TPMS assistance needed (Pic included)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ahhlen, Mar 7, 2012.
  1. Mar 7, 2012 at 4:01 PM
    ahhlen
    ahhlen [OP] New Member
    Hello all, I'm having trouble determining which TPMS sensor I need for the wheels pictured below, can any one advise?
    It's an 07' with the 17" wheels.
  2. Mar 7, 2012 at 5:25 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    I couldn't say which sensor you need for those, but what I do know is that I've been told by my stealership that the sensors from my steel OEM wheels wouldn't work on my aftermarket aluminums. Seem to be working just fine. Sorry I can't help with your particulars, but I'll bumpity anyhoo.
  3. Mar 7, 2012 at 6:45 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    They will work if you rotate them 180 degrees, but in the future you need to make sure that tire installers know this or they will destroy them breaking the bead.
    Another option is to go to standard stems and simply band the OEM sensors to the inside of the rim.
  4. Mar 7, 2012 at 7:10 PM
    satcom221
    satcom221 Well-Known Member
    Rick
    Kingston, WA
    2023 Celestial Silver Double Cab SR5 4x4 SB
    VLEDS V tail conversion, gas cap holder
    According to the parts list it would be 42607-06011 (see attachment)
    It appears that this TPMS is used for ALL wheels for models 2007-2010. I would verify that with a knowledgeable mechanic - not service writer...
    BTW, there are after market replacements as well as EBAY that have them for 30-50 apiece.
    Hope this helps
    Rick
  5. Mar 7, 2012 at 7:50 PM
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Yeah, the service guy at the dealer said I was going to have to either band them or buy new sensors (at $230/ea). The guy at Les Schwab (tire place) said that most newer aftermarket rims have been designed to allow them to fit. They definitely know what they're doing at that shop and had no issues re-using them.
  6. Mar 7, 2012 at 7:58 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
  7. Mar 7, 2012 at 8:00 PM
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
  8. Mar 8, 2012 at 7:09 AM
    rodney
    rodney Well-Known Member
    Toyota Sienna Mommyvan & Ford 2fitty
    just put the tpms in a pressure vessel, and use rubber in the wheels. problem resolved. just keep tabs on your tire pressure, and you will be fine. :p
  9. Mar 17, 2012 at 2:35 PM
    ahhlen
    One last question, is there a DIY way to program the new sensors to the vehicle?
  10. Mar 17, 2012 at 5:08 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Guys.... be real careful..... The TPMS sensors made for aluminum alloy wheels WILL react with steel and mess you up big time.... I know.... I put a steel valve stem cap on my aluminum spare tire....with the salt and shit.... the 2 metals destroyed the TPMS sensor....
    There are seperate sensors for steel wheel and aluminum wheels.... mix them up and you will have problems eventually....Sooner if you drive in salt, etc...
    Be careful...
    Over
