Toyota Tacoma 3.4L K-Line ECU Reflash interest
Discussion in '1st Gen. Tacomas (1995-2004)' started by OVTune, Jul 25, 2017.
  1. Jun 7, 2019 at 6:27 PM
    #281
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    StAndrew, You can't just make a "canned" tune for forced induction. At what boost? The 5VZ injectors are not able to handle much more than 5-6 psi from the TRD blower. If you replace the injectors, that tune is shit.
    They could/can make a canned tune. Hypertech has been doing it for years along with several others ( Banks, Bully Dog )that have them for the diesel market. Having a MAF, MAF and knock sensors make it possible. The 5vz fuel injectors would be able to supply the fuel necessary for a SC if we could adjust the Pulse Width Modulation. Longer they are open.....the more fuel is added to support the increased air volume of a SC.
    Even if you tune for a stock engine with a stock TRD blower, basically you have to tune so conservatively, its just going to be a massive fuel dump into the engine to make sure you don't experience pre detonation.
    If we were able to tune/calibrate the fuel tables we could turn the massive fuel dump in to a gradual fuel increase based off of the MAF and MAP sensors and be able to keep everything safe and together by monitoring the Knock Retard the engine produces.
    If I'm going to pay for a tune, I'd spend the extra $150 for a standalone. OVTune can invest in whatever they want but I'm not sure what they hope to gain unless they do what URD does with the 2nd gen and make a performance kit that compliments the tune.
    Have you ever heard of HPTuners? Just by a simple tune, a automobile can have more power and get better fuel economy. The OEM tune is tuned for emissions, and engine longevity. Ever seen how many safeties are in a modern day Ford F150 ECM? Part failure or human error is the only way to blow a engine.
    The 5vz has intake runners a mile long and 2 1/4" exhaust. Its choking on itself at around 3500 RPMs. Everything about the engine design, things that can't be tuned, is for low end torque. Unless OVtune replaces the intake runners, Throttle body, injectors, and exhaust, its not worth tuning.
    Being able to advance and retard the timing, adjust injector PWM, and fuel tables, we could take full advantage of the mile long intake runners. The 2 1/4 diameter exhaust isn't the problem, the stock muffler and exhaust manifolds are. Very restrictive. Put on a free flowing muffler like a MagnaFlow and get some decent quality headers...problem solved.
    The 5VZ was designed in the 90's and wasn't tuned for emissions. It was designed for low end power. Without cam timing adjustment, variable intake runners, port and direct injectors, and variable exhaust flow profiles, engine tuning is pretty much all mechanical until it comes to adding fuel. Then its just a simple math problem to calculate air flow and fuel flow that makes a 14.7 AFR. They only exception is engine timing but if you think you can find a safe timing advance that works for all 5VZ's, get ready for a class action lawsuit when people start blowing engines.
    Every fuel injection engine is designed with emissions in mind with power and longevity as a after thought. Hence why your engine and all fuel injection engines rev to mid level RPMs when cold to heat up the catalytic convertors and O2 sensors to expedite getting to closed loop ( O2 sensor fuel control ). The O2 sensors on a fuel injection system are designed to tell the ECM precisely how much fuel to add to the engine, unlike a carburated engine which dumps fuel strictly based off of intake vacuum.
    The fuel tables are quite complicated and are far from a simple math problem. All the sensors on the engine determine how and when fuel is needed when certain parameters are met. Many fuel tables are based off of MAF( volume ) and MAP ( engine load )sensors with the O2 sensors keeping everything within 14.7 for non-ethanol fuel and 14.2 for 10% ethanol. With knock sensors and rev limiters keeping the engine from destroying itself.
    Modern fuel injected engines have Knock Sensors that retard the timing when knock/ping is detected. When people disable, disconnect or ignore them is when they get start disintegrating piston rings lands and breaking shit.
    Adjusting the timing would allow us supercharged guys to tune our engines to stay out of KR which in turn would increase power, fuel economy and longevity.
    DesertRatliff and JasonLee like this.
  2. Jun 7, 2019 at 6:38 PM
    #282
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    @OVTune just curious, but did you see my post about the ECU chip? It's all good if its not compatible, I figure it wont be, but I thought it wouldn't hurt to ask :D
  3. Jun 7, 2019 at 6:47 PM
    #283
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Unfortunately can't.
    It likely *is* flushable through k line, but getting the Rom off the controller is borderline impossible.
    And believe me I want to do those damn things because the older tundras want it
    Brice[QUOTED] likes this.
  4. Jun 7, 2019 at 7:03 PM
    #284
    Brice
    Brice Turbo Member
    Brice
    Texas
    To be honest I have no clue how breaking into an ECU works. I can kinda tune stuff, but I'm definitely interested in this whole thing. Maybe enough so to swap over to 03-04 stuff. But is there anyway I could mess around with my 99 ecu? Like any resources you might could point me towards? If not, no worries.
  5. Jun 7, 2019 at 7:29 PM
    #285
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Well if you want to start a list put me on it. I need to do something. I feel like the ECU is constantly fighting the 7th injector tune. That and I don’t think the transmission likes the 33s and 9psi of boost very much.
  6. Jun 8, 2019 at 1:07 AM
    #286
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I'm sure you could improve throttle response. The electronic throttle body can be quite slow at opening.
  7. Jun 8, 2019 at 2:43 AM
    #287
    CD20H
    Ben
    North Texas
    04 Tacoma here. I will take a copy. Suggestion for any scanning software?
  8. Jun 8, 2019 at 2:09 PM
    #288
    Brice
    Brice Turbo Member
    Brice
    Texas
  9. Jun 16, 2019 at 10:41 AM
    #289
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Bumping here, @OVTune - I sent an email and DM on here.. No word back. I'm headed to my friends place in Oregon in a few weeks and want to do some tuning with him. If we can make this happen (cable + software), I'm in for providing feedback with a confirmed compatible ECU.
  10. Jun 16, 2019 at 12:32 PM
    #290
    mechanicjon
    Jon
    Scottsdale Arizona
    The icing on the cake would be the ability to make a auto trans ecu a manual one. The 03-04 4x4 manual trans computers are scarce and pricey.
  11. Jun 17, 2019 at 4:23 AM
    #291
    OVTune
    OVTune
    We will get back to everyone who inquired via email as soon as possible
    cali04intx likes this.
  12. Jun 17, 2019 at 2:45 PM
    #292
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Unfortunately it doesn't look like the 04 2.7's are tune-able :(
  13. Jun 18, 2019 at 12:47 PM
    #293
    Shortman5
    Supercharged TRD
    Anyone that has a TRD supercharger with an automatic transmission has heard of high gear low RPM ping. I honestly believe it has a lot more do do with the torque converter lock up than the overdrive gear.
    When ECT is off the TC really wants to stay on when accelerating over 45MPH, which is where it engages. But when ECT power is on it disengages with much less load. That why I typically have ECT when driving interstates and highways.
    It would be great if this gives us the ability to change the lockup behavior when ECT is off. A custom map that involves ECT would be great too. I’d like to be able to cruise around town without the transmission wanting hold lower gears but also have it hold lower gears when getting on it at the same time.
    I really do think that what holds this engine back with boost is the Auto transmission.
    @OVTune would that sort of thing be possible?
    What about a “copy and paste” 2JZ-GTE A340E tune to this ECU? Maybe that map is better suited for power and comfort.
    Brice likes this.
  14. Jun 21, 2019 at 9:15 AM
    #294
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    hmm older tundras. 05-06 i assume are tuneable? when mines put back together id be all for a tune on that sob..
  15. Aug 3, 2019 at 11:13 AM
    #295
    JasonLee
    15 TRD OffRoad
    Another bump here for @OVTune . I haven't heard back from my last email - I'm ready to buy the cable from you and download the software and start tuning.
    CD20H likes this.
  16. Aug 4, 2019 at 9:18 AM
    #296
    Shortman5
    Supercharged TRD
  17. Aug 4, 2019 at 12:41 PM
    #297
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    The issue is more complicated than that. It's not just the high load on the engine due to the high gear, but also the closed loop tuning. A proper ECU tune fixes it with proper timing and fuel trims.
  18. Aug 29, 2019 at 3:47 PM
    #298
    Shortman5
    Supercharged TRD
  19. Aug 29, 2019 at 3:50 PM
    #299
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Weeeeeeeeeeeeeeee
  20. Sep 5, 2019 at 3:11 PM
    #300
    OVTune
    OVTune
    Confirmed supported ECU IDs:
    89663-04031
    89663-04041
    89663-35121
    89663-05131
    and a few ECUs are for the old 2.7L
