TPMS Programmer
Discussion in 'Wheels & Tires' started by whitedlite, Jan 5, 2019.
  1. Jan 5, 2019 at 11:27 AM
    whitedlite
    whitedlite [OP] Well-Known Member
    USA!
    3RD Gen TRD 4WD
    what computer or device is needed to program new oem sensors to a truck?
  2. Jan 5, 2019 at 3:00 PM
    trdt44
    trdt44 Well-Known Member
    Trent
    Utah
    2017 Tacoma TRD OR
    I have the ATEQ Quickset TPMS tool and it works great. It will read the existing sensors stored in the computer and then allows a new set to be loaded into the truck. Both sets of sensor id's are stored on the computer and it is a quick process to switch. I used this with stock sensors and Denso (same as OEM). It will also work with 3 other vehicles.
    Eta: It is required to get the sensor id's off the new sensors before they are mounted. Otherwise a tool that can read the sensor id's is required.
  3. Jan 5, 2019 at 4:02 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    try these.......they work great !
    place directly over that silly azz light on the dash
  4. Jan 5, 2019 at 4:54 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    https://www.ebay.com/ulk/itm/152878359386
    So is this all I need? I took a photo of the sensor I removed and the new one I put in. Only one sensor was replaced.
  5. Jan 5, 2019 at 5:13 PM
    trdt44
    Trent
    Utah
    2017 Tacoma TRD OR
    Yep, the codes are the numbers that start with 86c and 1c8. Fyi, Tirerack has the quickset for $119. In your case you would pull the codes from the truck and then change the one you swapped out
    whitedlite[OP] likes this.
  6. Jan 5, 2019 at 9:16 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Thank you sir
  7. Jan 7, 2019 at 7:53 AM
    TWTaco
    TWTaco Well-Known Member
    Dave
    Carista works great for programming!Plus all the other functions it has.
  8. Jan 14, 2019 at 3:40 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    How do I know if programmed correctly? I haven’t driven truck yet. But after running the programming the TPMS flashed a minute then stayed on solid?
    It may go away with driving but idk
  9. Jan 14, 2019 at 3:53 PM
    trdt44
    Trent
    Utah
    2017 Tacoma TRD OR
    If remember right I had to go for a drive for the light to go off. For the pressure readings to show up I had to jump on the freeway for a minute.
  10. Jan 14, 2019 at 4:09 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Do I wanna go see my gf or not :anonymous:
    Thanks man. So far it was a super easy process. Just need to drive it to make sure the code took
    trdt44[QUOTED] likes this.
