Tracking down a vibe
Discussion in '2nd Gen. Tacomas (2005-2015)' started by salsataco, Jun 24, 2009.
  1. Jun 24, 2009 at 10:27 AM
    salsataco
    salsataco [OP] Well-Known Member
    Been having a vibe around 65 since new, now have 34k on the clock. Dealer says they all have them. Well I ran the truck parked today to about 2k rpm(65 mph if I were on the highway) and low an behold if I keep it there the truck vibes. Can any of you try this for me and confirm that they ALL do it???? Thanks
  2. Jun 24, 2009 at 1:35 PM
    salsataco
    Kind of an erratic rumble.
  3. Jun 24, 2009 at 1:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not sure what year your truck is, but I did this on my '07 with the 1GR, and have no vibes at 2k rpm.
  4. Jun 24, 2009 at 1:55 PM
    salsataco
    06 1gre. Do yo have that 60mph vibe?
  5. Jun 24, 2009 at 2:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I used to, but I had the tires ballanced, and it disapeared.
  6. Jun 24, 2009 at 2:27 PM
    salsataco
    Mine is clearly in the engine. Truck is smooth as silk otherwise.
  7. Jun 24, 2009 at 4:03 PM
    salsataco
    Anyone else with the on/off 65mph vibe try this?
  8. Jun 25, 2009 at 4:10 PM
    salsataco
    No One has this issue?
  9. Jun 25, 2009 at 5:30 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    I suggest you test drive another truck at the same dealership to see if "they all have them" because I surely don't but I have an 09 but it's the same truck.
  10. Jun 25, 2009 at 6:13 PM
    98tacoma27
    Ben
    Not Beech Creek
    I would say possible engine mount failure.
  11. Jun 25, 2009 at 6:17 PM
    salsataco
    Dont go saying that.
  12. Jun 25, 2009 at 7:35 PM
    98tacoma27
    Ben
    Not Beech Creek
    ok, I retract my statement, :eek:
  13. Jun 25, 2009 at 7:48 PM
    salsataco
    Much better. This is a slight vibe more of a buzzing/rumble. Plus Ive always had it. But just noticed it happens when parked and revving. When driving I feel it in the pedal and the wheel.
  14. Jun 25, 2009 at 9:19 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    i believe there is a TSB for the motor mounts failing. Or its only for 05's. someone else can jump in and correct me if i am wrong.
  15. Jun 25, 2009 at 9:28 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    More info, if you don't mind. 2X, 4X, Ex Cab, Quad cab?
  16. Jun 26, 2009 at 6:31 AM
    98tacoma27
    Ben
    Not Beech Creek
    Not sure this applies.
  17. Jun 26, 2009 at 7:35 AM
    salsataco
    Dealership did that when I had my tsb springs. I am thinking torque converter or harmonic balancer? access cab 4wd.
  18. Jun 26, 2009 at 8:07 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    I have tried mine sitting in the driveway at 2,000 RPM's and nothing, driving around town in 3rd gear, nothing, and in the highway and nothing at 2,000 RPM.
    Sorry man
  19. Jun 26, 2009 at 1:18 PM
    thomasr1950
    thomasr1950 19 Tacoma TRD Off Road
    central us
    I have the same or similar. I had the dealer rebalance & it went away. I still have some vibration about the same speed, mostly on asphalt, seems to go away on concrete. I'm going to have my dealer check it out again.
