Tpms problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smoke2, Jun 27, 2012.
  1. Jun 27, 2012 at 6:53 PM
    Smoke2
    Smoke2 [OP] Well-Known Member
    Tacoma
    07 DC 4X4 LB
    Rear TSB, Firestone Air bags
    I got new tires and now my tpms system light is on. I had the tire shop reset the system. The tpms scanner shows that the left rear tire pressure to be 78psi but the tire has 35psi in it. They says (tire shop) the sensor is bad but they didn't damage it. They said either the battery is low or the sensor pressure is stuck on 78psi. I did have my tire up to 78psi at one time. So without making it a big deal, I'm looking to replace the sensor. Where is the best place to buy a new sensor or used? I have offroad wheels so I need the 20 degree ones. Does it matter mixing non OEM with OEM? Any brands I should stay away from?
  2. Jun 27, 2012 at 6:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    have you tried to reset the sensors yet?
  3. Jun 27, 2012 at 6:56 PM
    TacoTitan11
    TacoTitan11 Well-Known Member
    Mr. C
    North Carolina
    2012 Tacoma
    just buy a used one on ebay $18
  4. Jun 27, 2012 at 6:56 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    78 psi sounds like too much air.
  5. Jun 27, 2012 at 7:05 PM
    Smoke2
    Tacoma
    07 DC 4X4 LB
    I had load range E's. The take 80psi max. I had 1100 lbs in the bed and pulling a 2500lb trailer. I was trying to get the tires up to 72psi...
    The tire shop reset tpms system two times. They deflated the tire and remove the sensor and installed it again. Also they tried to put another sensor in but it didn't work.
    Is there a way to rebuild or replace the batteries in the OEM sensors? I was told they need to be replaced every five to seven years.
  6. Jun 27, 2012 at 7:10 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Still too much pressure for that weight. 45-55 would be plenty, depending on the size of those E's. I suspect the high pressure is what damaged the sensor. A bit odd it seemed OK until the new tires though. Stupid question, you checked the pressure in the spare, right?
  7. Jun 27, 2012 at 7:29 PM
    Smoke2
    Tacoma
    07 DC 4X4 LB
    Yes, I had the tire shop replace the spare with correct size tire to match the others.
    I didn't like the E tires. They were to stiff or to spongy. I got rid of them and bought some D range. The last 2 years my tpms system was not coded because the tire shops didn't have a way to reset them. Now some of the shops have a computer that can re-code the system. I wasn't going to pay the Toyota dealer $150 re-code the system. I hope the C rated tires will work for my application.:confused:
  8. Jun 28, 2012 at 7:13 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Have you actually tried the reset procedure in the owners manual?
  9. Jun 28, 2012 at 7:27 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Every 5 years you should replace the batteries in the sensors (similar to your smoke detector) they don't last forever. [​IMG]
  10. Jun 28, 2012 at 7:30 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    honestly it's easier to just live with the light and check your tires regularly when you cant figure it out as opposed to spending hours at tire shops and spending money you don't have to IMO.
    <--- what this guy has been doing for nearly two years.
