TPMS blinking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moeb, Aug 13, 2012.
  1. Aug 13, 2012 at 1:57 PM
    moeb
    moeb [OP] Member
    moe
    baltimore
    06 SR5
    hey this is great a site for tacoma owners.just installed new wheels on my 2006 SR5.i bought the wheels and tires and they came mounted and balanced and now my TPMS light is blinking has anybody run in to this problem before.
  2. Aug 13, 2012 at 2:05 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Did you put the sensors in the new wheels? If not, that's why the light is on.
  3. Aug 13, 2012 at 2:18 PM
    conradtaco123
    conradtaco123 southern proud
    Joshua
    Glencoe Alabama
    2011 silver double cab tacoma
    procomp 3in lift, satoshi grill, custom light bar and 7in kragen hids behind grill, undercover hwms and smittybilt xrc8 8000lb winch, uws low profile tool bow, custom light bar on tool box, cobra 29lx cb cutom mounted in cab n k40 4ft antenna, fog anytime mod, diff breather mod, squeaky leaf fix mod,many more to come.
    when the new wheels and tires were installed did the tires sensors from your old wheels and tires get installed or did the new wheels and tires come with new tires sensors? if the new wheels and tires already had new sensors then your need them recalibrated for your emc unit. i would also check to see if they placed tire sensors were placed or not.
  4. Aug 13, 2012 at 2:21 PM
    sernaj64
    sernaj64 Aight
    Juan
    honolulu
    2011 prerunner V6 SR5
    N fab Step bars BHLM by Asianants Pro Comp 2.25" level lift kit rear leaf TSB
    how can you tell if you got TPMS ?? i have a 2011 dc had my wheels installed through the dealer and i have never had my light go on
  5. Aug 13, 2012 at 2:24 PM
    lowrange
    lowrange Supreme Commander of the Army of the Tacoma
    Joe
    Are Can Saw
    15 TRD Sport
    Let a few pounds of air out of one of your tires and see if the light comes on.
  6. Aug 13, 2012 at 5:31 PM
    moeb
    moeb [OP] Member
    moe
    baltimore
    06 SR5
    no they are still on my steel wheels and the new wheels dont have them i was wondering if there was anyway i can disable them
  7. Aug 13, 2012 at 5:40 PM
    Pugga
    Massachusetts
    Look at the valve stems. If they're plain black plastic, they likely didn't transfer over the TPMS. If they're metal sleeved, they have the sensors. If your light isn't on, they transfered them over. I don't believe a dealership would have disabled the TPMS system.
    There is a way to disable it, I'll see if I can find the thread. If you keep your old tires/wheels in the garage and park near them every night, the light will reset every time you start the truck and won't come on until you've driven 50 - 100 miles.
    Here's one method to disable the TPMS:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/161292-complete-tpms-disable-guide.html
  8. Aug 13, 2012 at 5:43 PM
    Hot2na
    Hot2na Well-Known Member
    Sounds like you need to make a TPMS PIPE BOMB !!! ...put the sensors in a sealed 3" pvc pipe & inflate to around 40 psi....store in the truck somewhere (under the seat ,etc)...mine's been in the pipe since day 1...works great !!!
  9. Aug 14, 2012 at 11:57 AM
    moeb
    moeb [OP] Member
    moe
    baltimore
    06 SR5
    i was wondering if i could put all the sensors inside of my spare tire
  10. Aug 14, 2012 at 12:19 PM
    Pugga
    Massachusetts
    I doubt you could put 4 sensors inside your spare... You could pick up a wheel barrel wheel and put the sensors in there and keep it somewhere either in the bed or in the cab. It'd keep the light off.
  11. Aug 14, 2012 at 12:23 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Best thing to have done was had them install the TPMS into the new wheels. :eek:
  12. Aug 14, 2012 at 4:41 PM
    OxyGuy
    OxyGuy Well-Known Member
    Conway, SC
    2007 PreRunner
    Check the air pressure in your spare tire.
  13. Aug 14, 2012 at 4:53 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    or just check your tire pressure regularly and get over the light like I did...
