Tpms question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toywoodsguy82, Aug 23, 2021.
  1. Aug 23, 2021 at 6:57 PM
    Toywoodsguy82
    Toywoodsguy82 [OP] Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    Long story short… tpms like came on Friday… filled tires Friday evening to what I thought was 37 ended up being 40… brought my truck into discount tire Saturday and they were to busy to look at it come back today and also said right rear was at 32psi on Saturday…
    brought it back today and they said my tpms light came on because I don’t have a tpms in my spare and they can’t reprogram because of that…
    I just got a new spare tire on a new rim but that was like two weeks ago, why would it take so long for tpms to come on. Also my right rear was down to 30psi today but nothing was in the tire.
    Anyone heard of this before?? The tpms that is.
  2. Aug 23, 2021 at 8:41 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Factory setting for a TRD OR is 32/29 (can't remember which it front and rear off the top of my head) or at least that's what mine is. The spare tire sensor is optional, they didn't come from the factory with one but the option is there to program one in.
    It's easy to set the sensors you your desired pressure.
    1: Set the tire pressures to the pressure you want to run.
    2: Turn the key on and wait a few secs.
    3: Press and hold the TPMS reset button (directly under the steering column at the bottom of the knee bolster) until the TPMS light blinks slowly 3 times.
    4: Release the button and leave the key on for 1 min.
    5: Turn key off
    Te light will come on when the pressure is aprox 5 psi lower than the set pressure.
    Blockhead, 6 gearT444E and Jimmyh like this.
  3. Aug 23, 2021 at 9:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You very well may need one in the spare. I think the 2007 models came with 5 sensors.
  4. Aug 23, 2021 at 9:39 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Interesting I thought it was optional on all models with TPMS, my 14 doesn't have one in the sapre.
    Really the only way to tell if a spare is programmed or not is with a scanner that can read TPMS data.
  5. Aug 23, 2021 at 9:41 PM
    Toywoodsguy82
    Patrick
    Oregon
    Discount tire scanned them and they show they are working…. Well except the spare because it doesn’t have one in it
  6. Aug 23, 2021 at 9:41 PM
    uncle ed
    uncle ed Well-Known Member
    Ed
    CA Eastern Sierra
    2007 & 2019
    You need one in the spare
    My 07 would do about the same
    I’d reprogram and within about 5-7 days the light would be back on
    Sometimes less days but back on again
    Changed the sensor and not a problem again
  7. Aug 23, 2021 at 9:42 PM
    Toywoodsguy82
    Patrick
    Oregon
    did it blink like ten times and then stay on the rest of the trip?
  8. Aug 23, 2021 at 9:44 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If it blinks when you turn the key on there's a problem with one of the sensors, if it just comes on steady a tire is low.
    Jimmyh likes this.
  9. Aug 23, 2021 at 9:46 PM
    uncle ed
    Ed
    CA Eastern Sierra
    2007 & 2019
    Yes- I suffered through it for about 3 years
    Drove me nuts
    When starting up it would blink and then stay lit
    I bought a new sensor and a tpms reprogramming tool and made it go away in about 15 minutes
  10. Aug 23, 2021 at 9:47 PM
    Toywoodsguy82
    Patrick
    Oregon
    yea I know what happens when it comes on steady…
    discount scanned all the sensors and said they work
  11. Aug 23, 2021 at 9:47 PM
    Toywoodsguy82
    Patrick
    Oregon
    Humm ok.
  12. Aug 23, 2021 at 10:22 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is fine and good except the TPMS ECU is expecting to have 5 sensors not just 4. It is missing the TPMS Sensor in the spare. That is why you have the fault.
    They used to have TPMS Sensor in the spare tires from the factory. I think they stopped putting them in the spare tires around 2010 or so. My 2012 only has four, none in the spare from the factory.
    In order to get the light off you will need to disable the TPMS System or install a sensor in the spare and have it programmed into the TPMS ECU.
    Dm93 likes this.
  13. Aug 23, 2021 at 10:23 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Or Techstream where you can see what is programmed into the ECU.
    Dm93[QUOTED] likes this.
  14. Aug 23, 2021 at 10:24 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    6 gearT444E and Dm93[QUOTED] like this.
  15. Aug 23, 2021 at 11:31 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    To confirm your suspicions, my 2010 only has 4 as well. Not exactly sure of the year change but I know 2010 is when minor "wiring changes" occurred so my guess is anyone with a late model 2009 or 2010 will only have 4 sensors.
    Jimmyh[QUOTED] likes this.
  16. Aug 24, 2021 at 12:48 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    My 07’ has one in the spare.
    I remember this - https://www.tacomaworld.com/threads/tpms-5th-sensor.723674/
    See post #8, but the whole thing is worth reading. (Not necessarily you Jimmyh, you were part of this discussion) Anyone else curious might find it interesting.
    Maybe try ID code 0000000 and see if you can ignore the 5th?
    See what happens?, beats buying a sensor if you don’t want or need one.
    Jimmyh[QUOTED] and Key-Rei like this.
  17. Aug 24, 2021 at 4:02 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I think 2008 was the last year they put one in the spare. My 07 has one. I'd just buy 5 new sensors and have discount tire install them. Will cost you just over $100 on Amazon. You can get a 4 pack for $80, then buy a single for $25.
    If you're still on factory TPMS sensors you're way overdue. Most last 7-8 years, but the ones in my 2007 were still working in March. Since I was buying new tires I ordered 5 new sensors and had Discount Tire install them when they mounted tires. If you buy sensors from them they are $65 each.
    My spare was the one that came with the truck and since it was almost 14 years old they wouldn't touch it. I found a used take off that was only 4 years old from a small independent shop and replaced my spare at the same time.
  18. Aug 24, 2021 at 4:10 PM
    Toywoodsguy82
    Patrick
    Oregon
    new sensors were put in about two years ago
  19. Aug 25, 2021 at 12:53 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    This is why you have a TPMS Light on. You have to have a sensor in the spare and one in each of the other wheels too. Five Total Sensors.
    BlkDakDave and Blockhead like this.
  20. Aug 25, 2021 at 2:31 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Haha...lather rinse repeat...
    BlkDakDave likes this.
