Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Mar 9, 2021 at 4:03 PM
    #581
    branden21
    branden21 Active Member
    2021 Barcelona Red Tacoma TRD Off-road
    A dealer told me today I could go 275/70/17 if I did this lift with no rubbing or anything
    TacoOggie likes this.
  2. Mar 9, 2021 at 4:20 PM
    #582
    TacoMan408
    TacoMan408 Well-Known Member
    CA
    2016 TRD Sport Manual
    OVTune (04B13+1.05 87 FOB), Morimoto XB Headlights, Toyota LED Fog Lights, Toyota TRD Lift Struts, Wheelers Progressive AAL, TRD Pro Tail Lights, 17" TRD Pro SEMA wheels, BFG 285/70R17, TRD Skid Plate, Bakflip MX4, OEM Audio +, Anytime Front Camera, G-Tek Fab Door Sill Protectors, WeatherTech Floormats Suntek Carbon 35% Tint
    There is no simple answer since there are so many factors in play. It depends on the wheel width, offset, and alignment.
    Typical wheel specs that tend to be 'non-rub friendly' are a more narrow wheel, more positive offset, and an alignment more positive caster (moves the wheel forward). There is also a middle ground here since too much positive offset like a stock wheel will not stick out far enough and rub on your UCA.
    For example: A rim like SCS that is 8.5" wide with a -10 offset is more likely to rub with the same tire than something like a TRD Pro SEMA wheel that is 7" wide with a +4 offset. The SCS is more wider, sticks out more, and is more likely to rub on the cab mount. You can try to max out the caster to move the wheel forward to give you the best chance, but with stock UCA's you can only get so much positive caster without messing up the camber.
    I suggest trying to search for other posts with a 2" lift with similar wheel specs to what you're wanting to see what the largest tire is. There are dedicated tire size threads that might help.
    https://www.tacomaworld.com/threads/official-3rd-gen-275-70r17-tire-thread.394460/page-62
  3. Mar 9, 2021 at 6:18 PM
    #583
    dragonsh8tacos
    dragonsh8tacos Active Member
    Tommy
    21 OR
    A few
    I have had this lift put on by the dealer a few weeks ago. Now I am getting mild vibrations and a rhythmic humming/light growling noise between 20 and 45 mph. Has anyone else experienced this?
    uncle-rico and YDCtaco like this.
  4. Mar 9, 2021 at 8:41 PM
    #584
    dragonsh8tacos
    Tommy
    21 OR
    A few
    I have vibration issues now that I have got this lift installed :( it is intermittent and seems most prevalent at about 45 mph.
    YDCtaco likes this.
  5. Mar 10, 2021 at 12:52 AM
    #585
    bolt_thrower77
    bolt_thrower77 Well-Known Member
    2021 DCLB trd or
    put it in 4wd and see if it goes away....for some reason any time you lift these trucks it has a tendency to throw out the needle bearings.....there is a ecgs bushing replacement for it.... good thing its under warranty since the dealership installed it....take it back to them...they are well aware of the needle bearing problem and there are a shit ton of threads on here about it
  6. Mar 10, 2021 at 2:55 AM
    #586
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    ^^ this and pls update after so we all know if it will be covered by warranty. Hopefully it’s covered.
  7. Mar 10, 2021 at 4:47 AM
    #587
    N3FOLMike
    N3FOLMike Well-Known Member
    2021 Tacoma TRD OffRoad
    My dealer will install tomorrow the kit plus wheels and tires. They have done a number of this type of install and with the lift kit, the taco can accommodate a 285 tire. My wheel is going to be 17x9 at a 0 offset. Warranty stays in tact.
  8. Mar 10, 2021 at 5:17 AM
    #588
    abrams2112
    abrams2112 Active Member
    Mid-East Alabama
    2021 Cement Tacoma TRD Sport 4x4 w/XP Package
    TRD lift kit
    Yikes! I'll have my TRD lift installed a week this Friday. I've noticed no vibrations, and most of my drive home from work is a 45 mph limit zone. I'm on the lookout now. Thanks.
  9. Mar 10, 2021 at 2:52 PM
    #589
    mainjet
    mainjet Well-Known Member
    Alberta
    2019 Tacoma off road
    Ray 10s Diode dynamics Hidden Light bar Toyo AT2s
    So for the Canadian boys. :canada:, my dealer said they can now order it
    It will be $ 1830.00 for the kit and $1105.00 for the install
    Over $ 3000 with tax....ouch
    They need a VIN to order it also.
  10. Mar 10, 2021 at 3:08 PM
    #590
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
    Even with warranty service, they'd just swap for another needle bearing and you'll see this same issue later?
    Guess folks will have to buy ECGS bushing and take it to dealership for warranty service.
  11. Mar 10, 2021 at 3:24 PM
    #591
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    That won't work. Some dealerships will do the clamshell bushing. Just do it, its going to happen.
  12. Mar 10, 2021 at 6:14 PM
    #592
    RCrumb
    RCrumb Dumb as Dirt
    CANADA
    2020 TRD OR Premium-Auto
    Agree it’s ugly, but completely in line with the the exchange rate.
    mainjet[QUOTED] likes this.
  13. Mar 10, 2021 at 7:29 PM
    #593
    Terminator84
    Terminator84 Active Member
    Kyle
    '21 Taco Premium Off-Road Pkg DCSB A/T LEDs Lthr Moonrf JBL Audio Nav Tech BSM RCTA
    OEM Lift Kit, 4Runner TRD Pro wheels, BFG KO2 265/70R17 tires, OEM black emblems, tacos4cheap TRD emblem, TVD vinyl grille/tailgate letters.
    DA6D5EA3-C565-4A4C-BA54-5B9C50F7CC61.jpg 8741E8B4-D5F8-4A77-9178-57974E2913F9.jpg
    Newbie here, saw this at my dealer today: black base SR with lift kit and TRD Pro wheels with Yokohama Geolandar X-A/T 265/70R17s.
  14. Mar 10, 2021 at 10:25 PM
    #594
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    Tell that to all the Jeep chicks driving fully modded Jeeps from a show room floor.
    If I had a dollar for every time I saw an overly modded dealership Tacoma in their showroom, I’d be able to take a vacation with it. They sell them. At eye gouging premiums. Easily.
    Most people outside of this forum don’t give a damn what parts they put on their Tacoma, as long as it has the look they want. Spacers, TRD Pro lift, Bilstein 5100, don’t matter. They will sell the same.
    JRH_Tacoma, RCrumb and bulalo like this.
  15. Mar 11, 2021 at 1:14 PM
    #595
    cheesepizza
    cheesepizza New Member
    Thought I would add a couple more before and after pictures for anyone interested. Tried my best to capture the same camera angles at the same time of day.
    Added this kit with with just over 100 miles on the truck (rig?), so I don't have a lot of seat time to compare. However, it behaves just as it did when I bought it 6 days ago, but the new level viewing angle from the driver's seat is noticeable. Very happy so far. Only thing I might change is add some color to the grille letters.
    Before / After measurements (ground to fender, both with full tank of gas) -
    • Left front: 35.44" > 37.63" = +2.19"
    • Left rear: 36.69" > 37.81" = +1.12"
    • Right front: 35.63" > 37.81" = +2.18"
    • Right rear:36.69" > 37.81" = +1.12"
    Overall thoughts, for whatever they're worth:
    Don't get this kit if you're only shopping on price. As the detractors of this kit have repeated many times, you can accomplish the same lift for far cheaper. Moreover, the included grille adds no value to many as they already have something similar installed.
    Do get this kit if you have the financial means and appetite for a Toyota co-branded product. Despite what others have said, if I was looking for a used Tacoma and had two options with a leveling kit (and all other factors equal), I personally am going to choose the one with the TRD kit.
    It took my dealer two days to get the parts and one full day to install. So far (30 miles) no vibrations from the dreaded needle bearing. Ordering wheels and tires next to complete this first project.
    RCrumb, offset, Jorts and 23 others like this.
  16. Mar 11, 2021 at 2:33 PM
    #596
    smuggiesrider
    smuggiesrider Well-Known Member
    Vermont
    2021 Army Green TRD Off-Road DCSB AT
    TRD 2" Lift kit w/ PRO Grille swap package ARE CX Classic Cap Sumitomo Encounter AT 265/75/16 tires TRD Pro wheels Predator steps Frame salt protection spray Weather Tech floor Mats and rainguards Wet Okole Seat Covers Bedmat Black exhaust tip Bed light LED kit Tailgate mat Eyecatcher tailgate letters Yoda cover for tow hitch and steering wheel Decals for grille, glove box, badges $$$$$$
    Very Nice!
    That was my 1st choice color until I saw the Army Green...I also agree about adding color to the grille
    cheesepizza[QUOTED] likes this.
  17. Mar 11, 2021 at 3:03 PM
    #597
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Looks good. Nice write up too. It looks like you had it tinted as well. Is that true? How much?
  18. Mar 11, 2021 at 3:12 PM
    #598
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    Great write up, keep us posted on how it goes as you add miles.
    cheesepizza likes this.
  19. Mar 11, 2021 at 3:22 PM
    #599
    N3FOLMike
    @cheesepizza Truck is looking good. I plan to have my 2 front windows lightly tinted to stay legal. I am just like you, I prefer the TRD kits more than anything else since warranty is a big thing to me on a new truck. Today, I have my dealer install all the goodies and I'll post dealer pics that were sent to me later this afternoon.
    Toyota_Eddy likes this.
  20. Mar 11, 2021 at 3:26 PM
    #600
    Toyota_Eddy
    Toyota_Eddy Official trouble Maker
    Riverside County
    2021 MGM TRD OR 4X4
    TRD lift kit, Pro Grille, Bed lighting, Falken Wildpeak AT3, To be continued....
    Same here, looking into either color matching the grille or just doing the letters.
