TPMS light, PSI, and cold weather
Discussion in '2nd Gen. Tacomas (2005-2015)' started by St. Swervus, Oct 22, 2012.
  1. Oct 22, 2012 at 10:25 AM
    St. Swervus
    St. Swervus [OP] Well-Known Member
    Nathan
    Mill Creek, WA
    '09 Double Cab TRD Sport
    Leer Camper. Thule Rack, NFab side rails w/step, 3' lift, Weather Tech mats, Paracord grab handles, LED interior lights, Bed Rug, Front windows tinted to match factory rears.
    Hey all. I did a search and came up with varying responses. I'm running 285 70/R17s. I drove my truck last night then parked in my driveway. We had our first relatively cold night here in Seattle and this morning my TPMS light is on.
    Checked all 5 tires and they're sitting right at 30 psi. Sound right or a little low?
    I'm going to do the chalk test here in a little while but I'm curious if the temp change is the culprit. It didn't get THAT cold out but....
    BTW my wife's Mazda does this every year when the weather changes. Usually add a couple of psi and blam-o it's all good. Hmm.... Thanks y'all.
  2. Oct 22, 2012 at 10:26 AM
    acdronin
    acdronin Well-Known Member
    Mine do the same thing when the weather turns
  3. Oct 22, 2012 at 10:37 AM
    St. Swervus
    Nathan
    Mill Creek, WA
    What's your fix? Bump the psi up then reset or just deal with the light being on?
  4. Oct 22, 2012 at 10:38 AM
    acdronin
    Pump them back up and reset the light
  5. Oct 22, 2012 at 10:53 AM
    St. Swervus
    Nathan
    Mill Creek, WA
    Thanks! I've got my tires chalked for a test later but the ground is wet and covered with leaves. Might fuck the test up. We'll see.
