Toyota Tacoma 3.4L K-Line ECU Reflash interest
Discussion in '1st Gen. Tacomas (1995-2004)' started by OVTune, Jul 25, 2017.
  1. Jul 25, 2017 at 10:47 PM
    digitalferg
    digitalferg Well-Known Member
    Southern Utah
    2006 1G Tundra DC TRD 4x4
    Pretty much ditto this for me. I'm in an '03 Tacoma with 5vz, SC and a TRD 7th kit.
    Definitely interested in hearing about what you can do @OVTune .
  2. Jul 26, 2017 at 8:17 AM
    Glamisman
    Glamisman Well-Known Member
    I would be interested in a re-flash. I have an 03 reg cab 4cyl basic stripper for use in Baja and the fuel there is so bad that the CEL is on constantly. I wonder if there is a "Mexico" as opposed to the USA - California flash for the ECU.
    otis24 and Dalandser like this.
  3. Jul 26, 2017 at 10:01 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    i think he is looking at 3.4's only...
  4. Jul 26, 2017 at 10:13 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  5. Jul 26, 2017 at 10:21 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I'm pretty sure the 4cyl never changed in Gen 1 aside from minor improvements. Only the V6 went to computer assisted throttle/cruise.
    sub'd for info for my '04 3.4 :D
  6. Jul 26, 2017 at 11:28 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    why would earlier years not be possible?
  7. Jul 26, 2017 at 11:54 AM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Could be wrong but maybe something to do with the drive by cable trannies up until 03-04.
  8. Jul 26, 2017 at 11:55 AM
    TashcomerTexas
    I believe he can control the fuel maps, possibly shift points and other various maps.
  9. Jul 26, 2017 at 1:00 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    Only thing I know of there is no "kick-down" cable for the 03-04 trans like that on earlier >'02s. So this might have something to do with it :notsure:
  10. Jul 26, 2017 at 1:02 PM
    TashcomerTexas
    Right. That's what I meant.
    The 03-04 transmission is controlled via drive by wire, or electronically. This makes sense therefore it is "hackable" and can be set to however the controller wants.
    The 95-02 transmissions are controlled via drive by cable so it's more manual - not something that can be adjusted through a controller.
  11. Jul 26, 2017 at 1:16 PM
    CanadaToy
    Greg
    Toronto
    Actually it changed more than the 3.4 !
    Original's actually had a distributor! Then they went thru 2 different coil plug variations. they also have 4 port and 8 port heads / intake manifolds. Definitely a bit of a :crapstorm: :)
    frizzman[QUOTED] likes this.
  12. Jul 26, 2017 at 1:25 PM
    TashcomerTexas
    Possible 3.4 mods based on the 4.0 and 3.5:
    Please don't forget the 3.4 has ECT too! I'm drooling at the possibilities over here.
    You also stated you can correct for bigger tires :fingerscrossed:
    Also waiting to hear what you can do about a supercharged w/ URD 7th injector tune and if they can coincide.
  13. Jul 26, 2017 at 1:27 PM
    TashcomerTexas
  14. Jul 26, 2017 at 1:36 PM
    tony2018
    tony2018 Well-Known Member
    Potential future turbo member, or supercharge.
  15. Jul 26, 2017 at 4:55 PM
    #35
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well my blower is going on my 03 when the v8 goes in frank.
    But I don't think you can do anything to our ecus. Nothing substantial anyways.
  16. Jul 26, 2017 at 5:07 PM
    #36
    TashcomerTexas
    Without having to swap a tranny I think there's a few options that could benefit an auto 5vz. I'll be optimistic considering he can crack a 4.0.
  17. Jul 26, 2017 at 5:25 PM
    #37
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    aww. looks like im still going to have to go piggy back =/
  18. Jul 27, 2017 at 9:04 AM
    #38
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    The trans cable is not a kick down cable. The trans is electronically controlled, hence "ETC". The transmission has a PWR mode which electronically changes the shift points in the trans ECU. The cable is ONLY for line pressure. You can pull it all the way back and tie it off and you'll notice very firm shifts. It does NOT change the kickdown point.
    Brice and devinzz1 like this.
  19. Jul 27, 2017 at 9:05 AM
    #39
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    What happened to you, OP? Why only 03/04?
  20. Jul 27, 2017 at 9:59 AM
    #40
    CanadaToy
    Greg
    Toronto
    It's been 1.5 days since his last message... jesus.
    JasonLee likes this.
