TPMS light flashing
Discussion in 'Wheels & Tires' started by piercedtiger, Jul 22, 2008.
  1. Jul 22, 2008 at 9:08 AM
    piercedtiger
    piercedtiger [OP] Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Anyone have any idea why my TPMS light is flashing? All 5 tires are at the same/correct pressure. I called a local dealership thinking maybe the batteries in the sensors are bad and need to be replaced, but they seemed to think there weren't batteries in them. :confused: Can anyone confirm that? Or give me an idea what the problem is? I tried the reset switch, but that didn't help. I haven't changed wheels or tires recently, or even had them worked on. The battery did die a couple times though and needed to be recharged (dead as in NONE of the lights worked).
    nazlax10 likes this.
  2. Jul 22, 2008 at 9:35 AM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    I have absolutely no knowledge in this area but I wonder if one of the sensors broke loose in the tire.
  3. Jul 22, 2008 at 9:49 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    13 TRD OR DC MGM
    Stock for now
    I have a brochure from my local tire warehouse on TPMS on my desk. One of things written in the "Things you should know about your TPMS unit" is
    "Each sensor has an internal battery designed for up to 10 years of service. In the future, the TPMS sensor may require replacement when the battery life expires."
    It also said something about the sensors may experience internal corrosion buildup that will ruin the valve core.
    "Frozen valve cores may require complete sensor replacement. Do not expose internal valve stems to any corrosion or moisture to protect your valve stem sensors."
    Hmmm, corrosion? moisture? vermont? My TPMS is toast at some point! Maybe this helps.
  4. Jul 22, 2008 at 9:51 AM
    piercedtiger
    Jon
    Southern Tier, NY
    I doubt it... We haven't really been driving it that much let alone off roading, or anything else that could damage it. :confused: I just assumed after 2 years the batteries needed to be replaced, but the service department told me no. They use radio waves. That would make more sense than batteries I suppose. Now I'm wondering if the battery dieing cause the system to reset and now need to be reprogrammed at the dealer (sensor serial numbers, etc).
  5. Jul 22, 2008 at 10:01 AM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    If your TPMS light blinks for 5 seconds and then lights steady, one or more of the tire pressures are out of spec.
    If the light blinks contineously, you have a malfunction in the system. Either the RF receiver is bad or one of the sensors is broken.
    You need to go to a Toyota dealer because they are the only ones that have the $$$ equipment to troubleshoot the system. New sensors are about U$120 each.
    The sensors have batteries. The system will illuminate the light whenever one of the sensors reports a tire pressure +/- 4 psi from the set value. You set the value with the reset button.
    Fritz
  6. Jul 22, 2008 at 10:09 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I have this issue. Toyota has already replaced one sensore, and they are about to do the same for another. The thing is only 3 months old with 10,000 miles on it. WTF? :frusty:
  7. Jul 22, 2008 at 10:10 AM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    do you think this can be related to changing your stock tires or something???
  8. Jul 22, 2008 at 10:11 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    No, because they told me that if it was the changing of the tires, then they wouldn't pay for it. They said that the sensor had just stopped responding. :confused:
  9. Jul 22, 2008 at 10:21 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Thanks. :rolleyes: I figured there was a battery in each valve stem. Really makes me wonder if I should go to that dealer or not... :rolleyes: They couldn't even tell me how much it cost to replace the valve stems. Only that it was $91/hr to look at it.
    Latrans likes this.
  10. Jul 22, 2008 at 10:24 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Crap! :eek: 120 f'n dollars for these damn things!! I liked having the system, but hell, disabling it's beginning to look like a better option. :(
  11. Jul 23, 2008 at 11:19 PM
    2nd2none
    2nd2none Well-Known Member
    San Diego, CA
    2018 Tacoma TRD Pro. Lifted, rims, tires, yada yada yada
    Had the same thing happen to my truck. I bought the TRD Ivan Stewart rims and some new tires but I was able to have the tire shop move my sensors to the new rims. worked fine for months then I was on deployment while in the Navy and my friend slacked off on driving the truck around periodically and let the battery die. When i got back the sensor light kept flashing. All my tire pressures were about the same and since I've got the URD supercharger on my truck I couldnt just take it into a dealer to have them look at it. I know you can do some wiring snipping to disable it but i've just ignored the flashing for about a year now.
  12. Jul 24, 2008 at 4:49 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Yeah, I just can't justify $91/hr to find out the sensors need to be programmed back into the system plus whatever the f*&K that is gonna cost me. :rolleyes:
  13. Jan 30, 2014 at 7:02 AM
    jhkorn
    jhkorn New Member
    JK
    Atlanta
    05 4runner sports edition
    After driving home when the temp dropped to the teens and snowing my light starting blinking and wouldn't go out. I checked the tires and all were really low due to a sudden temp drop. Two days later I had them all filled including the spare and the light went out. It's my conclusion that blinking can also mean multiple sensors are reporting a malfunction. So fill all tires including spare, wait a few minutes and see if the light goes out.
  14. Jan 30, 2014 at 7:12 AM
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    Same thing happened to me during this latest deep freeze here
  15. Feb 18, 2014 at 2:51 PM
    Poodle Head Mikey
    Poodle Head Mikey Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    They told me $600. for new sensors (as they don't know how many are defective) and then some additional charge that I forget for programing them to play nice with my truck. I have owned more than fifty vehicles in my life so far and only one other one has had a tire pressure monitoring system. So, all things considered; the better part of $1000. to have some tire-nanny thing which does what I have quite successfully done myself for decades seems pretty darned silly to me. Taking the warning light bulb out of the dash seems more like The Way Of A Reasonable Man. <g>
  16. Feb 18, 2014 at 4:00 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Isn't it frustrating to see that you could, if you wanted to, replace the entire damn system with one that has more functions for a FRACTION of that price? :frusty:
    http://www.amazon.com/ORO-Technolog...bs_auto_4?ie=UTF8&refRID=04TYHJHMRHN84JS8YVCV
  17. Feb 19, 2014 at 7:34 AM
    Poodle Head Mikey
    2007 base w/2.7
    Did my factory TPMS system have a display like that in the mirror?
    I have a cap on my truck bed and the white lines on the road some how reflected around between the rear window on the cab and the rearview mirror in some way which made me crazy distracted so I took the inside mirror off long ago. I doubt I could even find it now
    Did the factory TPMS system have a rearview mirror display? Like the one you posted a link to has? Or is that aftermarket TPMS both cheaper And better? <g>
    PHM
  18. Feb 19, 2014 at 5:08 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Yeah, that's my point. You could rip the whole factory setup out and replace it with a BETTER system (most show actual tire PSI, per tire and some show tire temperature too) for what it would cost to have the dealer replace ONE sensor! :frusty:
    So with that in mind, why the hell is it so damn expensive for the dealer to fix this shit?
  19. Feb 20, 2014 at 7:48 AM
    Poodle Head Mikey
    Those darned TM shareholders keep demanding profits. <g>
    "(TM) operating profits during the quarter were stronger than expected. This allowed share net to come in $0.85 above our projection, at $3.15.
    2013 consolidated vehicle sales forecast of 9.1 million units - but this ought to be fully offset by lower sales in overseas markets. Nevertheless, management raised its earnings forecast for the year. As a result, we have raised our fiscal 2013 bottom-line forecast by $0.85 per share, to $12.60.
    Shares of Toyota are ranked to out-perform the broader market averages in the coming 6 to 12 months. Solid demand trends in most regions, along with the aforementioned benefits to the bottom line, ought to allow for near record earnings for the year. Over the 3 to 5 year period, Toyota shares offer wide appreciation potential at the recent quotation . . . . "
    And the service department plays a big part in achieving the goal apparently. <g>
    PHM
  20. Oct 18, 2018 at 6:31 PM
    bkrdave36
    bkrdave36 Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Daystar 3 inch lift, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    Where do I find this TPMS reset button you all speak of?
