thanks. And what is it?
  13. Oct 28, 2009 at 7:00 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Automotive butyl tape... Wasn't that your second choice all along :)
  14. Oct 28, 2009 at 9:19 AM
    Lentsnh
    Nope not really:p
  15. Oct 28, 2009 at 9:22 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    Its butyl tape. Just pick it off. Butyl tape stays. It doesnt cure or harden. It stays the same as it was when it was put on. Just pick it off with your finger nail.
