tpms help
Discussion in 'Wheels & Tires' started by djehockey7, Jun 30, 2010.
  1. Jun 30, 2010 at 5:01 AM
    djehockey7
    djehockey7 [OP] Member
    North Carolina
    09 tacoma 4X4
    5100s set at 2.5 1.5 AAL
    hello TW I need some help, my friend is going to be installing a lift and wheels/tires on my 2009 4 cylinder 4x4 access cab tacoma at the dealership he works at. my question for you is will my tpms switch over from my stock wheel? or will he need anything to switch them over?
  2. Jun 30, 2010 at 5:09 AM
    98tacoma27
    Ben
    Not Beech Creek
    Steelie TPMS are different than alloy TPMS sensors, but you can turn the sensors 180° so they will fit.
  3. Jun 30, 2010 at 5:14 AM
    djehockey7
    North Carolina
    09 tacoma 4X4
    will he need anything to do that? or should it be fine? also r they a need, what would happen if i just dident use them?
  4. Jun 30, 2010 at 5:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    They just unbolt from the rim. Look at the valve stem and you will see a nut at the bottom against the rim. That is what holds them on. If you don't use them, your TPMS light will illuminate.
  5. Jun 30, 2010 at 5:25 AM
    djehockey7
    North Carolina
    09 tacoma 4X4
    allright so he needs to unbolt it at the valve stem and then like u said just flip it 180?? and he wont need anything to do this? no bands or anything? also where are u stationed? mos?
  6. Jun 30, 2010 at 5:28 AM
    98tacoma27
    Ben
    Not Beech Creek
    He will only need to flip them if you are going from steel to alloy rims or vice versa. This what they look like:
    I am stationed at home. I was an 0341.
  7. Jun 30, 2010 at 5:37 AM
    djehockey7
    North Carolina
    09 tacoma 4X4
    hey thanks a lot, I am also a 41, but am currently in FAST CO
  8. Jun 30, 2010 at 5:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    Ranger pudding and Spades..............
    Thank you for your service and stay safe. Semper FI
  9. Jun 30, 2010 at 5:46 AM
    djehockey7
    North Carolina
    09 tacoma 4X4
    thanks for the help stay safe as well. Semper Fi
