TPMS and the Five-Wheel Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SBT, Nov 18, 2017.
  1. Nov 18, 2017 at 5:12 PM
    SBT
    SBT [OP] New Member
    2015 Tacoma
    Hi all,
    This is my first post on this forum.
    I have searched high and low for an answer to my question, but haven't found anything, so here goes:
    I want to get a spare tire for my 2015 Tacoma that matches the four new offroad tires I have put on it. These have TPMS sensors in them.
    I would like to rotate the spare with the other tires, so it would make sense if it also had a TPMS sensor.
    The problem is, the local dealer tells me that the 2015 Tacoma system will only handle four sensors at a time. So a fifth sensor will not give me any meaningful info about the state of my tires (i.e., if one road tire runs low, the light will stay off because with the spare tire on, there will still be four healthy signals coming into the system).
    Anyone have any suggestions for a workaround?
    I am also wondering if there are external TPMS sensors (that screw on to the valve stem, like a valve cap) that would work with a Tacoma. This would seem to be the ideal solution, but I have not seen anything like this (https://www.amazon.com/ENKLOV-Wirel..._4?s=automotive&ie=UTF8&qid=1511053489&sr=1-4) that appears compatible with the Tacoma's TPMS receiver -- they all use standalone receivers that plug in to the 12V outlet.
    Thoughts?
    wi_taco likes this.
  2. Nov 18, 2017 at 5:18 PM
    RichB
    RichB Well-Known Member
    Rich
    MA
    2023 Nissan Frontier Pro4X
    So in theory you could have a deflated spare tire and not know it. This makes no sense.
    bski22 likes this.
  3. Nov 18, 2017 at 5:20 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    So...why not just run 1 tire without a TPMS? If you have 4, you’ll always know you have 4 full tires. If the 5th goes flat, then you have a full size spare.
    Or do what millions have done before you and don’t run a TPMS. I disabled mine when I went to aftermarket wheels.
    Armed in Utah likes this.
  4. Nov 18, 2017 at 5:25 PM
    SBT
    SBT [OP] New Member
    2015 Tacoma
    Hmm. You do have a point. Maybe I'm overthinking this whole thing...
    Clearwater Bill likes this.
  5. Nov 18, 2017 at 5:25 PM
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
  6. Nov 18, 2017 at 5:57 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    one time my "low tire pressure" light came on and I didnt know why, I took it down to the tire shop, they squirted a bit of air into my spare and the light went out... now, that dont square up with what the dealer told you, does it?
    bski22 likes this.
  7. Nov 18, 2017 at 6:04 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I have 5 matching wheels and tires on my 15 as well. They all have TPMS Sensors in them, I will be rotating the spare into my rotations, and the place I get them rotated reprograms all 4 before I leave at no charge. So it is doable. But that monitor you show will only show the 4 tires that are rolling
  8. Nov 18, 2017 at 6:04 PM
    chucklefunkk
    So. AZ
    2016 TRD OR
    FWIW my dealer told me that 2016's have a 4 sensor system without TPMS in the spare.
  9. Nov 18, 2017 at 6:13 PM
    SBT
    SBT [OP] New Member
    2015 Tacoma
    What year is your truck? I have read that older ones (pre 2015 at least) supported five sensors.
  10. Nov 18, 2017 at 6:15 PM
    SBT
    SBT [OP] New Member
    2015 Tacoma
    How does the receiver tell between the signals on the 4 installed tires and the one coming from a spare in the back?
    trktwo likes this.
  11. Nov 18, 2017 at 6:17 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Because he goes around to the 4 on the ground tires gets the numbers off them and runs it into the OBDII
  12. Nov 18, 2017 at 6:38 PM
    Pigpen
    Dan
    Northwest Montana
    Here's how it works. The truck senses wether or not it is in close enough proximity to 4 functioning sensors that transmit a desirable reading. I have 2 sets of wheels with tires on them and a spare. The spare does not have a sensor. One of the sets of wheels also does not have sensors. The other does. When I switch from winter to summer wheels (or visa versa) ... If the wheels without sensors are on the truck and I am not near the other set, my TPMS light is on. If I drive around with the set that has sensors in the bed of my truck, the light does not come on.
    You can even do a 5 tire rotation if you like. As long as 4 have working sensors, you're good. If your spare has a good sensor, you could get a flat and the truck may not notice, as there are 4 good sensors in proximity. I could also be wrong about that part. One sensor sending a "red flag" signal might set off the light. I'm not sure.
  13. Nov 18, 2017 at 6:56 PM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    In techstream there is a field that shows how many tpms sensors came from the vehicle from the factory. Location of the sensors have no bearing on this. Vehicles with 5 sensors do not know if a tire is in the bed of the truck or on your vehicle.
    I see no options in changing the number of sensors either.
    I probably have 20 vehicles a day in the service drive when it gets cold for air.
  14. Nov 18, 2017 at 6:59 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Why did they go to a four sensor system? My 06 supports 5. That’s weird
  15. Nov 18, 2017 at 7:03 PM
    OKTACO
    Ty
    2005 SR5 Taco
    It's hit or miss it seems to be honest never took the time to verify which years have them. So many vehicles went to donuts and no Toyota without a full size spare has a sensor.
  16. Nov 18, 2017 at 10:02 PM
    bluezzy
    Monty
    Eugene, Oregon
    Mine is an 07 Sport.
  17. Nov 19, 2017 at 2:38 AM
    RichB
    Rich
    MA
    The '15 owners manual says that the spare doesn't have a sensor but it also calls it a temporary tire. The Tacomas obviously have full size spares the same as the rest of the vehicle. Confusing.
    I'm tempted to let air out of the spare and see if the light comes on.
  18. Nov 19, 2017 at 5:06 AM
    p_chinnici
    p_chinnici Well-Known Member
    Pete
    South Nj
    2015 Trd Pro Access Cab, 2.5 Kings, Dakars
    2.5 Kings all around, HD Dakars -1 OL, Camburg Moog BJ UCA, Leer 100r topper, Prinsu rack
    So did you disable the whole TPMS? I am putting aftermarkets on soon, and my old truck doesn't have tams, so I don't care about it.
  19. Nov 19, 2017 at 5:14 AM
    Clearwater Bill
    Billy
    Largo Florida
    There is the magic secret.
    And 'no charge' is magic secret #2.
  20. Nov 19, 2017 at 5:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    Your disablement method?
    Lots of posts around on the topic, but success seems to vary wildly by year model (or maybe user)
    I'd gladly do w/o mine, particularly when they finally fail.
