TPS light on, but no tires have low press
Discussion in '3rd Gen. Tacomas (2016-2023)' started by edelsite, Aug 6, 2020.
  1. Aug 6, 2020 at 6:42 PM
    edelsite
    edelsite [OP] New Member
    Erick
    2017 Tacoma TRD Off Road
    King shocks, Total Chaos upper arms
    The TPS light just came on and when I check the individual tire pressures, they're all showing dashes on the display. Tires are at correct pressure....first thing I checked. Is there a reset for the sys or a known problem with this?
  2. Aug 6, 2020 at 6:44 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Spare tire :eek:
  3. Aug 6, 2020 at 7:01 PM
    bluzharp
    bluzharp Well-Known Member
    Central AR
    19 OR DC LB Cement (the slowest color)
    Pro Suspension, Roadmaster overloads, Diamondback
    Yep, reset button on lower dash. I forget exactly how to rest it, hold it for 10 seconds or something. I have to bust out the manual every tire rotation. Try it. It should set the light to come on about 7 psi lower than the set pressure. You have to drive 10-15 minutes before it picks up the sensors.
    No sensor in spare like was on 2nd gen.
    BINK05TRD and hiPSI like this.
  4. Aug 6, 2020 at 7:19 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Drive it for 15 minutes.
    Chew likes this.
