tpms questions...
Discussion in 'Wheels & Tires' started by wolfman00, Jul 9, 2020.
  1. Jul 9, 2020 at 7:47 AM
    wolfman00
    wolfman00 [OP] Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    i was thinking about tpms recently, and was curious- knowing that sensors need to be programmed to the ecu, does that mean like 04b04...etc? if so, would that theoretically mean you could take tpms programmed from a different truck of the same year (or ecu code) and pop them in without reprogramming? provided ecu code was the same, like going onto another truck with 04b04?
    or am i overthinking?
  2. Jul 9, 2020 at 7:53 AM
    Shellshock
    Iowa
    If you go into TS, you can program new sensors.
    There’s a code on the sensors that needs to be entered for the ECU to find them. It’s going to be specific to your vehicle not ECU revision.
  3. Jul 9, 2020 at 8:42 AM
    wolfman00
    matt
    '16 dclb
    ah ok that makes sense .
