Toytec lift, and extremely harsh ride?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewskie, Sep 15, 2010.
  1. Sep 15, 2010 at 5:23 AM
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    I have a 2.5 inch Toytec lift, with longer springs and small spacers up front, and AAL in the rear. I installed them as soon as I got the truck, so I have nothing to compare to, but it seems as though the ride is much to harsh/bouncy. The front and rear both seem really stiff, and the truck bounces on even the smallest bumps, passengers always wonder if somethings broken. I have always just attributed it to being a truck and the lift kit, but is it normal to be very, very harsh and stiff? Is something wrong? It was installed professionally. I am strongly considering removing the lift kit very soon.
    And yes I searched, because I am sure it has been asked, but I couldnt find anything. Thank you.
  2. Sep 15, 2010 at 7:41 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    ....go and test drive a new stock suspension taco ? I know with the toytec lift my ride was bumpy still but alot smoother and alot less bumpier than stock
  3. Sep 15, 2010 at 8:10 AM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    Which lift is it exactly? Toytec makes adjustable coilovers as well as other lifting options. If you have lift springs w/ spacers on stock shocks then that might be a cause.
  4. Sep 15, 2010 at 8:39 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    regular cab, access cab, double cab?
    regular cab, being lighter, is going to get more bounced around by stiffer springs.
  5. Sep 15, 2010 at 8:43 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
  6. Sep 15, 2010 at 8:45 AM
    JLee
    Jerry
    Benicia, CA
  7. Sep 15, 2010 at 12:36 PM
    drewskie
    Drew
    Burbank, CA.
  8. Sep 15, 2010 at 12:44 PM
    robdawg14m
    robdawg14m Rob
    Robert
    Denton, TX
    08 DC 4X4 SR5
    Apline IDA-X100 Head Unit Massive P 950.5 Amplifier 100x4 + 550x1 Diamond Audio 10" D1 Sub Focal K2 Component 165KR Debadged 33x12.5 Toyo MT 18" ATX Artillery Toytec ultimate lift kit LR UCA's Wet Okole seat covers
    Its harsh because you have a spacer lift.
  9. Sep 15, 2010 at 12:51 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    He does not have a "spacer lift" per se. He has OME 884 springs. The spacers in his setup are thin top-plate spacers, which do not affect the ride.
    The harsh-riding spacer lifts you are thinking of are preload coil spacers.
  10. Sep 15, 2010 at 1:03 PM
    drewskie
    Drew
    Burbank, CA.
    ^That's the impression I was under as well..............but something is definitely not right.
  11. Sep 15, 2010 at 1:11 PM
    JLee
    Jerry
    Benicia, CA
    Well the ride is going to be stiff with the 884 springs but it shouldn't be that harsh.
    Maybe your use to spongy trucks :D
    I personally like a firm ride.
    You can try and get some 5100's but it don't think it's going to sponge it up that much.
    you can also take it to someone to check everything to make sure the shop installed it properly. You never know they might of put something on wrong.
  12. Sep 15, 2010 at 4:18 PM
    jeremy.allen
    jeremy.allen Well-Known Member
    Jeremy
    The Ville, Ky
    07 DC, OR
    3" Lift with OME 885's, 5100's front and rear, alcan add-a-leaf. Banks Monster Exhaust, on the way: MM951C 17X9 and 285 MT/R's...
    5100's!! Your stock shocks are overextended.
  13. Sep 15, 2010 at 7:39 PM
    drewskie
    Drew
    Burbank, CA.
    Would that (overextension) make the ride stiff? i thought it had the opposite effect.
  14. Sep 16, 2010 at 8:20 AM
    JLee
    Jerry
    Benicia, CA
    Oh yeah if your shock extends all the way out it's like hitting a bump stop but on the other end you have no shock to absorb the impact so every time you rebound you feel everything the wheels hit.
    You want your shocks to have up travel as well as down travel.
    If you picked up some 5100's and relieved some of that tension that the coil is putting on your shocks you would see a dramatic change in the ride.
  15. Sep 16, 2010 at 8:51 PM
    drewskie
    Drew
    Burbank, CA.
    Thanks, I think i am going to go that route. i like the lift, but if that's what's causing the ride quality, i will gladly remove it. Do they make 5100's for the rear too? or is that even necessary? It feels like the ride in the back is stiff too.
  16. Sep 16, 2010 at 8:54 PM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Get Bilsteins on all four corners...you will love'em. I do!:)
  17. Sep 17, 2010 at 12:23 AM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Check your tire pressure too. anything over 30-35psi will start getting harsher.
  18. Oct 1, 2010 at 9:16 PM
    drewskie
    Drew
    Burbank, CA.
    Ok, so i am getting really fed up with the quality of the ride, so I'm asking my fellow tacoma'ers, would I be better off removing the Toytec lift altogether, or replacing the shocks with 5100's? I relaize the shocks will obviously cost a lot more, but I'd rather keep my lift and have at least a decent ride, than remove it if its not necessary. Thanks.
  19. Oct 1, 2010 at 11:14 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Depends on what's currently on there?
    I had the Bilstein OR shocks and Wow, those things are incredibly stiff in terms of rebound. The OME shocks I have were way easier and make the ride that much more enjoyable.
    If you were to get shocks, I'd go OME just because with the springs you have, they go hand in hand with the OME shock. (Seeing as it's made by the same company.)
  20. Oct 2, 2010 at 12:10 PM
    drewskie
    Drew
    Burbank, CA.
    Yes, I have the stock, non-trd shocks on there still. Are the OMEs made for trucks with a lift though?
