Toytec add-a-leaf shifting apart ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Razorecko, Oct 28, 2009.
  1. Oct 28, 2009 at 7:48 AM
    Razorecko
    Razorecko [OP] Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    So the last couple days i've been getting a squeek noise coming off from a take-off on my rear pass side. I have the toytec ultimate lift kit w/ the non tsb aal. My question is that when i got under the car it looks like the leafs on that pass side look like they are shifting apart. I'm guessing this is causing the noise but why are my leafs shifting apart and how urgent is this/what can i do to fix it permenantly....
    pics of pass side...
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    pics of normal drivers side...
    [​IMG] [​IMG]
  2. Oct 28, 2009 at 7:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Straigten it out, and check the torque on your U bolts.
  3. Oct 28, 2009 at 7:58 AM
    Razorecko
    I kinda figured but should i use some threadlock on the bolts ? I'd hate to have this be a repetitive thing.
  4. Oct 28, 2009 at 8:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If the U bolts are torqued to the correct amount, it shouldnt happen. I wouldnt use thread locker on them..
  5. Oct 28, 2009 at 8:36 AM
    Razorecko
    Thanks, this only happened recently when the truck was undercoated but i doubt it had anything to do with it
  6. Oct 28, 2009 at 8:38 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    hit with a hammer and straighten it out!
  7. Oct 28, 2009 at 8:40 AM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
  8. Oct 28, 2009 at 8:41 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    x2!
  9. Oct 28, 2009 at 8:41 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    PM neubs maybe he can help you out.
  10. Oct 28, 2009 at 8:41 AM
    09tacoLI
    09tacoLI Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    I gotta check my torque to see if they backed out I know they were set right cuz I watched david set them but mine look they same on both sides. I just thought thats the way they were. I also have the sqeaks.
  11. Oct 28, 2009 at 8:47 AM
    Razorecko
    Thats def causing it. My guess is the leaf is rubbing on the ubolt during compression.
  12. Oct 28, 2009 at 8:50 AM
    trailmaster308
    trailmaster308 Well-Known Member
    Louisiana
    PreRunner 3" Toytec Adj Coilovers 2" AAL
    mine did the same thing. turned out the U-bolts weren't tight enough. once i got that straight its been fine for a while now
  13. Oct 28, 2009 at 9:08 AM
    09tacoLI
    long island ny
    09 off road
    I think its around 70 for the torque setting if Im wrong (and I allways am) someone help me out its my parents fault im retarded not mine.
  14. Oct 29, 2009 at 2:07 AM
    RWS_350MAG
    RWS_350MAG Well-Known Member
    Don
    Wisconsin
    2010 TRD Off Road 4x4 AC
    Toytec Ultimate lift, Tailgate anti-theft mod, 265/75-16 Goodyear Duratrac tires on stock rims, Lakeland Predator Cap, Rear seat headrests removed, Husky Floorliners
    I believe the correct torque for the U-Bolts is 75 ft./lb.
    After installing a lift, it is a good idea to recheck the torque on all of the suspension fasteners after 100 miles or so.
  15. Oct 29, 2009 at 4:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    correct.
  16. Oct 29, 2009 at 4:09 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    we set yours to 75 to 83 :D
  17. Oct 29, 2009 at 4:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Perfect! :) If they werent check again after 50 or so miles, they could have loosened (if the bolts stretched), causing this to happen.
  18. Oct 29, 2009 at 4:22 AM
    David Tarantino
    N.J.
    08 tacoma
    and why the hell are you up at 4:30 am :D
  19. Oct 29, 2009 at 4:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Gotta take the MIL to the hospital for her (hopfully) Last surgery.
  20. Oct 29, 2009 at 6:00 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Is some shifting considered normal?
