TPMS flashing after tire fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dinki, May 25, 2018.
  1. May 25, 2018 at 10:52 AM
    dinki
    dinki [OP] Member
    13 PreRunner I4
    I ran over a nail and had the tire plugged. Tire tech pulled the tire, plugged it and put it back on. TPMS was flashing and I asked why this was so. They told me it could take up to twenty miles for it to reset. It's been well over that now and it's still on.
    Tire light flashes for a while and then stays solid until I kill the engine. Next time I start it I get the same thing. I used my BT OBDII to see if I could get more information but Torque shows nothing.
    Can anyone tell me what might have gone wrong and how to fix it? I am planning on bringing it in for routine service in a few months but would like to get this resolved before then if possible.
    Thanks!
  2. May 25, 2018 at 10:59 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    Did the tire jockey set the repaired tire to the same pressure as the others on the truck? If not, start there...
    It's also possible they damaged the TPMS sensor when they dismounted & mounted the tire.
    You'll need a capable scan tool to pull TPMS codes.
  3. May 25, 2018 at 11:02 AM
    BRT64
    BRT64 Well-Known Member
    Alabama
    2014 TRD OR
    Try the reset button under the steering wheel. Just turn the key on and hold the button till it blinks three times. I think, it worked for me , but its been a while
    blu92in99 likes this.
  4. May 25, 2018 at 4:08 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    2nd resetting tpms
  5. May 25, 2018 at 5:00 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If it's flashing the sensor is broken
    Bebop likes this.
  6. May 25, 2018 at 5:13 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    What he said...
  7. May 25, 2018 at 7:07 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Duct tape over light
  8. May 25, 2018 at 7:08 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    x3
  9. May 26, 2018 at 5:00 AM
    dinki
    dinki [OP] Member
    13 PreRunner I4
    What sensor? In the repaired tire? Kind of weird it stopped working right after the tire came off
  10. May 26, 2018 at 5:29 AM
    Bebop
    Nick
    There is a sensor in the tire that tells your tire pressure to the truck. It probably broke when he reinstalled the tire. Happens all the time
  11. May 26, 2018 at 6:57 AM
    dinki
    dinki [OP] Member
    13 PreRunner I4
    Thanks for the information. Can I get this fixed at Walmart or do I have to go to the dealer? Any idea on the cost to repair?
  12. May 26, 2018 at 7:16 AM
    Bebop
    Nick
    Whoever fixed the tire should be paying the cost of the sensor to be replaced if this is the case. I would take it back to the shop that did the flat repair.
  13. May 26, 2018 at 7:58 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    This.
    Bebop[QUOTED] likes this.
  14. May 26, 2018 at 11:44 AM
    dinki
    dinki [OP] Member
    13 PreRunner I4
    Tire was fixed at Walmart . They are capable to replace sensor there?
  15. May 26, 2018 at 12:04 PM
    TexasWhiteIce
    Texas
    I don’t think they are even capable of dressing themselves
    tomwil, grizquad, blu92in99 and 2 others like this.
  16. May 26, 2018 at 12:05 PM
    Bebop
    Nick
    If they can’t they should be forking over the bill to a shop that is capable to replace and program a sensor. Note to self, don’t take your truck to Walmart
    blu92in99 and b_r_o like this.
  17. May 26, 2018 at 12:06 PM
    TexasWhiteIce
    Texas
    Note to self, don’t take yourself to Walmart
  18. May 26, 2018 at 12:06 PM
    Bebop
    Nick
    I wouldn’t trust them to change the wheel on a lawnmower let alone a 35k truck...
  19. May 26, 2018 at 12:07 PM
    Bebop
    Nick
    I go to target, where I pay a little more to not have to go to Walmart. Plus there are always hot chicks in yoga pants drinking Starbucks
    EatSleepTacos likes this.
  20. May 26, 2018 at 12:32 PM
    TexasWhiteIce
    Texas
    Only time I go to a Walmart is the neighborhood Walmart markets. For some reason the Walmart “culture” isn’t in those which is odd. And most of the white trash doesn’t shop there. Guess they need the full blown Walmart experience.
