toytec lift kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trd888, Feb 14, 2011.
  1. Feb 14, 2011 at 8:26 AM
    trd888
    trd888 [OP] Well-Known Member
  2. Feb 14, 2011 at 8:28 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Well it's a spacer lift and there not the best. What year truck do you have and how many miles?
  3. Feb 14, 2011 at 8:30 AM
    trd888
    2011 ...3K miles on it now...TRd sport package 2WD DC
  4. Feb 14, 2011 at 8:31 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Your alignment (although within spec) may be less than desirable. In the future, you could add UCAs to solve that problem.
    The AAL is what I have on my truck, and is a very good AAL IMHO.
    Do a search on Bilstein 5100 2.5. I think those alignment discussions would give you a bunch of insight..
  5. Feb 14, 2011 at 8:34 AM
    JLee
    Jerry
    Benicia, CA
    Well at least your springs are new. I personally wouldn't put spacers on my truck let alone a brand new one. i would spend a little extra money and upgrade the shocks. You could get some 5100's & AAL for a little more then price and have a way better ride.
  6. Feb 14, 2011 at 8:48 AM
    trd888
    thank you for response...im doing this for starting point...is there any more adjustment if i lift on the front?may be in the future i will add UCA for now i want to enjoy the truck while still on warranty...
    thank you for response..yea the springs are pretty much new, but i want to install level lift kit for now like toytec..maybe in the future..yes ill do it upgrade ...the 5100's are standard shocks or coilovers?
  7. Feb 14, 2011 at 8:53 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    5100 are adjustable shocks only $300 for all 4
    U should go that rout and later upgrade coils
  8. Feb 14, 2011 at 8:53 AM
    JLee
    Jerry
    Benicia, CA
    If you just want it level just buy the 5100's and no AAL and set the shocks to 1.75 and your golden and it's the same price as the spacer lift and your ride will be better.
  9. Feb 14, 2011 at 8:54 AM
    trd888
    btw i already replace my OEM rims and went to upgrade 17x9 procomp wheels and install new BF goodrich K/O 265/70/17 to look more aggresive...kinda have slight rubbing from the mudguard,trim a little a bit..so far its ok for now..that was thinking if i can used the toytec lift for now with trd shocks..
  10. Feb 14, 2011 at 8:55 AM
    trd888
    thanks...do i need spacers if i install 5100?
  11. Feb 14, 2011 at 8:56 AM
    JLee
    Jerry
    Benicia, CA
    Nope!
  12. Feb 14, 2011 at 9:07 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    I had spacers to get me by till I got a set of bilstien 5100s and looking back I wish I never got the spacers, just go with the better lift the first time you won't regret it.
  13. Feb 14, 2011 at 9:44 AM
    The1youluv2hate
    Peps
    SAnta Paula CA
    Or u can just get eibach coils ..
  14. Feb 14, 2011 at 10:12 AM
    ttime4four
    ttime4four Well-Known Member
    West Linn, OR
    10 Tacoma 4x4 SR5 DCSB
    What is the best 5100 setting when adding the AAL to maintain stock rake? I'm probably going to do this this week because when I put BFG AT TA 265-70-17s on MotoMetal 951s, I get rubbing on the front fender bottom lip when reversing and turning. I've already removed the flaps and trimmed the front inner fender well.
    Thanks!
  15. Feb 14, 2011 at 10:22 AM
    JLee
    Jerry
    Benicia, CA
    I honestly have no clue but Id think it would be 1.75" with the 1.5" AAL but I don't have a 2nd Gen so I'm not sure.
  16. Feb 14, 2011 at 10:23 AM
    trd888
    where both same situation now;)...
  17. Feb 14, 2011 at 10:43 AM
    ttime4four
    West Linn, OR
    So I'm going the 5100 route vs the Toyotec and will post an update here when done.
  18. Feb 14, 2011 at 10:44 AM
    JLee
    Jerry
    Benicia, CA
    :thumbsup:
  19. Feb 14, 2011 at 3:13 PM
    raycie
    Oahu, HI
    In need of $$$
    There are some discussions on here about this very subject. The 1st question will be which AAL are you going to add? I think you are answering your own question... if you want your truck to have the same or close rake that you have now.
    If you lift the back 1.5" the front could go 1.75 (no 1.5 on the 5100s)
    If you do a 2" back, then 1.75 would give you more rake, 2.5 would give you a little less rake.
    I have a DC LB, and have my fronts at 1.75, 2" AAL on the rear and a snugtop shell.. I still have rake... I am picking up some UCAs so I can lift the front to 2.5, and hopefully be a little more level.
    Also, I wish I took someones advice.. Get the AAL that you want, then play around with a floor jack on the front to simulate 1.75 or 2.5. That way you only do your front once...
    Also, the AAL will sag a very small bit, but not a lot IMHO..
  20. Feb 15, 2011 at 7:13 PM
    trd888
    how about pair 5100 front and AAL with stock trd shocks? or 5100 allaround no AAL??are these good combination and ride?
    what is TSB leaf mean?
