toytech adjustables 2.5 or 3?
Discussion in 'Suspension' started by straycat241, Jul 24, 2008.
  1. Jul 24, 2008 at 4:46 PM
    straycat241
    straycat241 [OP] maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    ya i just got them in the mail the come pre set at 2.5 but if i crank them up to 3 inches would i have problems like stiff ride\ bad angles on front end parts when wheelin ?
  2. Jul 24, 2008 at 4:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The higher you crank them, the more stiff the ride will be. :) You will need to get an alignment after lifting and your angles should be fine then.
  3. Jul 24, 2008 at 5:01 PM
    straycat241
    paul
    ya 2.5 sounds good i want travel on them but if i was to get the rear tsb done does the leaf package add some height too\ better off road ride?
  4. Jul 24, 2008 at 5:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The TSB will give aboput 3/4". It will ride much better on and off road. :)
  5. Jul 24, 2008 at 5:09 PM
    straycat241
    paul
    ya sounds good my brother inlaw is supposed to install my coilovers tomorrow at the yota dealer and hes trying to get the rear tsb part sqared away im not sure if my 08 is eligable im pretty sure it is though
