TPMS question
Discussion in 'Wheels & Tires' started by SR54x4, Aug 4, 2010.
  1. Aug 4, 2010 at 2:53 PM
    SR54x4
    SR54x4 [OP] Well-Known Member
    Mark
    Hudson Valley
    2008 4x4 TRD SR5 Tundra
    Magnaflow 12588, TSC lo-pro extra deep toolbox, step bars and bull bar
    Will the stock tire sensors from my 2010 Taco with the STEEL wheels work with aftermarket ALLOY wheels?
  2. Aug 4, 2010 at 2:56 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yes...The valve stem may not fit exactly right tho...You might have to turn the 180 degrees or get a strap kit to make them fit right.
  3. Aug 4, 2010 at 3:10 PM
    moonman
    moonman Active Member
    Pacific Northwest
    2008 SR5 4x4 V-6 Access Cab
    TRD CAI, TRD Exhaust, Hood Struts, 5100's all 4, Kenwood DDX-812 w/NAV. 5100's + and a leaf. HID Projectors, HID Fog's, 4x4 Light, WET OKOLE, Fog Lights anytime, Smoked Tailights, LED Lamps, Red Line Hood Struts, Piller Gauge's,
    I tried to do that and They don't fit in there as they are different , The ones for the stock steel wheel is bent at 40 deg and the one for the stock Aluminum is bent at 20 deg. You maybe able to somehow get it in there but it wont be like they were.
  4. Aug 4, 2010 at 6:36 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    spot on info.
    Buy the strap kit or get the installer to turn 180.
    Many here have done both.
  5. Aug 16, 2010 at 2:15 PM
    SR54x4
    Mark
    Hudson Valley
    Ok thanks for the help. Here is another question...
    If I get new wheels and either re-use the old ones or get new ones is it true that only Toyota can calibrate them? If so how much will this cost me?
    Also, scenario two would be I just put the bigger tires on my stock steel wheels. Again will Toyota have to re-calibrate the stock sensors?
  6. Aug 27, 2010 at 8:56 AM
    mxracer452
    mxracer452 Member
    Spraggs, PA
    stock for now, 5100'a all around with 885 coils and 2' aal in rear, light racing uca's and m/t sidebiter wheels 16x8, and nitto terra grapplers 285/75/16 in the spring
    i'm getting new wheels for mine too, and instead of swapping the sensors as i want to keep my stock wheels for winter, i found oe sensors here for 35 bucks a piece, www.wholesaletpms.com. i found out that walmart will reprogram them for like 20 bucks, might be something worth looking into.
  7. Aug 27, 2010 at 10:03 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If you keep the same sensors and change the rims and/or tires- You can reset the "standard" pressure with the button under the steering wheel.
    If you get new sensors, I think the guys quoted below is right. Any big name wheel/car place should be able to do it.
