TPMS - Replace just one or all?
Discussion in 'Wheels & Tires' started by grissom, Dec 4, 2019.
  1. Dec 15, 2019 at 6:40 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    A federally mandated gimmick. Thanks to Ford Explorers and Firestone Tires.
    robssol, Kolter45 and KY_Rob like this.
  2. Dec 15, 2019 at 8:00 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    Yeah, that's what I remember. Yet you still see people driving around on tires that are more than half flat so it shows you can't fix stupid.
    Kolter45 likes this.
  3. Dec 15, 2019 at 8:07 PM
    Greenedmc
    Daniel
    Elizabethton TN
    Yep. I totally agree there. Most tire related incidents can be prevented with regular maintenance.
  4. Jan 7, 2020 at 8:53 PM
    black cx
    black cx Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    how much do oem tpms sensors cost?
  5. Jan 7, 2020 at 10:28 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    theres a website listed on TW somewhere that has a good website to get them cheaper!
  6. Jan 7, 2020 at 10:59 PM
    Waasheem
    Waasheem
    2007 xrunner
    I could be wrong but, I think they need to be installed at a tire shop, dismount remount the tire is necessary.
  7. Jan 8, 2020 at 2:52 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    OEM $65 to 92 depends where you get them and yes requires install and load each new one into the ECU and delete old ones.
    Dealer is pricey to do it but most tire store do it. Like I said earlier $60 each at Discount that's new TPMS sensor, install, and program so 4=$240.
