Toyota Techs don't f**ck around!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by piff, Mar 8, 2021.
  1. Mar 9, 2021 at 8:41 AM
    #41
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    The drain plug thing on the bottom of mine is hopelessly stuck so I just put an extension in there and unscrew the whole thing that way.
  2. Mar 9, 2021 at 8:43 AM
    #42
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    I always hand tighten mine and on my last oil change I broke 5 FIVE!!! Different tools. Ended up taking a dremel and cutting the plastic housing off. Replacing with a metal one.
    piff[OP] likes this.
  3. Mar 9, 2021 at 8:50 AM
    #43
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Seems to me having Al on Al would be more of a recipe for stuck-ness than plastic.
    The housing is sealed by an Oring. Once the oring is fully engaged there's no reason to apply more torque to the housing. I'm 80k miles into my truck and have applied zero ft lbs of torque to it.
  4. Mar 9, 2021 at 8:54 AM
    #44
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    They "changed" mine for free at the 20K mile service. I went to put my receipt into the glovebox and noticed that nothing in there was moved. Pulled the filter and sure enough they didn't touch it. Drove back and they said it was mistake and changed it in front of me.
    Sounds more like fraud than a mistake but what do I know?
  5. Mar 9, 2021 at 9:00 AM
    #45
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    These aren’t the mechanics that are changing the oil, it’s the kid making $8 an hour.
    shakerhood and Grossomotto like this.
  6. Mar 9, 2021 at 10:01 AM
    #46
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    How many out there do not even know there is a filter inside of their vehicle. I've seen some nasty filters in 10-15 year old vehicles that have the filter that they came with from the factory...
    shakerhood, FLA_Hoosier and tonered like this.
  7. Mar 9, 2021 at 10:02 AM
    #47
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    i have a meme for this somewhere
    tonered likes this.
  8. Mar 9, 2021 at 10:14 AM
    #48
    coopcooper
    alberta canada
  9. Mar 9, 2021 at 10:39 AM
    #49
    FLA_Hoosier
    FLA_Hoosier Well-Known Member
    Rick
    Space Coast
    2017 White TRD Sport AC
    I just change my cabin & air filters before I go in. Stops any argument before it can even start.
    shakerhood and piff[QUOTED][OP] like this.
  10. Mar 11, 2021 at 4:20 PM
    #50
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    LOL ! I'm 6' 5" and big! Every time I pick up my car - I get in - and immediately get my knees in my face !!!!
    gillies66[QUOTED] likes this.
  11. Mar 11, 2021 at 5:11 PM
    #51
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    It's not just our tacos with stuck filter housings, a lot do this. I have more trouble with aluminum housings on yotas. If the engine isn't warm I heat them up before loosening. I see no point getting aluminum housing.
    FYI I have busted the filter wrenches that have the recess for 1/2" drive. The solid filter wrench without 1/2" drive, regular hex, are more durable
    tonered likes this.
  12. Mar 11, 2021 at 8:49 PM
    #52
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    I broke the filter housing on my wife’s RAV4 cause it was too tight. On my 03 with regular oil filter I make sure I don’t over tighten them, but next oil change it is tighter than what I had tightened it.
  13. Mar 12, 2021 at 2:42 AM
    #53
    Vmax540
    Chuck
    Clarion PA.
    Which grips more two smooth pieces of metal sliding together or one piece of smooth aluminum and one piece of plastic ?
  14. Mar 12, 2021 at 4:39 AM
    #54
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    The question assumes the issue is due to the threads of the canister, and nothing else.
  15. Mar 12, 2021 at 5:16 AM
    #55
    Vmax540
    Chuck
    Clarion PA.
    Both the aftermarket aluminum housing and the plastic/composite housing would have a rubber seal. With both torqued the same I would expect the plastic/composite housing to hold on stronger ?
  16. Mar 12, 2021 at 5:47 AM
    #56
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    This is my single greatest fear in taking my truck to a shop, especially with the electric seat with no memory settings. I'm super fussy about driving position and it will be a pain in the ass to get it back to how I want it.
  17. Mar 12, 2021 at 5:51 AM
    #57
    golfindia
    Yes.
    pickup truck
    Aluminum forms an oxide layer when exposed to atmosphere. Two oxide layers in contact with each other make a bigger oxide layer and more friction.
    A threaded Al to AL junction is sub optimal. Drive through some water, water dries in housing threads, or around outside more corrosion...... Plastic doesn't oxidize.
  18. Mar 12, 2021 at 6:06 AM
    #58
    Barrister
    Barrister Well-Known Member
    Dennis
    Mesa, Arizona
    2023 TRD Pro, Solar Octane, 6 speed Manual
    Predator Steps, OEM Tonneau
    I like my electric seat, but one advantage of the manual seat is that you are more likely to find the same “notch” you were in than the same spot on the rail with an infinitely adjustable electric mechanism.
    gillies66 likes this.
  19. Mar 12, 2021 at 6:09 AM
    #59
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
  20. Mar 12, 2021 at 5:12 PM
    #60
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    I was at the local dealer today getting parts, there was a tech in line behind me with oil filter socket broken just like OPs. He said it happens ever so often, didn't think to ask if he was using an impact. I assume the housing was fine since he only had the tool in his hand.
