Toytec ultimate lift with stock rims and tires.
Discussion in 'Suspension' started by Esoetenga, Feb 27, 2010.
  1. Feb 27, 2010 at 8:58 AM
    Esoetenga
    Esoetenga [OP] New Member
    I was just wondering if anyone is running the toytec ultimate lift with LR Uca's on stock rims and tires. The reason I'm asking this is because I am going to install this lift on my 07 Tacoma 4x4. I have to wait a bit on new rims and tires due to money. I just want to make sure it will work fine. And I would be getting it allighned after, and probably going to have to get it done a second time after I put on 285 or 265/70 R17. Any help would be sweet.
  2. Feb 27, 2010 at 9:08 AM
    Hugebergen
    Hugebergen Crash and burn live and learn
    Saskatoon Sask
    3"Toytec ULK, box mat, angle brackets in box corners for tie downs, anytime fog lights, bhlm, black grill and lip, trimed front flaps, 7089 procomp rims with 285/75/16 Toyo M/T tires, black badges with trd badges added,anytime foglights, lamin-x yellow fogs, illuminated 4x4 switch, colour match satoshi, Camburg ball joint UCAS.
    Im doing the same thing. I cant see why there would be a problem.
  3. Feb 27, 2010 at 10:10 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    You will not have a problem. You do not have to get it aligned AGAIN just because you put new wheels and tires on either.
  4. Feb 27, 2010 at 10:41 AM
    Esoetenga
    Good to know, thanks. Do I need to extend the brake lines on this lift or will it be ok?
  5. Feb 28, 2010 at 8:20 AM
    Hugebergen
    Saskatoon Sask
    Brake lines should be good to.
