Toytec ULK 1/4 " frt. top plate spacer
Discussion in 'Suspension' started by daniel68, Jul 1, 2012.
  1. Jul 1, 2012 at 11:06 AM
    daniel68
    daniel68 [OP] Takin' up space!!
    Danny
    Reno NV
    08 Acess Cab SR5 V6 TRD Manual
    Toytec ULK set to 3" frt. 2" AAL rear. LR UCA. URD short shift kit. ATX Mojave's on Cooper ATR's 235x85x16. Pinch weld mod.
    New to the forum. Been getting tons of useful info. I ended up going with the ULK with the 2" AAL. I have a bit of rake. The frt is set to 23" hub to fender.
    The question.....can I go with the Toytec 1/4" frt top plate spacesr and not have to worry about any pre mature wear issues. CV joints etc.... I reallize I will probably have to have the truck re aligned. Also. I have the LR UCA.
    Thanks in advance.
  2. Jul 2, 2012 at 7:13 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    What vehicle do you have?
    Are your coil overs maxed out at 2.5"?
    Shouldn't really go any higher since alignment issues will arise. Also the 1/4" Lift is generally only used to correct the taco lean
  3. Jul 2, 2012 at 7:20 AM
    cgs2k2
    cgs2k2 old man
    You should be able to add them with no problem. Especially since you have the LR UCAs.
    I have 2" up front from OEM coils, and have been thinking of adding the 1/4" spacers to both sides for about 1/2" more lift.
    Somebody with actual experience in these will probably chip in soon...
  4. Jul 2, 2012 at 8:19 AM
    daniel68
    Danny
    Reno NV
    Thanks for the replies. I have a '08 Access Cab 4x4 w/ theTRD package. ULK w/ LR UCR's. UDR short shift kit and running 235x85x16 Cooper ATR's on Mojaves. All thanks to info from TW!!:burnrubber:
    I think I am able to go higher with the threaded spacer. I am in the middle of the theaded part. However, I have read not to go more then 3" because you are using most/all of the down travel of the shock. So I am wondering if adding the 1/4" spacer on top of the C/O for a total of 3 and a 1/2" is advisable. Or am I setting myself up for all kinds of wear issues down the road? :eek:
  5. Jul 2, 2012 at 9:57 AM
    Supra TT
    Eric
    Indiana
    Our trucks aren't suppose to be lifted more than 3" and even at 3" it is too much some times. I wouldn't do it. Your ride quality will be shot.
  6. Jul 2, 2012 at 10:04 AM
    daniel68
    Danny
    Reno NV
    That's what I was thinking. I guess I could change out the AAL to the 11/2" height vrs the 2" to help level it out. I was hoping to not go any lower. Oh well. Thanks.
  7. Jul 2, 2012 at 1:56 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    The ULT kit has height adjustable collars for this very reason......however the truck will ride like shit if too much pre-load is put on them! Best thing is to add some weight to the the rear and let it settle after a bit. In general, coilovers are more of a performace upgrade than a lift if you look at it that way!?
  8. Jul 2, 2012 at 2:02 PM
    daniel68
    Danny
    Reno NV
    Makes sense. Maybe I'll throw the old wheels/tires in the bed and drive around for a while. Let the rear settle in. Thanks. :thumbsup:
  9. Jul 2, 2012 at 3:05 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Hell ya, and take them offroad and flex them out a few times!
  10. Jul 2, 2012 at 3:12 PM
    daniel68
    Danny
    Reno NV
    I'm all over it!! Brapppp!!!:mudding:
