TPMS pressure reading gauge.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dacon, Oct 15, 2018.
  1. Oct 15, 2018 at 11:36 AM
    Dacon
    Dacon [OP] 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    I have a good air compressor and a cheap (Auto Zone) air pressure gauge. I can not inflate all 4 tires at the same pressure no matter how many times I check. That dial is "general" at best.
    Any suggestion for a good digital air gauge?
  2. Oct 15, 2018 at 11:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I had a digital gauge that actively read pressures to 0.1psi. I bought it for $10 when Griots Garage was clearing them out. Slime started selling the same ones for about that price. This might be an updated version of it:
    https://www.amazon.com/Slime-20202-Digital-Pressure-Gauge/dp/B00G6UISRK
    I used and abused it for years until the spring arm broke off the battery contact. 0.1psi sounds dumb, but typical digital gauges read to 0.5psi. Side to side, you could be off by almost 1.0psi. I couldn't wrap my head around that big of a difference.
    I bought this afterward. It has a big following in the motorcycle community:
    https://bestrestproducts.com/shop/c...edition-tire-inflator/cyclepump-ez-air-gauge/
    I have an older version of it also. Since, they redesigned the straight and right angle chucks. I wish I had the right angle one, but the price is too high. Great gauge though.
    Either way, the ability to bleed down to a pressure is an important feature.
  3. Oct 15, 2018 at 12:03 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    I have a blue point inflator gauge I bought from the snap on man years ago when I worked on cars. It's accurate and I can both inflate and deflate with it. I think I've warrantied it out twice, but it gets way less use now days. It's probably rebranded from another manufacturer.
  4. Oct 15, 2018 at 12:05 PM
    slowtacotruck
    17 offroad
    stuff
  5. Oct 15, 2018 at 12:08 PM
    Dacon
    Danny
    Gilbert, Arizona.
    I would like one that I connect the compressor to it and to the tire. In this way I can check pressure as I inflate it.
  6. Oct 15, 2018 at 12:22 PM
    svdude
    svdude Well-Known Member
    jonathan
    Rick111, Techsan and NoOne like this.
  7. Oct 15, 2018 at 12:36 PM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
  8. Oct 15, 2018 at 12:54 PM
    navin r
    navin r Well-Known Member
    2017 double cab short bed trd off road 4wd w/ premium pkg.
    Craftsman 19.2 volt cordless inflator has a digital gauge, to 10ths of a lb if I recall correctly, seems to work OK.
  9. Oct 15, 2018 at 12:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Inflating them to the same pressure and keeping them at the same pressure is impossible. If half your car is in the sun and half in the shade it can change the air pressure. If you go around a bunch of left hand turns the outside front will increase by a psi or two. You cannot ever keep the same pressure in all tires, unless you keep it in a garage and never drive it lol.
    AKGSD, svdude and T4RFTMFW like this.
  10. Oct 15, 2018 at 1:51 PM
    Dacon
    Danny
    Gilbert, Arizona.
    Kept in garage. Tired of cheap analog gauges. Thanks to all for the links, will read about all.
    I know pressure changes with temp (from sun and driving) but I can't get constant pressure as is. The needle over the white background is flimsy and based on viewing angle is different reading.
    tonered and hiPSI like this.
  11. Oct 15, 2018 at 2:33 PM
    mvusa
    mvusa Well-Known Member
    2016 Silver Tacoma TRD Off Road 4x4 Access Cab V6 Auto
  12. Oct 15, 2018 at 2:41 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Unless you are a race car drive and need pure nitrogen and accuracy to 1/8 lb the digital gauges work just fine. I have 3 Slime brands keep one in my wife’s car, my truck, and my tool chest. I keep all tires at 35 but most important they are the same pressure left and right sides.
    r1200gs4ok and Sandman614 like this.
  13. Oct 15, 2018 at 2:48 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep! I check my air cold before leaving the garage. It allows me to gauge tire wear over time, which was a problem with my favorite motorcycle tires. Going up just 2psi (cold) eliminated cupping and netted a 25% increase in tire life.
    r1200gs4ok likes this.
  14. Oct 15, 2018 at 2:58 PM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    I have that gauge.
    I concur that it works very well.
  15. Oct 15, 2018 at 5:30 PM
    spp
    spp OC, Kalifornia
    OC California
  16. Oct 15, 2018 at 6:03 PM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    I like the Accu-gage brand products - made in USA, low price and most importantly, they will re-calibrate them for the life of the gauge.
    https://www.ghmeiser.com/
  17. Oct 15, 2018 at 7:38 PM
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    Milton pencil gauge.
  18. Oct 15, 2018 at 7:42 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    0.5/1 psi is a big difference? You do know that when you drive your tire pressure fluctuates, when one side sits in the sun, the temps/season changes.. It ain't a race car. Digital dash gauges have made people paranoid.
    Psst, do you know your speedo is off too.
  19. Oct 15, 2018 at 7:50 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Psst, well aware. Thanks for sharing.
  20. Oct 15, 2018 at 9:46 PM
    SouthParkColorado2
    SouthParkColorado2 Member
    Dale
    Hartsel/Aurora, Colorado
    2017 Tacoma TRD Offroad - White Long Bed
    K&N 33-5017, Toy Bed mat,
