Toytec Ultimate is Installed
Discussion in 'Suspension' started by testedone, Oct 23, 2009.
  1. Oct 23, 2009 at 11:50 PM
    testedone
    testedone [OP] Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    Ok, so almost 7-8 hours later I am done, I thought it was a pain in the arse since I have never done this vehicle before, but after doing one rear and one front the others ones went easier
    Took it for a test drive there is a very small shudder/vibration from 5-10 mph, very, very small but there none the less.
    From 10 -75 mph no problems, vary speeds and gears
    4 wheel drive no problems
    The ride comparison with the 5100's all the way around is SWEET...there is a road I go to that has a ton of pot holes and railroad tracks, it "seem" as if I just floated over them :)
    I do not have the front Diff drop in yet so I still need to do that...
    The front coils Darrick said were shipped at 3 inches, I turned them down 3/4 of an inch (measured with a precision ruler) which should put the front at 1.5 inches of lift, I did keep a couple (1/8 inch) extra on the driver side for balance.
    In the rear I have the 1.5 TSB AAL even though I don't have the TSB done to the truck.
    Over all I am happy, tired but happy, tomorrow I will put the diff drop in and double check my bolts, torque etc..etc.. just to make sure. I might even raise the front another 1/4 - 1/2 do balance it out a little more, but it's not bad the way it sits. Next week I will take in for an alignment..
    Here are some pics, it's 1:45 am so no shots outside, best I could do in the garage
    Not to heavy of an angle at all on the UCA?
    Rear
    Front
    Full sag hanging on the jack stands
  2. Oct 23, 2009 at 11:51 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Nicely done good job now test that out and get some pics of that
  3. Oct 23, 2009 at 11:56 PM
    testedone
    Rick
    U.S.A.
    oh yeah the Sway Bar relocation kit was definitely needed and worked out great!
    It's not as high as some others but I didn't want overly high, my Jeep TJ had 6 inches and I hated all the money I dumped into that to get things smoothed out... And now I remember why I hate working with suspensions, my knuckles are toast
  4. Oct 24, 2009 at 10:42 AM
    testedone
    Rick
    U.S.A.
    Here is a pic from this morning, I installed the front Diff lowering kit and took it out again, still the shudder at 5-7 or 10 mph, So my thoughts are maybe drop the carrier bearing with a few washers??
    I am going to raise her another .5 inches up front and leav it at that just do get it leveled out a little more, not to much as I am sure the rear AAL will settle a bit..
    Thanks to everyones help in selection and getting this done, my wife hates you all for the money I spent...just kidding :p
  5. Oct 24, 2009 at 1:10 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Did you already install the shims that come with the kit? Alot of guys on here say not to install them right away because you may not need them. Maybe try taking them off before the CB drop if you've already put them on.
  6. Oct 24, 2009 at 2:41 PM
    testedone
    Rick
    U.S.A.
    yeah I thought of that, I did not put the CB on, later tonight I will remove the Shims and see what that does, I also have an alignment set for Monday...
  7. Oct 24, 2009 at 3:03 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Looks awesome! Good job on the install!
  8. Oct 24, 2009 at 3:53 PM
    testedone
    Rick
    U.S.A.
    Some new shots after I raised the front to 1.75, I might go the full 2 but will decide tomorrow before my alignment.
  9. Oct 24, 2009 at 4:13 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    looks awesome man great job!
  10. Oct 24, 2009 at 11:15 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Looks awsome! great job.
    And I think you could go a little bit higher in the front...IMO
  11. Oct 25, 2009 at 6:34 AM
    testedone
    Rick
    U.S.A.
    I am going to take the shims out of the rear this afternoon and see if it gets rid of the slight shudder I have at 5-10 mph, I only have 1.5 AAL's in the back without the TSB, so I shouldn't need the shims, maybe the shudder will leave.
  12. Oct 25, 2009 at 9:23 AM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    Yes the shims may be overcompensating.
    Put a few hundred pounds in the bed and see if it gets worse.
  13. Oct 25, 2009 at 9:26 AM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Good looking truck, I love that color. Good job.
  14. Oct 25, 2009 at 9:40 AM
    Faskev
    Faskev Well-Known Member
    Looks great! I have the same kit and love it! When I first installed it I put in the diff drop and the shims in the rear but still had a slight take-off vibe so I ordered the OME Carrier Bearing spacer which smoothed it right out. It's only $20 for the CB spacer so it's worth a try. I was happy it was a simple solutions with some of the vibe horror stories around. I am nothing short of impressed with the lift as it's at a full 3" of lift and none of the ride comfort has been sacrificed. Enjoy!
  15. Oct 25, 2009 at 9:48 AM
    Foster9091
    Foster9091 Well-Known Member
    Upperco, MD
    01 Doublecab TRD
    deckplate mod, floor mats, hi lift, scanquage, and 2 in front leveling kit
    remember the rear will settle out before you decide on your front height
  16. Oct 25, 2009 at 10:53 AM
    testedone
    Rick
    U.S.A.
    yes, that's a thought I keep up front, I have a trip net week, 1800 miles that will I am sure get thing settled in the truck so once I come back from that I will work out the height issue if it needs to be addressed.
    As it sits now it has the shims in the rear which I will be taking at after typing this up ( I don't think I need them with only 1.5 inch in the rear) and then if the vibe is gone I will leave it as it is and see how things settle..
  17. Oct 25, 2009 at 11:12 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Looks good...
    Whats the difference between the 3 sets of leaf lift options for those without the TSB....the 2" AAL, the 1.5" TSB AAL and the OME Dakar..?? or is this answered somewhere else?
  18. Oct 25, 2009 at 11:29 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Looks good!
  19. Oct 25, 2009 at 11:43 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Nice job man! :woot:
  20. Oct 25, 2009 at 12:03 PM
    testedone
    Rick
    U.S.A.
    ok, I removed the shims, I still have a very small amount of vibes, to begin with the vibes I had with the shims in was small, this is even less, so I will leave it as it is and just deal with it, since it (the rear AAL) is bound to settle it may just go away...
