Tracking down front-end clunk?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rednext, Jul 15, 2020.
  1. Jul 15, 2020 at 5:18 AM
    rednext
    rednext [OP] Well-Known Member
    2013 double cab. I recently replaced the LCAs with Moog units, because the truck is at 230k miles and one of the bushings on the driver's side shat the bed. I had a little noise over bumps before, and thought that was the problem.
    The same noise is still there, albeit a bit less so (it seems), but I noticed a new noise this morning. I crossed a ditch at a 45 degree angle with the wheels straight (like you do), and when the suspension articulated there was a loud clunking noise. On first crossing, it was only when the driver's side crossed. On the way back out it did it when both sides articulated.
    Edit- it was when the suspension traveled up into the wheel well that it happened, on both occasions
    It doesn't do it during normal driving, and it has never done it before replacing the LCAs. I checked UCA bushings and felt the upper ball joint when I had the suspension apart, and I assume the guy at the shop torqued everything down when he aligned it.
  2. Jul 15, 2020 at 5:56 AM
    TwoTacos
    TwoTacos Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport
    3" Leveling Kit with AAL, 5160/6112 Billsteins, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
    Check your sway bar bushings, easy to replace.
    rednext[OP] likes this.
  3. Jul 15, 2020 at 5:56 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
  4. Jul 15, 2020 at 6:06 AM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    I have the same noise. Stock LCA but replaced sway bushings and end links with MOOG.
    I think radiator support bushings are the culprit but I’ve yet to pin point.
  5. Jul 15, 2020 at 10:35 AM
    rednext
    Thanks guys. The sway bar bushings have a little slack, but not a hell of a lot. I still suppose that could be some of an issue, but I'm not convinced.
    The radiator support bushings may be a good place to look too. I'll check that, and I'm taking it back to the shop that aligned it whenever I get time.
    verynearlypure likes this.
  6. Jul 15, 2020 at 12:15 PM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    If you stated that it has never happened prior to LCA replacements, I would venture to guess that it's not torque properly. Hope the installer didn't go by his noodle arms but with a torque wrench.
    verynearlypure and b_r_o like this.
  7. Jul 15, 2020 at 6:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, more than one person (myself included) have had the LCA bolts loose.
    Are you lifted?
    I remember someone having a very similar issue with the sway bar rubbing the coil springs.
    winkel likes this.
  8. Jul 15, 2020 at 6:58 PM
    rednext
    Yeah, I don't know that he used a torque wrench. I do know that the guy who lined it up is not the guy who usually works on my rides, but it was his nephew so I let it slide. There's a distinct possibility that that's the problem. When I get time I'll crawl under it and look. Or rather, I'll take it back to them and have them do it.
    Yes, I'm lifted, but I moved the swaybar so it doesn't contact
    TnShooter likes this.
  9. Jul 15, 2020 at 8:58 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    X3 on the LCA torque. Spec is 100 lb/ft and it's very easy to overlook
  10. Jul 21, 2020 at 11:05 AM
    verynearlypure
    Ernest
    The Buckeye State
    Did you end up finding the culprit?
    I’m going to start seriously tackling the sound I’m getting in the next few days. Even if it means going to a shop for help. :annoyed:
  11. Jul 21, 2020 at 11:10 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    I had a front end clunk that was driving me crazy every time I went over speed bumps and such. It went Finally away when I replaced the shocks. I guess the cheap spacer lift had finally taken its toll on the stock shocks. Ended up getting 5100s with ome 887 coils.
  12. Jul 21, 2020 at 11:16 AM
    verynearlypure
    Ernest
    The Buckeye State
    Thank you for your feedback.
    I’ll be rechecking LCA bolt torque of 83ft lb as well as somehow inspecting radiator mount bushings. I’ve suspected it may be a shock as well or a LCA getting hung up.
    All stock suspension except sway links and bushing replaced with MOOG.
  13. Jul 21, 2020 at 11:33 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    83 lb/ft is for the lugnuts
    LCAs are 100 lb/ft
  14. Jul 23, 2020 at 7:23 PM
    rednext
    I have not tracked it down yet. I live on a gravel road, and the county can't find anyone who can run a grader so it's full of washboards. It sounds terrible. The shocks are new(ish) Bilstein 5100s, maybe 5k on them. I haven't had time to fool with it yet, but next time I get a chance I'm carrying it to get lined up and making them stick a torque wrench on it.
  15. Dec 1, 2020 at 3:11 PM
    rednext
    Island Cruiser and TnShooter like this.
  16. Dec 1, 2020 at 3:41 PM
    TnShooter
    Deogee
    STOCK
    Island Cruiser likes this.
  17. Dec 1, 2020 at 3:46 PM
    rednext
    Me either! They didn't look bad either, which is why I didn't do it at first. The rubber seemed intact. But, looks can be deceiving. The inner sleeve was shot. I didn't install the new ones upside down as the OP suggested, but, the height seems the same to me. So far the poly seem to be doing fine but it's day one, lol.
    TnShooter[QUOTED] likes this.
