Toytec ulk cant adjust coilovers
Discussion in 'Suspension' started by weaponxgfs, Nov 7, 2009.
  1. Nov 7, 2009 at 1:36 PM
    weaponxgfs
    weaponxgfs [OP] Member
    I just installed the ulk with the adjustable front coilovers. The directions say they come from the factory at 2" but I Want to adjust them to 3. Ive been searching and most people say to adjust the collar upwards to add more lift. When i try to adjust the collar its very hard to turn and feels as if im twisting the shock and i dont want to break the shock. Any suggestions?
  2. Nov 7, 2009 at 1:38 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If the tire still off the truck?? That's the first step to make it easier..
    And you are working against a fairly stiff spring and trying to compress it more....
  3. Nov 7, 2009 at 1:53 PM
    weaponxgfs
    Yeah the tires are off. Not sure wha the springs are rated at. They are the ones that come in the toytec ulk. Im using a pipe to add more levereve and they still dont budge
  4. Nov 7, 2009 at 2:17 PM
    Black Rock Taco
    Black Rock Taco Well-Known Member
    Winnemucca and Reno, NV, Oakland CA
    2011 DBL Cab Tundra
    None, yet
    How long have they been on there? At the very least, you need some good lube on the threads, and if they've been on and have crud maybe let some penetrating oil sit for awhile. You must use both spanners; if you're twisting the shock it sounds like maybe you're only using one??
    Wheel off, jacked up to take weight off and lube...
    My first time I tried it dry, and wouldn't budge. Sprayed some Break Free clean-lube-penetrant w/ Teflon and it turned pretty easy. Keep the spanners perfectly at 90 degrees to the length of the shock, they bend pretty easy if mis-aligned.
    I had to re-adjust mine twice, the springs settled a lot within the first 100 miles or so.
  5. Nov 7, 2009 at 2:56 PM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    Spray some WD40 on the threads, that should help.
