Tpms sensors 2nd gen for 3rd gen rims
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco600mpg, Jan 22, 2021.
  1. Jan 22, 2021 at 1:15 PM
    Taco600mpg
    Taco600mpg [OP] Well-Known Member
    Cam
    14 regular cab 5 speed manual
    2.25 inch lift, Firestone airbags, 235/85/16 tires, k&n 63 series cold air intake, LCE header and exhaust, nfab prerunner light bar, trd skid plate 3rd gen oem knock off, ecometer, kc lights, trd grill emblem, trifold bed cover, cb radio and antenna, pedal commander, volant ram air scoop, daystar airbag cradles, trd off road 3rd gen rims, hood hinge light mounts, bilstein 5100 shocks and 5100 struts set at 1.75 lift, strut spacers to gain . 5 more inches of lift, Jba standard high caster upper control arms
    I recently installed these 3rd gen trd off road rims and all 4 sensors won’t able to ready my truck. My 2nd gen came with steel wheels and the sensors r to short to mount on these new rims, will any second gen tpms sensors work on these rims and r will the stems be long enough
  2. Jan 23, 2021 at 6:15 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    I've read that 2nd Gen steel sensors can be used with alloy wheels but they need to be rotated. This can be an issue for future dismount/mount procedures. If you replace them with new, you'll need the sensors for alloy wheels (2nd Gen) and the Denso ones are a good economical choice. The Denso's are OEM.
    steelcity2 likes this.
  3. Jan 23, 2021 at 6:25 AM
    airmax233
    airmax233 Always ready for the next adventure
    Southern California
    12 PreRunnerTrd sport R.I.P 21 Tacoma Off road 4x4
    2.5 Kings w/resi Adj. Total Chaos Upper control arms. IG: Cement_runner23
    3rd gen sensors cannot be programmed to be used on a 2nd gen Tacoma. You either have to live with the orange light on the dash or get some new sensors that are compatible with your 2nd gen Tacoma. If you don’t care about the sensor being on you can also cover it with black tape.
  4. Jan 23, 2021 at 6:06 PM
    Taco600mpg
    Cam
    What second gen oem sensors will work on these rims?
  5. Jan 24, 2021 at 5:20 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
  6. Jan 24, 2021 at 11:55 AM
    Taco600mpg
    Cam
  7. Jan 24, 2021 at 1:24 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Pacific Industries manufactures the sensors for Denso who in turn supplies Toyota. Buying from Toyota will be much more costly than other sources. Amazon or Ebay have proved in the past to be the cheapest option for them.
  8. Jan 24, 2021 at 1:53 PM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
  9. Jan 25, 2021 at 2:44 AM
    Taco600mpg
    Cam
    Rock as in Dwain the rock Johnson
  10. Jan 25, 2021 at 3:16 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I was thinking Alcatraz but online only ordering and no customer pickup.....
  11. Jan 25, 2021 at 3:23 AM
    steelcity2
    Pittsburgh Pa
    Rockauto.com
    Then I use a 5% off coupon code from retailmenot.com
  12. Mar 8, 2021 at 11:41 AM
    Pinion
    Pinion Well-Known Member
    Drew
    Brookings Oregon
    2020 DCSB limited 4x4
