Toyota unable to figure out vibration
Discussion in 'Suspension' started by yodaman, Mar 17, 2010.
  1. Mar 17, 2010 at 8:11 PM
    yodaman
    yodaman [OP] Active Member
    Bellingham
    07 TRD Sport 4x4 V6 Automatic
    Yokohama tires Skyjacker canopy add more later
    2007 Tacoma Sport 4x4 with Yokohamas and Skyjacker suspension.
    Have vibrations at 20mph and 40mph that go away in 4x4. Have tried a homemade center bearing shim that seemed to help out the 20mph vibs. Tires all balanced, rotated, and alignement is spot on. No vib in steering wheel.
    Finally brought the truck into Toyota. They tech said that he could feel and hear the vibs at both speeds but after 5 hours they were unable to tell where the noise was coming from. He stated he checked everything he could and used a microphone. I had to pay $90.00 even though they didn't diagnose the issue. I was a little irritated with paying so I spoke to the manager. Ended up paying anyway. I understand that people have to make money.
    The kicker...they told me to wait until the noise gets worse and then they will fix it for me under the warranty...even if it expires. I've never been told that one before but they were decent about it. Took it to a driveline specialist. He stated that it shouldn't be the transfer case or any of the gears. He thought it may have been the center bearing. He showed me a spot that may have been rubbing inside the center bearing. I'm so fed up that I sprayed WD-40 into the center bearing tonight and drove it. No change. Hopefully one day I can figure out the vibs. The biggest thing is the tech. said that everything looked great on the truck so the vib must (hopefully) not be causing damage! Just wanted to update you guys.
  2. Mar 17, 2010 at 8:28 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I agree with the tech about letting the noise get worse, it would make it easier to spot the problem. I've been in that situation a few times but if it's bothering you, carry it to another dealer and driveline specialist and see if they can find the problem.
  3. Mar 18, 2010 at 3:40 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hope you get it squared away man. maybe they need to swap out the driveshaft.
  4. Mar 18, 2010 at 5:36 AM
    ACE_Taco
    ACE_Taco Long Range Practical Marksman
    NC
    08 DBLCab TRD 4x4
    OME 885x Coils, Dakar Leafs, OME Shocks, TC UCAs, BHLM, Tailgate MOD, WeatherTec Window Deflectors, WeatherTec Floor Mats, Blacked Out chrome bumber, Satoshi Grille, Wet Okole Seat Covers
    You are not alone Devil Dog...... I have been going through the same issue. I think the problem is the two-piece DS on the DC models. Shit is driving me crazy, and I have spent countless hours on it. I am about to put my shit back to stock and say the hell with it!
    My recent post -
    http://www.tacomaworld.com/forum/su...after-ome-lift-need-help-resolving-issue.html
  5. Oct 2, 2010 at 5:39 PM
    2011TacoSport4x4
    2011TacoSport4x4 Well-Known Member
    Clyde
    Offutt AFB, Nebraska
    2011 TRD Sport DC 4x4 OME 3" lift
    OME 3" lift, Flowmaster exhaust, K&N Intake, bestop, ARB Locker, 4:56 gears, ARB Deluxe bumper, Warn 8000lb winch, Synthetic line, Rock sliders, exhaust relocation done, All Pro standard 3" leaf packs, Timbren Bump stops, Extended brake lines, Pioneer dual din DVD, Pioneer door speakers, Ultra Gauge, BAMF Lower LCA Skids.
    Me too! I have spent so much time getting the vibs out of my truck, got them almost gone:cool: and now am getting a vibe when under power or climbing grades!
  6. Oct 3, 2010 at 7:57 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  7. Oct 3, 2010 at 8:00 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    have you tired putting on a carrier spacer ?
  8. Oct 3, 2010 at 8:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Generally, vibes in that speed range are indicative of a U joint....
