TPMS question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by M82mike, Jan 22, 2021.
  1. Jan 22, 2021 at 6:04 AM
    M82mike
    M82mike [OP] Active Member
    Milton, Indiana
    2010 reg.cab.2.7 5 spd. 4whl.dr. tacoma
    LCE headers, Intake spacer,
    My 2010 regular cab needs new tires. Found a set of 2021 Tacoma take offs. Will the tpms work with my old truck?
    Can I have the tpms removed from the spare and not worry about it? I check my tire pressure regularly. Great deal on tires and wheels, if it's not a big problem with the tpms!
  2. Jan 22, 2021 at 6:25 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, SPC, Archive, Method, RCI, C4
  3. Jan 22, 2021 at 6:32 AM
    Kmart6
    Kmart6 An Average Joe
    MD
    08 2.7 5spd
    3rd Gen tpms won’t work on 2nd gens. I bought 3rd Gen wheels and just have been dealing with the flashing tpms light. Will probably eventually throw some tape over it.
    TacomaUSA likes this.
  4. Jan 22, 2021 at 6:48 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    If you google something like "changing tpms without removing tires," there are quite a bit of instructions/videos on how to swap tpms sensors out without having to completely dismount the tires, which would require rebalancing, etc.
    I don't know about 2021 vs. 2010 sensors. Tpms sensors work in certain frequency ranges depending on what the car manufacturer specs/type of tpms systems. Most car manufacturers are pretty consistent with using the same system through many years.
    From what I can see, 2010 uses 315Mhz sensors. I couldn't find the info on 2021 (too new?), but 2020 uses 315Mhz as well, BUT I believe Toyota has to have the sensor numbers manually coded to the ecu, which requires a Techstream or similar. Most tire shops will do it for much cheaper than a dealer.
    Another option, since you would be opening up the beads anyway, is to install cloned sensors so your car just thinks the same sensors are still there. I have a cheaper ATEQ tpms tool (I forget what model) that can do this. It's not the higher end model that can program new tpms numbers into the ecu, but it can clone existing sensors (many aftermarket ones available). If I really wanted to, I have an Autel that can program new sensors too, but it's easier just to clone - especially if you have multiple sets of wheels/tires. I can put cloned sensors in all sets so no matter what I swap out to, so it makes no difference to the truck.
    Many tire dealers will also clone for a modest cost.
  5. Jan 22, 2021 at 6:54 AM
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Nailed it.
    Crow Horse likes this.
  6. Jan 22, 2021 at 5:49 PM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2015 ACLB TRDS, 2012 DCSB TRDOR
    3rd Gens won't work on 2nd Gens because of the ID#'s on the sensors are not compatible.
  7. Jan 22, 2021 at 5:54 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Are you sure there is a sensor in the spare? I thought that was done in '08?
  8. Jan 23, 2021 at 8:29 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Yea, they no longer put TPMS in spares and 2008 sounds about right. My 07 has one in the spare.
    Four new sensors are about $80
    Amazon.com: MORESENSOR Signature Series 315MHz TPMS Tire Pressure Sensor 4-Pack | Preprogrammed for Select 270+ Japanese Brand Models | Replacement for 42607-33011 | Clamp-in | NX-S008-4: Automotive
    Most any tire store will install them for $10-$20/ tire. They do not have to rebalance. They can mark the tire and wheel with a reference point so that when they remount everything is in the same position.
    Sensors typically last about 10 years, they just recently died in my 2007 so I got more life than most. If the ones in your 2010 are still working they are due to be replaced soon anyway. Even if you keep your old wheels and just buy new tires I'd order new TPMS sensors before buying tires. There won't be any additional charge to have them installed at the same time new tires are being mounted.
    For all the internet bitching about TPMS sensors they serve a purpose. They don't replace an air gauge, they give the driver a few seconds warning in the event of a sudden tire deflation while driving. BTDT. The warning gave me time to slowed down and off onto the shoulder of the road before the tire came apart at 70 mph. Spending $80-$120 every ten years is pretty cheap. Skip a Big Mac value meal once a year and you've paid for new sensors.
  9. Jan 24, 2021 at 7:07 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    My 2008 has one in the spare too.
  10. Aug 4, 2022 at 1:33 PM
    optifree
    optifree Well-Known Member
    Gary
    Pflugerville
    2010 AC TRD
    OME
    Are these still working for you?
