Toyota Tacoma 3.4L K-Line ECU Reflash interest
Discussion in '1st Gen. Tacomas (1995-2004)' started by OVTune, Jul 25, 2017.
  1. Nov 28, 2018 at 12:52 PM
    #181
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    @OVTune @livel0veryde - because I'm paranoid, should I do anything besides disconnect the battery before removing my ECU?
    opteron likes this.
  2. Nov 28, 2018 at 2:14 PM
    #182
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Is this only for the 3.4 ecus? Or will 03-04 2.7 work as well?
  3. Nov 28, 2018 at 2:16 PM
    #183
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Good question, wanna open your ECU and take a pic or two?
    Reh5108[QUOTED] likes this.
  4. Nov 28, 2018 at 2:20 PM
    #184
    Reh5108
    Idaho
    I suppose I could ...
    Speedytech7[QUOTED] likes this.
  5. Nov 28, 2018 at 2:36 PM
    #185
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Do you have ECTS or whatever the E-throttle/ part E-throttle is called?
  6. Nov 28, 2018 at 2:39 PM
    #186
    Reh5108
    Idaho
    I'm guessing no. Not sure what any of that is.
  7. Nov 28, 2018 at 2:42 PM
    #187
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    It will have a larger plug and electric motor on the TB.
    Kinda like this I ASSume.
  8. Nov 28, 2018 at 5:37 PM
    #188
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Another way to be sure is to turn the key to on but don’t turn the engine on and pop the hood. Turn the throttle by hand at the throttle body and you should hear a click and an electronic motor inside it actuating the throttle plate.
  9. Nov 28, 2018 at 6:18 PM
    #189
    Reh5108
    Idaho
    No, it's cable actuated
  10. Nov 28, 2018 at 6:20 PM
    #190
    Shortman5
    Supercharged TRD
    It would still have a cable. The 03-04 3.4l does. The cable is supposedly for limp mode if your TB goes out.
  11. Nov 29, 2018 at 12:31 PM
    #191
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Yes but in 99+ the wideband o2 is only on the two cat version, if I ran a wideband upstream on my truck it wouldn’t run right 99+00 has a fed edition with only single cat and simple o2 upstream.
  12. Nov 29, 2018 at 12:35 PM
    #192
    Luv my yota
    00 turd lift 33's
    Its legal in a sense as long as you don’t tell the smog center they can’t see anything you did to tune it anyway.
  13. Nov 29, 2018 at 12:42 PM
    #193
    Luv my yota
    00 turd lift 33's
    Yah Gadget seems bored with the 5VZFE since he’s gotten to 500 hp, and now doesn’t play much with first gens mainly xrunners. LCE has done 500hp na for real call em’.
    cali04intx likes this.
  14. Nov 29, 2018 at 3:17 PM
    #194
    1Fine40
    1Fine40 Well-Known Member
    Rich
    Great Northwest
    04' Ex.Cab TRD
    Grey wire, deck plate, 2-Lo, Toytec front, All-Pro rear, 4.88's (Hi rpms!)
    LCE has done 500hp na for real call em’." I would be real skeptical about that....especially the NA part? Did LCE drop in a small block chevy mill?? Then I could see it :thumbsup:..
    Maybe I need to go read the LCE lit and see what they do?? Won't be cheap that is for sure...HP never is!:burnrubber:
  15. Nov 29, 2018 at 4:37 PM
    #195
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah I have a set of heads ready to port and polish after my jalopy is running. That seemed to have a good deal of how that HP was made.
  16. Nov 29, 2018 at 11:35 PM
    #196
    Luv my yota
    00 turd lift 33's
    When I heard what was done to get that 500hp engine there mechanically, well, I shit a Nike!, and when it gets to that hp the stock ecu is rubbish. Could’ve had it for 5k, I still kick myself, but for a daily driver in Ca, smog centers wouldn’t dig a stand-alone or all the visual smog stuff removed permanently. Could have stuffed it up my friends ass with a 15’ 454 SS camaro, maybe, not really. Probably wind up flipping into a barrel roll with that kinda power on a 3” lift on 33” tires, I’d love to watch it though.
    Rocan likes this.
  17. Nov 30, 2018 at 6:19 AM
    #197
    Shortman5
    Supercharged TRD
    Where did you hear that? I can’t seem to find any definitive source of what needs to be done (and what dosent) to get 500hp. Or even 400 for that matter.
  18. Nov 30, 2018 at 7:01 AM
    #198
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    To more than double the output of any engine without forced induction another method of moving more air through it will have to be found.
  19. Nov 30, 2018 at 8:46 AM
    #199
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Some info on the 5VZ based napcar engines.
    Dalandser[QUOTED] and JasonLee like this.
  20. Nov 30, 2018 at 9:27 AM
    #200
    JasonLee
    15 TRD OffRoad
    Anyone? Tomorrow is the day I pull out my ECU for some photos (and fix my dash rattle).
