Tracrac or Rola bed rack?
Discussion in 'Product Reviews' started by WardDeaux, Oct 28, 2015.
  1. Oct 28, 2015 at 12:21 PM
    WardDeaux
    WardDeaux [OP] New Member
    08 Tacoma TRD Crew
    Do any of you have experience either the Rola Or Tracrac Trac-one bed racks? The Rola comes with rail mounts. The Tracrac rail mount kit is an additional $60 or so. HomeDepot has the Tracrac for $298. Rola at Amazon is $296.
    Thanks
  2. Oct 28, 2015 at 1:24 PM
    TempleToyota
    TempleToyota New Member
    15 Tacoma DBL Off Road
    Huh, wasn't aware of the Rola. I've been looking at TracRac and Thule Xsporter. I would be interested in hearing more about Rola. I don't believe Trac Rac has locking components like the Rola. Let us know how it goes.
  3. Nov 9, 2015 at 1:37 PM
    808TAC2012
    808TAC2012 Active Member
    Kevin
    NorthShore / Red Raider Country
    2012 PreRunner TRD Sport
    18" FN Wheels, Bakflip bed cover, NFAB Bars, 6000K HID Headlights and 6000K HIDFogs, Ceramic tint.
    I had 2 trac racs ... the first one on my GMC Sierra and it worked great... it could hold up to 1000lbs. They heaviest I loaded it was about 500lbs.
    The other one that I bought was for the Tacoma which I still have and it is the one from Home Depot and it does the job. It is a little more flexible because it doesn't have the angle cross bar but so far when I used it does the job. The reason I bought the TRAC RAC was that I seen people cut the height and width to make it fit the Tacoma better which I did. I cut the height 4 1/2 inches and width 5 inches.
    I am curious about the ROLA.
    Depends how much weight you will carry the THULE will be another option but a lot more expensive.
    Check Craigslist that might be the deciding factor.
  4. May 8, 2016 at 2:07 PM
    Goblin
    Goblin TSB 0305-08 Rev2 & TSB 0373-09 DONE
    VA
    09 SR5 TRD OFF ROAD
    STOCK TRD 4X4 OR DC
  5. Jun 21, 2016 at 8:05 AM
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
  6. Jul 23, 2016 at 9:42 AM
    hobiecat111629
    Used the ROLA for the first time last week. Assembly was a headache and the tolerances are very loose, meaning one of the uprights isn't welded to the attachment to place completely straight and requires a decent amount of yanking and pushing to get it on the truck.
    Once it was on and I was content with the alignment it was great and handled the 3 kayaks like a champ. For $200 it'll do what it needs to do the 3 times a year that I'll use it and it's not worth the effort to ship it back.
    If I had to do over, I'd probably spend the extra $60 on a tracrak.
