Toyota tool
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Goldwrench, Dec 13, 2021.
  1. Dec 13, 2021 at 5:13 PM
    Goldwrench
    Goldwrench [OP] Well-Known Member
    2010 silver 4wd access taco
    Bought used and mild lift
    Anyone know what tool Toyota techs use to install mini roller bearing in front differential, that doesn’t knockout mini roller bearings. We hammer in ecgs bushing, but, can you hammer in factory bearing without losing rollers? I would think they have an installation tool similar to the inner cv axle. That would certainly prevent loss of the rollers.
  2. Dec 13, 2021 at 5:14 PM
    Bishop84
    Bishop84 Well-Known Member
    I use a standard bearing installer tool. No different than any other bearing. You chose a flat surface larger than the race and hammer it flush.
    TnShooter and blu92in99 like this.
  3. Dec 13, 2021 at 5:39 PM
    Waasheem
    Waasheem
    2007 xrunner
  4. Dec 13, 2021 at 6:35 PM
    Goldwrench
    Bishop 84 & Waasheem, thanks for reply. I do have the aluminum bearing install tools shown, but, just curious. Seems you should use something that fits in bore to keep those rollers from popping out if you don’t hammer in straight. Ty.
  5. Dec 13, 2021 at 6:55 PM
    Bishop84
    They are nearly impossible to break, there is no special tool (I'm a toyota tech) The TSB even references a standard bearing installer tool.
    TnShooter likes this.
  6. Dec 13, 2021 at 6:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The rollers just don’t fall out like a U-joint cap.
    I think the cage helps keep them in.
  7. Dec 14, 2021 at 8:02 AM
    Goldwrench
    Thank you gentlemen. Learned something. Appreciate it.
